Peter Simpson 1 | 19/01/2021 16:27:58 |
![]() 194 forum posts 9 photos | I purchased a couple of 7/16" x 30 tooth wheels, I want fit them to an 8 BA spindle. The problem is the hole in the centre of the wheel 0,090" which is too big for 8 BA, the easy option would be to drill the centre hole out and fit a brass bush then drill and tap it 8 BA. The problem is the wheels appears to be case hardened and does not want to be drilled. Has anybody come across these wheels ? |
not done it yet | 19/01/2021 20:29:13 |
5609 forum posts 20 photos | Do the wheels need to be hardened? If not, anneal them. Alternatively grind off the case hardening or get a drill/cutter suitable for cutting hardened steel. |
Michael Gilligan | 19/01/2021 20:41:06 |
![]() 17299 forum posts 778 photos | With reasonable care, they could be fixed using a suitable grade of ‘anaerobic retainer’ [ Loctite, PermaBond, etc. ] MichaelG. |
Peter Simpson 1 | 19/01/2021 21:20:39 |
![]() 194 forum posts 9 photos | Tomorrow I make a stepped spindle and press fit the ratchet onto the over size shaft. As the wheel sits in the fork in the actuation arm, gluing would not be practical. |
JasonB | 20/01/2021 06:56:17 |
![]() Moderator 19932 forum posts 2172 photos 1 articles | You could anneal, drill and then reharden. Press or Loctite the bush in once hardened. |
Peter Simpson 1 | 20/01/2021 10:23:19 |
![]() 194 forum posts 9 photos | If the wheels are case hardened would they anneal ? They are a dull grey colour so I assume they are not made of silver steel, machined then hardened. |
Michael Gilligan | 20/01/2021 10:28:48 |
![]() 17299 forum posts 778 photos | Posted by Peter Simpson 1 on 20/01/2021 10:23:19:
If the wheels are case hardened would they anneal ? They are a dull grey colour so I assume they are not made of silver steel, machined then hardened. . I have no way of knowing for sure, but that sounds like they might be sintered ... in which case, I wish you luck. ... could you post a close-up photo ? MichaelG. . Edit: __ I’ve just looked [at a 34 tooth version] on the Reeves website; but it doesn’t help much https://www.ajreeves.com/6592.html Edited By Michael Gilligan on 20/01/2021 10:35:16 |
Peter Simpson 1 | 20/01/2021 10:46:38 |
![]() 194 forum posts 9 photos | Michael I think you may be right with the sintered suggestion. Looks like the spindle will have to be a push fit into the central hole in the wheel. |
Peter Simpson 1 | 20/01/2021 14:23:01 |
One old wheel one new, Neither will allow a drill to enlarge the central hole which is 0.090" I have ordered some 3/32" En1a rod to make a new press fir spindle. |
JasonB | 20/01/2021 14:36:26 |
![]() Moderator 19932 forum posts 2172 photos 1 articles | They are not hard to make from silver steel with a simple single point tool. |
Clive Brown 1 | 20/01/2021 14:43:57 |
612 forum posts 23 photos | Not quite answering the question, but lubricator ratchet wheels are very easy to make from silver steel and some simple tooling. A suitably ground HSS toolbit in the lathe will readily cut the teeth by traversing the saddle. Division can be by means of a change wheel and detent mounted at the LH end of the mandrel, or possibly using the bull wheel on some lathes. After parting off, the wheel is hardened & tempered back slightly. Edit, can't type fast enough! Edited By Clive Brown 1 on 20/01/2021 14:45:41 |
duncan webster | 20/01/2021 16:17:05 |
![]() 3054 forum posts 36 photos | One way clutches are cheap enough, but you won't get one that small |
