Dr_GMJN | 31/01/2021 11:43:02 |
![]() 996 forum posts | All, I thought I'd share this telescope mount I've been building. Every year for about the past 5 years I’ve been saying “I’ll get this done for February and get some use out of it in the clear winter nights” At last it’s done, now for the clear nights... |
Dr_GMJN | 31/01/2021 11:43:15 |
![]() 996 forum posts | I previously requested ideas for the azimuth bearing over on the "General" forum, which I've incorporated into the design. I used a 390mm diameter ball-raced lazy Susan slew bearing. I got it from Simply Bearings who do a range of them. I assumed it would cost a fortune, but it was about £38. The white outline was a bit of a mistake during routing the base. It's filled and flatted, and has no effect on function. I've not used it yet - too cloudy! I really hope it works ok in 'real world' conditions. Thanks for looking! |
Roderick Jenkins | 31/01/2021 12:26:14 |
![]() 2064 forum posts 555 photos | Very nice May your skies be clear. Rod |
Dr_GMJN | 31/01/2021 14:18:37 |
![]() 996 forum posts | Posted by Roderick Jenkins on 31/01/2021 12:26:14:
Thanks Rod! |
old mart | 31/01/2021 17:41:30 |
2829 forum posts 178 photos | Clever design, your printer must be pretty large. Sealing the MDF is very important to retain its dimensions. What decides the pivot point, is it the COG of the tube assy? Edited By old mart on 31/01/2021 17:44:47 |
Dr_GMJN | 31/01/2021 19:33:31 |
![]() 996 forum posts | Posted by old mart on 31/01/2021 17:41:30:
You slide the tube in and out of the cage until it’s balanced on the horizontal pivot axis (depends on what equipment is in and around the eyepiece), then lock the tube ring. The tube ring stops the tube falling through. The vertical rotation axis is directly under the centre of the horizontal pivot axis. My printer is the usual size for a home machine - bed is about 250mm square IIRC. The MDF has 3 coats of varnish, so should be well sealed for what it is. It’s stored in the house, and will be outside only for the duration of an observing session. Cheers! |
