Hollowpoint | 25/01/2021 13:43:51 |
402 forum posts 51 photos | Does anyone know a way to remove that very light, brown surface discolouration you tend to get on machine tools? You know the kind im talking about, it looks like rust (probably is) but its perfectly smooth to the touch and steel wool doesn't usually work on it. Sandpaper does work but im hoping for a non abrasive solution?
Anyone? |
Alan Donovan | 25/01/2021 14:14:23 |
34 forum posts 24 photos | Hi there. If I have something that is ‘rusty / discoloured’ that I want to clean up, but not remove metal in the process. I use a worn out ‘green scouring cloth’ (the type used to remove burnt on food from cookware) lubricated with oil and rub the affected area. If it is a stubborn stain I may use a new scourer, but still lubricate it with oil. I frequently remove the ‘dirty oil’ and re-oil as I feel the removed rust is probably quite abrasive anyway. It seems to work but does require some ‘elbow grease’. Just one suggestion - I am sure other methods will be along in a few minutes. Best regards. Alan. |
roy entwistle | 25/01/2021 15:04:24 |
1318 forum posts | Steel wool or worn emery cloth with oil Edited By roy entwistle on 25/01/2021 15:05:12 |
Brian H | 25/01/2021 15:08:29 |
![]() 2038 forum posts 111 photos | I can recommend Frost Rust Remover. I had a problem the other year when I silver soldered a boiler in the workshop and all steel items developed a brown film on the upper surfaces. I tried some of the frost rust remover and it quickly removed the film but it needed a light polish to make it bright again. It then needs a wash in water followed immediately by dewatering fluid such as WD40. I have no connection other than as a very satisfied customer. Brian Edited By Brian H on 25/01/2021 15:09:42 |
Mark Rand | 25/01/2021 15:21:43 |
961 forum posts 8 photos | It can be oxidised oil. If it is, a strongly alkaline cleaner may remove it. |
mgnbuk | 25/01/2021 15:46:25 |
929 forum posts 65 photos | We used something like Metal Brite at my last employment for cleaning & brightening machined surfaces on rebuilt machine tools. I'm not certain it was this exact product, but recall the one we used contained phosphoric acid which the SDS for Metal Brite shows too. It was very effective - planed cast iron surfaces came up like freshly machined. The only references I can find are for 25 litre drums, though. Otherwise, on a slightly abrasive note, brick red "extra fine" Scotchbrite pads used with WD 40 (or similar) work well with minimal surface scratching. For stubborn coolant & tramp oil residues, I use DEB Janitol Rapide water based caustic cleaner diluted about 4:1 with water. Apply with a trigger action spay bottle, leave to stand for a few minutes & wipe off with paper towels. Repeat as required on stubborn stains. Being caustic, it takes the shine off painted surfaces & should be used with eye protection & waterproof gloves. Nigel B. |
old mart | 25/01/2021 15:47:01 |
2686 forum posts 176 photos | A solvent based degreaser followed by oiled steel wool would be all I would use, no abrasives. |
Mick B1 | 25/01/2021 17:13:27 |
1839 forum posts 92 photos | Scotchbrite or equivalent green scourer - available in rolls from B&Q etc. - with WD 40. In many or most cases, unless the rust really has a hold, you can get back to a bright finish with no detectable metal removal. Happens most winters to the chuck, milling vice, cross- and compound slide top surfaces on my Warco WM250V, but after half-an-hour or so's work you'd never think it'd been there. I think I'd have to live another 2- or 300 years for it to cause any wear to worry about. Edited By Mick B1 on 25/01/2021 17:16:47 |
Breva | 25/01/2021 17:36:58 |
![]() 78 forum posts 7 photos | Not directly what you have asked about but related, I find Lanolin a very effective rust inhibitor during the winter months. IIRC a jar costs about £6 on the Bay and it will last you a lifetime. It is better for tools not in regular use as it is a bit greasy, but a very thin coat is all it takes. It is easily removed and as sold has a pleasant smell. Search for :Dax 100% PURE LANOLIN Super Hair Conditioner |
Mike Poole | 25/01/2021 18:15:35 |
