WM180/DB7 mini lathe to cut 32TPI
Setting up for 32tpi
Lainchy14/02/2021 17:01:51
271 forum posts
103 photos
Hi Forum
I have a Chester DB7 and mid Juliet II build. I'm looking at single point cutting the gland nuts... 32tpi. Only issue is, the lathe doesn't list it!
I'm looking for a final ratio of 0.375 on the 12tpi leadscrew, but looking at the online threading calculators... they seem to be for different change gear setups.
I got some details on this forum of a 26tpi thread setup, but my head hurts now.
Has anyone set up 32 TPI on one of these mini lathes?
Many thanks
Ian
JasonB14/02/2021 17:04:48
21999 forum posts
2539 photos
How many teeth on the fixed spindle gear and what change gears do you have.
Lainchy14/02/2021 17:18:44
271 forum posts
103 photos
Hi JasonB,
Fixed gear on headstock Spindle is 40
Selection of available.... 20,30,33,35,40,42,50,52,60,75 and 2x 80
I did some calcs... but I was down to manually doing each one, and I did get to one combination, but there's no way I could have got the gears to mesh, being too far out.
Redsetter14/02/2021 17:33:42
194 forum posts
Wouldn't it be quicker to use a die?
Lainchy14/02/2021 18:06:28
271 forum posts
103 photos
It would be way quicker to use a die, yep, BUT, this is for gland nuts. I want it to be a really good fit in the steam chest, otherwise, it'll undo itself over time.... according to the articles.
Lainchy14/02/2021 18:22:52
271 forum posts
103 photos
I say the lead screw is 12TPI based on searches, but in the manual, I've just found 2mm pitch.
Calculations of some of the stock setups, give the following
40 TPI
40/60 = 0.6666
60/52 = 1.1538
33/80 = 0.4125
0.6666*1.1538*0.4125 = 0.3172
0.3172*40= 12.688
28 TPI
40/80 = 0.5
80/33 = 2.4242
30/80 = 0.375
0.5*2.4242*0.375 = 0.4545
0.4545 * 28 = 12.72
..... so maybe the leadscrew pitch is 12.7 per inch?? Seems a strange pitch though?
Peter Cook 614/02/2021 18:28:14
212 forum posts
55 photos
12.7 per inch is 2mm pitch ( exactly). The manual seems correct.
Howard Lewis14/02/2021 18:33:10
5748 forum posts
13 photos
12.7 per inch look like 2mm to me!
32 tpi is a pitch of 0.3125" or 0.79375 mm This requires a gear train ratio of 2.519685 :1 for a 2mm pitch leadscrew.
So a compound train is very likely Could be that a mod to some of the numbers in the 40 or 28 tpi trains would give what you want.
What changewheels have you got?
Lainchy14/02/2021 18:39:55
271 forum posts
103 photos
Thanks chaps
Redsetter14/02/2021 18:45:57
194 forum posts
Posted by Lainchy on 14/02/2021 18:06:28:
If you use a split die you can get the threads as tight as you like. In practice they seldom unscrew because there is enough friction from the packing to retain them.
JasonB14/02/2021 18:47:21
21999 forum posts
2539 photos
is it a metric lathe or imperial eg what are the handwheels marked as
Post a photo of the chart on the headstock then we can check the leadscrew from that.
Howard, you have been using the Duffer rule again, 32tpi is 0.03125"
Lainchy14/02/2021 18:49:24
271 forum posts
103 photos
Redsetter... That's true! Will check if I have a split die for that and try on a piece of scrap.
JasonB... will do. Bear with. Lathe is Metric, but I believe the leadscrew is the same on both.
Lainchy14/02/2021 18:52:59
271 forum posts
103 photos
Edited By JasonB on 14/02/2021 19:19:09
Lainchy14/02/2021 19:15:36
271 forum posts
103 photos
The 0.8mm pitch maybe close looking at it. Very short length of thread needed... maybe 3/8 tops.
25.4 /32 gives me 0.79375. 0.006mm short. That's pretty close maybe?
JasonB14/02/2021 19:20:54
21999 forum posts
2539 photos
Yes, I'd just worked out a different 0.8mm which is probably as close as you will get with the gears you have only 0.00025" out per turn.
Lainchy14/02/2021 19:24:36
271 forum posts
103 photos
Superb JasonB Many thanks.
I'm gonna sit and work that out too. First time I've gone off the stock and it had me totally flummoxed, especially when I was struggling with the online tools too.
Many thanks !
Ian
Neil A14/02/2021 20:40:13
104 forum posts
Jason - I think you have put the second 40/80 round the wrong way in your calculation, is the "Duffer Rule" catching?
I have had a little go at this, it all depends if you can fit the train on the banjo.
(40/40) x (20/60) x (50/42) with a 2mm leadscrew this gives 32.004TPI.
As I have said, it all depends if it will fit on the banjo. I hope it does.
Should have said, you may have to change the order of the drivers and driven gears to fit.
Edited By Neil A on 14/02/2021 21:09:13
Lainchy14/02/2021 20:45:59
271 forum posts
103 photos
Ah yes, just checking and indeed.... that would be 40/80, 40/80, 20/50. I'm guessing it would still fit, given that it's on the chart. I'll take a look at this also Neil. Going to be tail end of next week to get the gears off.
Many thanks
Ian
Edited By Lainchy on 14/02/2021 20:50:52
JasonB14/02/2021 20:46:12
21999 forum posts
2539 photos
Yes you are right Neil.
Neil A15/02/2021 22:02:31
104 forum posts
I have just run through my original suggestion for the gear setup and I don't think it will work because of tooth tip interference. I think that I have tried all the combinations of that setup.
I have another setup where the tips just run clear, but again it depends on whether it will fit in the banjo length.
(40/42) x (40/60) x (50/80)
There will be clearance between the 42 tooth and the 50 tooth gear. Assuming the gears are 1 Module the gap will be 2mm.
I should have checked the first one more thoroughly.
walker midge
JD Metals
rapid Direct
