Martin King 2 | 02/02/2021 18:57:17 |
984 forum posts 439 photos | Hi All, would anyone know if it is possible to buy allthread rod in 7/32” x 28 tpi BSF? cheers, Martin |
Keith Long | 02/02/2021 19:57:03 |
877 forum posts 11 photos | I think you'll struggle. In Kempes Engineers Year Book for 1965 7/32 BSF is marked up as "to be dispensed with whenever possible". So if it was out of favour 55 years ago it's not likely to be stocked very much. The common sizes of 3/16, 1/4 and 5/16 are readily available according to a quick internet search. |
Mike Poole | 02/02/2021 21:29:38 |
![]() Moderator 3306 forum posts 73 photos | That may be hard to find, I don’t know whether 1BA would of any help but it’s fairly close. No use of course if it has to fit other parts. Mike |
Robert Butler | 02/02/2021 21:53:35 |
384 forum posts 6 photos | Or if you have a lathe with a hollow headstock mandrel purchase a 7/32 BSF die from Tracy Tools and cannibalise a die holder to enable it to fit in a three jaw chuck, support in a suitable bush drilled in situ in the tool post. Lock in tailstock chuck to prevent rotation with tailstock unlocked and free to slide. The die plus cannibalised die holder is of little cost and subject to between centres distance enables you to produce whatever length and quantity you require. Go steady if you drive the mandrel other than by hand!! Robert Butler |
Georgineer | 03/02/2021 09:35:36 |
565 forum posts 32 photos | Can one ask why? It seems such an unusual thing to need. George B. |
JasonB | 03/02/2021 09:58:41 |
![]() Moderator 22588 forum posts 2641 photos 1 articles | Posted by Georgineer on 03/02/2021 09:35:36:
Can one ask why? It seems such an unusual thing to need. George B. English plane makers like it. As you are likely to just need short lengths why not get some 7/32" rod and a tailstock die holder and thread it under power a couple of inches at a time. Or find a man with a repetition lathe and coventry diehead.
Edited By JasonB on 03/02/2021 10:04:17 |
Andrew Johnston | 03/02/2021 10:24:56 |
![]() 6575 forum posts 701 photos | Posted by JasonB on 03/02/2021 09:58:41:
Or find a man with a repetition lathe and coventry diehead. Funny you should mention that. Appropriate Coventry diehead chasers seem to be available secondhand. Andrew |
Tim Stevens | 03/02/2021 10:27:16 |
![]() 1587 forum posts | You might find it helpful to start with a length of 1/4" x 28 UNF studding (=allthread). Especially as UNF is current in the USA, and still around in GB. Running a tap down it should be easier than starting with 7/32" rod. Cheers, Tim |
Robert Butler | 03/02/2021 10:36:10 |
384 forum posts 6 photos | Or a die Robert Butler |
Tim Stevens | 03/02/2021 10:39:01 |
![]() 1587 forum posts | Robert - you got me bang to rights. Whatever that might mean ... Tim |
Robert Butler | 03/02/2021 10:44:46 |
384 forum posts 6 photos | Tim - no problem - anything to include a bit of humour Robert
Howard Lewis | 03/02/2021 11:15:57 |
6024 forum posts 14 photos | Tim, You screwed up there! If only a short length is needed, if it not available, as already suggested, make it. A friend wanted a LH 1/2 UNC nut. Either not available or at RIDICULOUS prices, (£50+ each). Having some hexagon bar, a set of Taps worked out much cheaper! Howard |
Martin King 2 | 03/02/2021 11:24:58 |
984 forum posts 439 photos | Hi All, Jason has it right. It is common on many STANLEY planes and others. i need some length to remake knackered adjuster columns on some spokeshave adjusters etc. i will try a hexagon die from Tracy tools then try to power thread some at low rpm in back gear. Another first for me! Cheers, Martin
Howard Lewis | 03/02/2021 11:28:53 |
6024 forum posts 14 photos | use plenty of a suitable lubricant and you sgould be OK. Go for it Howard |
Andrew Johnston | 03/02/2021 11:30:53 |
![]() 6575 forum posts 701 photos | Posted by Martin King 2 on 03/02/2021 11:24:58:
i will try a hexagon die from Tracy tools then try to power thread some at low rpm........ Solid hexagon dienuts are intended to clean up existing threads, not cut new ones. Personally I no longer buy from Tracy Tools. Instead I'd look a for a quality make NOS die on Ebay. Andrew |
Martin King 2 | 03/02/2021 19:53:01 |
984 forum posts 439 photos | Andrew, Thanks for that info, will do. Martin |
John Reese | 06/02/2021 23:53:41 |
![]() 1035 forum posts | I am surprised no one suggested single pointing the thread using a follow rest for support. |
