Plans
Neil Wyatt | 09/02/2021 09:56:26 |
![]() Moderator 19076 forum posts 736 photos 80 articles | I’ve had Bernard is very pleased people like his lantern chuck. He is drawing up the design with pencil and paper, and it should appear in MEW 302. Neil |
Phil P | 09/02/2021 10:08:10 |
805 forum posts 195 photos | Neil Do you have any more details or photo's of Bernard's lantern chuck, it is not something I am aware of. Thanks Phil |
IanT | 09/02/2021 10:37:30 |
2002 forum posts 212 photos | They are in MEW 301 Phil.... IanT |
Martin Kyte | 09/02/2021 11:17:16 |
![]() 2781 forum posts 53 photos | I have to say that the Lantern Chuck article is the very essence of what a small project for MEW should be. It's reasonably quick and cheap to make. It's something that, even if you were aware of, you probably will not have got around to making yet (like me). It's a genuinely usefull piece of kit that once you have you keep using. It's, as far as I am aware, not something you can buy. I do make quite a lot of workshop tools and equipment but usually on the more elaborate side such as dividing heads etc. The smaller stuff tends to get overlooked especially when there are workarounds and lash ups which just delays making the proper piece of kit. I have been sometimes going to make a lantern chuck for about 20 years and the article has given me a sufficient nudge to get on with it. Thank you very much Bernard. You have done me a great service. regards Martin
Edited By Martin Kyte on 09/02/2021 11:18:30 |
Neil Wyatt | 09/02/2021 12:45:11 |
![]() Moderator 19076 forum posts 736 photos 80 articles | I agree, I would like to be able to publish more projects of this type - good learning project for a beginner, useful for the experienced. Neil |
Andrew Tinsley | 09/02/2021 13:35:58 |
1611 forum posts | Like Martin, I have been meaning to make one for many years! I will now get stuck in, thanks Bernard! Andrew.
RRMBK | 09/02/2021 19:01:17 |
154 forum posts 18 photos | Hi Neil. If you are not a subscriber and your local newsagent / WHS doesnt stock MEW, is there a way to buy individual copies by post please? |
Mike Poole | 09/02/2021 19:12:50 |
![]() Moderator 3374 forum posts 76 photos | Posted by RRMBK on 09/02/2021 19:01:17:
Hi Neil. If you are not a subscriber and your local newsagent / WHS doesnt stock MEW, is there a way to buy individual copies by post please? The RH end of the black bar above has a back issues button which takes you to the back issue supplier. I think they supply on a “when they are gone they are gone” basis. Failing to find what you want there you can find most copies on eBay which will usually be used copies. Mike |
JasonB | 09/02/2021 19:20:59 |
![]() Moderator 23022 forum posts 2763 photos 1 articles | Posted by RRMBK on 09/02/2021 19:01:17:
Hi Neil. If you are not a subscriber and your local newsagent / WHS doesnt stock MEW, is there a way to buy individual copies by post please? You can also buy digital back issues from Pocketmags as well as the current issue, allows printing off of two pages at a time. |
bernard towers | 24/04/2021 18:58:26 |
687 forum posts 141 photos | drawing in issue 303 has a mistake . the dimension for screw cutting the internal thread on the lantern screw should read 0.710 screwcut 32TPI. to be a close fit on thread on body. Hope neil sees this as it needs to be noted in the mag. Edited By bernard towers on 24/04/2021 19:23:02 |
Tricky | 30/04/2021 16:32:51 |
65 forum posts 8 photos |
bernard towers | 30/04/2021 19:37:53 |
687 forum posts 141 photos | sorry Richard but the 1.2 dimension does not appear on my original drawing. the mix of dims are there to enable people to imagine the sizes as some people think in imperial and some in metric. It looks like you have made a good job of it and I hope it gives you pleasure using it. Try putting your screws in with tweezers. |