![]() Moderator 2893 forum posts 68 photos | Removing the brown finish will restart the battle to keep the bright finish. The brown patina tends to be stable whereas a bright finish will immediately want to return to the brown one. Mike |
Tim Stevens | 25/01/2021 18:25:45 |
![]() 1374 forum posts | In the sporting gun world (UK version) a gun which is nicely browned is regarded as 'just right'. No, not a kalashnikov, nothing a Trump wally might flaunt, but a nice black-powder percussion cap twelve bore, of course. Cheers, Tim |
Hollowpoint | 25/01/2021 19:46:47 |
402 forum posts 51 photos | Some interesting food for thought. Might have to give the rust remover a go. Some of my tooling has a nice engine turned type finish, obviously abrasives would spoil the finish. |
old mart | 25/01/2021 20:12:08 |
2686 forum posts 176 photos | Lanolin is used on the Lockheed Hercules C130J propellor hubs. The hubs are sulphuric anodised, but not subsequently painted, but coated in lanolin. Paint might conceal underlying deterioration, and the lanolin gives protection for the hub under the cowling, but can be easily be washed off with solvents for close inspection. Breva's post reminded me of this. Edited By old mart on 25/01/2021 20:13:01 |
Matt Harrington | 25/01/2021 20:16:56 |
![]() 155 forum posts 7 photos | Lanolin - I was once given a bottle of the stuff and IIRC it was mixed with white spirit. It was used by RR to preserve some parts of an RR jet engine (cant remember what) . I used to use it on my motor bike spokes & rims during winter months. It was brilliant! Matt |
Pete. | 25/01/2021 20:22:58 |
![]() 409 forum posts 57 photos | Posted by Tim Stevens on 25/01/2021 18:25:45:
In the sporting gun world (UK version) a gun which is nicely browned is regarded as 'just right'. No, not a kalashnikov, nothing a Trump wally might flaunt, but a nice black-powder percussion cap twelve bore, of course. Cheers, Tim Those Trump wallies are more likely to carry AR15's, a rifle that uses an aluminium alloy receiver and hand guard, most likely modern protection methods on the barrel like cerakote etc, unlikely to have any corrosion issues, this being an engineering forum, might as well make your snide remarks accurate and relevant. |
Paul Lousick | 25/01/2021 22:23:44 |
1692 forum posts 625 photos | Lanolin is now available in spray cans by the makers of WD-40 at the hardware store. |
Brian H | 25/01/2021 22:28:41 |
![]() 2038 forum posts 111 photos | Lanolin was always used by the MoD to preserve weapons. MANY years ago n the Air Cadets we were supplied with some deactivated Lee Enfield Mk3s which were smothered in lanolin. It took a lot of removing. Brian |
Phil P | 25/01/2021 22:59:00 |
749 forum posts 181 photos | Posted by Paul Lousick on 25/01/2021 22:23:44:
Lanolin is now available in spray cans by the makers of WD-40 at the hardware store. Paul. I just googled it, looks like it is not available in the UK........Pity Phil
Nigel Graham 2 | 25/01/2021 23:35:44 |
1071 forum posts 16 photos | Lanolin dissolved in white-spirits is an old but effective preservative for wire-rope, especially when such ropes had sisal cores. The rope is soaked in the solution then hung up to drain and dry. Worth considering for trailer-winches, and for winding-ropes on miniature traction-engines & ploughing-engines. As far as I know lanolin is not only tenacious and long-lasting, but also doesn't carry the skin-health risks inherent with mineral oils.
' I tried to investigate gun-blue for protecting the bare steel parts on the tool-&-cutter grinder I am building. My security software blocked my attempts, and so far I have no reply from a major country-sports stockist that lists the stuff but not the weapons, making me wonder if the system stopped its transmission! Yes I did try "ours" first but it looks as if only Chronos stocks metal-blacking, and then warns it gives no real protection against rusting. |
Danny M2Z | 26/01/2021 05:55:23 |
![]() 936 forum posts 1 photos | I have found that Inox MX3 is quite a useful lubricant and metal protector for workshop use. It is lanolin based. More info here Inox and Lanox engineering uses * danny * |
