Turbine Guy | 21/01/2021 15:27:07 |
311 forum posts 172 photos | I'm trying to find a place to purchase a collet holder (chuck) for a Unimat 3. I have found a few sources for complete sets of collets with a holder. I have not been able to find a source that sells the collet holder only. I appreciate any help, Byron |
br | 21/01/2021 15:34:26 |
461 forum posts 3 photos | I have one and a full set of collets - boxed never used. Never will be and arthritis in my hands may mean an end to lathe activities soon. Seen them on ebay from time to time If you draw a blank and are desperately stuck in a while, send me a PM. br |
Emgee | 21/01/2021 15:35:03 |
1929 forum posts 243 photos | Byron, chuck for what type and size of collet ? Emgee |
br | 21/01/2021 15:44:10 |
461 forum posts 3 photos | My unimat collet chuck is Emco ref no 150 290 !4mm thread Collets are type E16 br |
Turbine Guy | 21/01/2021 17:01:49 |
311 forum posts 172 photos | Posted by Emgee on 21/01/2021 15:35:03:
Byron, chuck for what type and size of collet ? Emgee I can get collets in size ER-16, ER-20, or ER-25. The largest collet I would probably need is 5/8" (16mm). |
Turbine Guy | 21/01/2021 17:09:39 |
311 forum posts 172 photos | Posted by br on 21/01/2021 15:44:10:
My unimat collet chuck is Emco ref no 150 290 !4mm thread Collets are type E16 br Your set would be perfect for my Unimat 3. I was hoping to get original EMCO items since all my lathe and drill attachment accessories were made my EMCO. I live in the USA and if you are willing to ship them to me please PM me with the price you would like to sell them for. Look forward to hearing from you, Byron |
Turbine Guy | 21/01/2021 17:17:34 |
311 forum posts 172 photos | I just checked my source for collets and found out I would need the ER-25 collets to get up to the maximum size I would like to use. This would be my preferred size. |
br | 21/01/2021 17:29:07 |
461 forum posts 3 photos | 363230894047 This would suit you better than my set which are not large enough for your needs. On ebay UK chuck and 15 collets £150 BUY IT NOW Shipping is £15.90p Happy to buy and ship if it helps. br
Edited By br on 21/01/2021 17:30:04 Edited By br on 21/01/2021 17:34:30 |
Emgee | 21/01/2021 17:42:19 |
1929 forum posts 243 photos | Emco did/do an ER25 chuck that screws direct to the spindle on the Emco 5 milling drilling accessory fitted to some 5 cnc lathes and 5 manual lathes. You don't say if the thread you need is M14x1 or M14x1.5 ? Emgee
Turbine Guy | 21/01/2021 17:50:46 |
311 forum posts 172 photos | Posted by Emgee on 21/01/2021 17:42:19:
The Unimat 3 uses M14x1 thread. |
Emgee | 21/01/2021 18:03:07 |
1929 forum posts 243 photos | Turbine Guy Original EMCO, item no. 200 050, Fixing M14x1 as in picture, collet recessed into the body so takes up less height from your set-up if milling/drilling, also less overhang from the spindle. From my own experience using the 5 milling attachment I wouldn't advise using a 16mm milling cutter because the unit is quite low power motor, best results will be obtained using smaller diameters but then the spindle speeds may be a bit low, so feedrate will have to be reduced to prevent stalling. Used with correct size of cutter and consideration to the points raised excellent work can be accomplished. Emgee |
Turbine Guy | 21/01/2021 19:23:41 |
311 forum posts 172 photos | Hi Emgee, The collet chuck you showed the picture of (EMCO 200 050) would be perfect for my needs. If anyone knows where I could obtain one of these (new or used) I would appreciate it. As br mentioned in a preceding post, the ER-25 collet chuck is available as a complete set with collets on ebay. I would prefer to get just the chuck if possible. Thanks for the help, Byron Edited By Turbine Guy on 21/01/2021 19:24:57 |
clivel | 21/01/2021 19:54:27 |
311 forum posts 13 photos | I purchased the Emco 200 250 collet chuck for my Unimat from Pro Machine Tools a few years ago and have been very happy with it. Clive
Turbine Guy | 21/01/2021 20:00:16 |
311 forum posts 172 photos | After looking at the cost of buying the collets individually, I realize what a bargain the ER-25 collet chuck with the set of collets sold on ebay is. I went ahead and ordered the set mentioned by br. Thank you all for your help, Byron |
br | 21/01/2021 20:10:56 |
461 forum posts 3 photos | Good to know you are sorted. It looked to be the best value for money. br Edited By br on 21/01/2021 20:15:32 |
Jouke van der Veen | 21/01/2021 20:33:49 |
78 forum posts 8 photos | Emco C5 spare parts etc. can also be bought at Emco Holz & Hobby in Austria. |
Turbine Guy | 21/01/2021 23:17:48 |
311 forum posts 172 photos | Posted by Jouke van der Veen on 21/01/2021 20:33:49:
Emco C5 spare parts etc. can also be bought at Emco Holz & Hobby in Austria. Thanks for the source. They appear to sell the collet holder I thought would be ideal for me as shown in Holz & Hobby This source could be useful for other EMCO parts. |
Jouke van der Veen | 22/01/2021 11:49:58 |
78 forum posts 8 photos | I have the strong feeling that E H&H also act as a distributor to sellers in Western Europa but I am not sure. |
Turbine Guy | 17/02/2021 13:08:57 |
311 forum posts 172 photos | I received the collet set that I ordered on Ebay. The runout was very bad so I looked for help to see if anyone else had this problem and what they did to fix it. I found the following thread Collet Runout that gave suggestions for correcting problems with collet holders. After trying some of the suggestions, I came to the conclusion that fixing the collet chuck is beyond my skill and equipment capabilities. After seeing the size of the ER-25 collet set, I agree with Emgee that an ER-16 collet set would be more appropriate for the Unimat 3. br, I sent you a PM that I am interested in purchasing the E16 collet set if it is still available. Thanks for your help, Byron Edited By Turbine Guy on 17/02/2021 13:12:41 |
John Haine | 17/02/2021 13:20:13 |
3661 forum posts 206 photos | Did you buy the collet set from a seller apparently in Wales (Mountain Ash)? I bought an ER16 one from him, runout was awful and the small nut would not take smaller collets. I returned it as not fit for purpose and got a refund. |
