anyone beat this?
pgk pgk | 16/02/2021 14:14:09 |
2073 forum posts 290 photos | I tooka small item into shed to put in a battery. 2 tiny screws removed with jewellers screwdriver... and yes, I dropped them! Then bent down and picked both up from the floor!!! |
Jeff Dayman | 16/02/2021 14:16:36 |
2125 forum posts 45 photos | I'd give Guinness WR a call! That would not have happened that way in my shop these days - they'd be gone like the wind. |
mechman48 | 16/02/2021 17:43:04 |
![]() 2886 forum posts 449 photos | I don't even bother looking; just wait until I do a weekly clean up then sift through the debris .. George. |
old mart | 16/02/2021 17:46:12 |
2850 forum posts 181 photos | You must have cheated and swept the floor first. |
Dominic Bramley | 16/02/2021 17:50:23 |
46 forum posts 1 photos | Without Norris there to verify the attempt, I'm afraid no-one is going to believe you! Dom |
Samsaranda | 16/02/2021 17:54:42 |
![]() 1071 forum posts 5 photos | Having worked on aircraft, when you drop a screw or a bolt you develop a sixth sense that is able to track where it’s gone, very embarrassing if you can’t find the missing item in the aircraft structure. Loose nuts bolts and screws have a habit of finding areas like controls where they can jam items, definitely not desirable if it’s flying controls etc. Dave W |
Grindstone Cowboy | 16/02/2021 17:57:28 |
560 forum posts 49 photos | Dedication's what you need! (Only those of a certain age will understand the full significance of this Rob P.S. if you haven't got dedication, a magnet in a plastic bag is a reasonable substitute for finding ferrous fasteners |
Shadow | 16/02/2021 19:07:42 |
19 forum posts 1 photos | Great respect for your accomplishment! I have searched for small screws in office carpet. Literally almost down the drain. My most miraculous save was when servicing an obsolete microscope at a medical clinic on their countertop. I was reinstalling a 1mm slotted set screw when I dropped it and I heard it hit in the stainless steel sink about 18" away. I picked it out and the same thing happened but an immediate search found nothing. A second search found it in the small ring of water surrounding the drain, disaster averted. |
Vic | 16/02/2021 19:56:15 |
2750 forum posts 1 photos | Posted by pgk pgk on 16/02/2021 14:14:09:
I tooka small item into shed to put in a battery. 2 tiny screws removed with jewellers screwdriver... and yes, I dropped them! Then bent down and picked both up from the floor!!! I find this extremely unlikely, not impossible but unlikely ... |
Phil super7 | 16/02/2021 20:35:56 |
14 forum posts | I think it all depends if the workshop pixies are watching at the time.
pgk pgk | 16/02/2021 20:46:20 |
2073 forum posts 290 photos | I swear it's true, Gov. pgk
Windy | 16/02/2021 21:42:43 |
![]() 839 forum posts 166 photos | Bits I drop seem to have a spring on them and land where you don't expect them to. |
Dominic Bramley | 16/02/2021 21:49:19 |
46 forum posts 1 photos | Last week I was knocking the pin out of a knurling wheel and thought to myself "this is going to fall on the floor and get lost". I had 3 second look around for something to catch it in before thinking "**** it - I'll just watch where it lands". Bang! Gone. Dom |
Nigel Graham 2 | 16/02/2021 21:59:35 |
1275 forum posts 17 photos | My workshop pixies amuse themselves even without my aid. A couple of times lately they have knocked objects some distance from me onto the floor. I used a set of ball-ended Allen keys in dismantling my old drawing-board the other day. That was in the house. The keys, in their plastic block, normally live on a shelf in the workshop. Wanted them today, in the workshop. Gorn! So has the big tobacco-tin stuffed with assorted Allen keys. Luckily I found a key that fitted the M6 cap-screws I was using - note I didn't say a key for M6 cap-screws. Just one that managed the task in hand. I don't need drop tiny objects on the shed floor to lose them - I can lose quite sizeable things without any trouble at all! |
mechman48 | 17/02/2021 13:35:20 |
![]() 2886 forum posts 449 photos | How many have done simlar as in putting some thing down on the bench/worktop, turned away to get something else, turn back & cannot find the item you put down, no matter how hard you search. You then go & get an alternative tool to do the job intended put that down on the bench... right next to the item you lost in the first place, I did that yesterday. Those workshop gremlins are pretty smart, & damned fast too ! George. |
Derek Lane | 17/02/2021 14:12:32 |
![]() 412 forum posts 85 photos | Posted by mechman48 on 17/02/2021 13:35:20:
How many have done simlar as in putting some thing down on the bench/worktop, turned away to get something else, turn back & cannot find the item you put down, no matter how hard you search. You then go & get an alternative tool to do the job intended put that down on the bench... right next to the item you lost in the first place, I did that yesterday. Those workshop gremlins are pretty smart, & damned fast too ! George. I can relate to that lost count how many times I have done that, then decide to clean the bench to stop it happening again only to loose the next piece |
Howard Lewis | 17/02/2021 16:15:36 |
4683 forum posts 10 photos | SOMEWHERE under the bench are a load of high number drills, dropped the box, half fell out and vanished heaven only knows where. Probably guarded by all the small BA nut ans washers that have escaped my grasp. How long can it take to find a M6 x 100 bolt after falling about 300 mm onto a steel bench? About 30 minutes in my shop. How did it get to hide behind the Mill? But I got it!!!! Have just spent half a day resetting this PC after it decided to rest the outgoing mail server details, without my permission or aid. Having FINALLY got it reset, it is obviously sorry and now recompences me by working faster than ever before. Howard |
peter smith 5 | 17/02/2021 18:26:45 |
76 forum posts | You mean that you can actually bend down??? I have to get “ Erin doors” to put me socks on of a morning. pete |
pgk pgk | 17/02/2021 18:56:46 |
2073 forum posts 290 photos | Posted by peter smith 5 on 17/02/2021 18:26:45:
You mean that you can actually bend down??? I have to get “ Erin doors” to put me socks on of a morning. pete Lie on my back on the bed and bend knees to put on socks I do try an do excercises to keep bits working. Rowing machine temporarily abandoned after spraining an ankle - 6 weeks ago and still painful and swollen. But one arm dumbell lifts and presses and pec excercises. If I miss 2-3 days then weight capability drops markedly.... I also practice putting shorts on standing on one leg- balance is becoming an issue but it helps to have the lifted leg swung slightly across the standing leg... pgk |
peter smith 5 | 17/02/2021 19:16:15 |
76 forum posts | You need to take more water with it! pete |
