Ultra sonic cleaning
Liquid
Boiler Bri11/02/2021 17:58:02
840 forum posts
199 photos
Is the liquid in these ultrasonic cleaner units specific to the parts being cleaned. ?
I was offered one but know nothing about them
Bri
Martin King 211/02/2021 18:16:09
938 forum posts
420 photos
Hi Bri,
i use mine on an almost daily basis with water, (unit is heated), with just some washing up liquid in it.
Works very welll indeed. Mainly smaller parts and grungy castings etc.
Cheers, Martin
Nigel Graham 211/02/2021 18:26:41
1898 forum posts
26 photos
I used one at work for cleaning mainly small metal parts, admittedly already quite clean, and the proprietary detergent didn't appear to be anything very special that washing-up liquid would not match.
Any specificity would be in material, not item; and there might be fluids appropriate for certain things like printed circuit-boards. Best source of information on that are the stockists of the plant and fluids - they want to sell you it but despite the "use outside our control" caveat, it's in their interest to help customers to select wisely.
The bath I used had a heater which helps the action and speeds the drying time.
David Jupp11/02/2021 19:07:46
806 forum posts
17 photos
There are specialised solutions/chemicals available for different purposes. You can get a long way with a general detergent or de-greaser solution.
Don't use flammables unless you known exactly what you are doing, and take the appropriate precautions.
Nick Clarke 311/02/2021 19:07:56
1322 forum posts
53 photos
My unheated unit (It is a 15quid Aldi special) uses water with a spot of washing up liquid as above.
I have not had to use it for engineering stuff but for mechanical film camera parts, fountain pens and spectacles it works a treat.
Edited By Nick Clarke 3 on 11/02/2021 19:08:07
Dave Smith 1411/02/2021 21:58:37
208 forum posts
40 photos
I use Allendale general ultra sonic cleaning solution in my 2L heated version. All my machined and small soldered parts go into his machine no matter the material. For delicate stuff, watches, jewellery, 4mm scale loco chassis and bodies I have a small unheated one I put warm water and washing up liquid in.
Graham Stoppani12/02/2021 06:45:29
109 forum posts
21 photos
There was an earlier thread on this subject that may be useful, including my own contribution about using solvents in glass jars.
LINK
Russell Eberhardt12/02/2021 08:58:58
2726 forum posts
86 photos
I have found that dishwasher rinse aid is preferable to washing up liquid as it is a non foaming detergent. However my main machine is almost permanently fille with clock cleaning liquid to this recipe:
Clock cleaning solution
Brass parts in particular come out bright and shiny.
Russell
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
