The Workshop Progress Thread 2021
JasonB01/01/2021 06:57:50
21318 forum posts
2420 photos
The previous year's posts can be found here
Roderick Jenkins12/01/2021 15:52:03
2122 forum posts
582 photos
Well, here we are, the first entry of 2021:
I've brought my musical instrument making bang up to date (well, middle of the 20th Century anyway). Steel strung guitar, Alpine spruce front, Indian rosewood back and sides and Pau abalone inlay. This is the first time I've installed metal frets on an instrument. I've had 2 goes and still not really happy but I'll see how it settles down, still some action tweaking to do. Sounds quite loud and bassy.
No more woody stuff in the pipeline, its back to engine building. Promise.
Stay well,
Rod
Pete.13/02/2021 23:06:31
625 forum posts
102 photos
I bought and started restoring a huge ratcheting arbor press about a week before the world went into meltdown, unfortunately it has sat there untouched since, I decided to make a start on finishing it earlier, just finished welding up a subframe with wheels that sits inside the base, with adjustable feet under the original bolt holes, it weighs I'd guess in the region of 250kg, hopefully should have it finished within the next week.
R.press
R.press
Stuart Bridger14/02/2021 09:13:31
528 forum posts
29 photos
UPT nominally completed.
Just need to make up custom washers so the Kipp handles sit nicer.
GoCreate21/02/2021 19:37:02
386 forum posts
119 photos
Just finished my 2" Baby Bench Vice build, Finally a nice little quality bench vice. I based it loosely upon the 'WILTON' design popular in the USA. An interesting and worthwhile project.
baby vice.jpg.
Nigel
Pete.21/02/2021 19:40:03
625 forum posts
102 photos
That's very nice Nigel, is your surname Walton?
Derek Lane21/02/2021 19:53:58
507 forum posts
95 photos
Posted by tractionengine42 on 21/02/2021 19:37:02:
Nigel
Have been watching the build on this looks a great little vice. Now waiting for the next part
Jim Nic21/02/2021 21:02:48
355 forum posts
200 photos
For the last couple of months I've used my workshop time to set about my version of Neil Wyatt's Norden engine design. I say my version because firstly the castings that Neil used seem to be no longer available and secondly I like to work in metric measurements and the drawings I have are in imperial units. Following advice from Jason B some time ago converting from imperial to metric was straightforward by taking 1/32" as 1mm.
The original:
My engine will thus be slightly larger than the original and made mainly from barstock; the exception being a cast flywheel.
First off was the base, a simple aluminium sheet with mounting pads Araldited in place:
Then the frame. The trickiest bit for me, silver soldering the angled legs to the table was always going to be a challenge but it turned out OK. Still to add the trim strip around the inner faces of the legs:
Then the crankshaft bearings:
Finally for now a family shot of progresss to date:
Next job will be the cylinder.
Jim
JasonB22/02/2021 06:57:52
21318 forum posts
2420 photos
Off to a good start Jim.
Anthony Knights05/03/2021 17:22:19
556 forum posts
233 photos
I have now finished making enough components of the Stewart Hart beam engine to be able to fix them together to see what it looks like. (Impatient person that I am). Made a rough looking flywheel from MDF just to get some idea of dimensions when it came to making the plinth. There is still quite a bit to do, but I've already got a little guy to operate it when it's finished.
Jim Nic05/03/2021 19:31:55
355 forum posts
200 photos
A good looking model Anthony.
How are you going to make the flywheel?
Jim
Anthony Knights06/03/2021 09:05:46
556 forum posts
233 photos
Hi there Jim. For the flywheel, I can either buy a suitable slice of cast iron or steel and machine from scratch, or buy a laser cut blank. I have not decided which to do yet.
mechman4806/03/2021 12:47:30
2933 forum posts
460 photos
Hi Jim
What scale is your figure?
George.
duncan webster06/03/2021 14:32:46
3457 forum posts
63 photos
This was supposed to be made from a slice of thick wall pipe, but the chap who had offered to get a couple of rashers couldn't find any, so he machined it from solid bar. Easy when you have big industrial type machines. All held together with loctite. The idea was to grip the boss in the 4 jaw, set the rim running true, bore and sleeve, but it's come out really well. Held on rotary table to set up for loctite. I've made other changes to Stuart's design, not because I think there's anything wrong with it, I just like to do my own thing. It has a slide valve for starters, couldn't bring myself to have a piston valve beam engine.
And where did you get the little man from, adds a bit of charm I think
Edited By duncan webster on 06/03/2021 14:33:35
Jim Nic06/03/2021 15:39:51
355 forum posts
200 photos
I make flywheels in a similar way to Duncan's it appears.
Start with the bits:
Initial machine and assemble:
Loctite it all together and finish machine:
Add some car body filler fillets, paint and display:
I have made several like this varying from 70 to 170mm diameter. The rims are steel from M Machine, the spokes silver steel and the hubs mild steel. The ones shown here are 95mm dia, 15mm wide and the spokes are 6mm dia.
Jim
Edited By Jim Nic on 06/03/2021 15:41:01
Anthony Knights07/03/2021 10:01:57
556 forum posts
233 photos
I have also made several changes. The cylinder and steam chest are made from cast iron rather than aluminium, purely because that is the material I had to hand. The vertical beam was machined from solid because I didn't fancy all the fiddlely soldering.
The figure was obtained from a British company called "Farol" which I got to via Amazon (although it was made in Germany). Searched the internet with " 1/16th scale workmen figures" and this was one of the hits. He is a garage mechanic and came with a toolbox, a trolley jack and a pair of axle stands. I think it looks about right scale wise.
I have still got quite a bit to do. Bushes for main axle, steam chest valve and the regulator assembly. I also need to make some studs for the steam chest as the 2mm screws I am using are barely long enough and have pozi heads. At least, its now warm enough to get some more workshop time, so I'll report back when I've made further progress.
Regards Anthony
JasonB07/03/2021 18:44:45
21318 forum posts
2420 photos
I've been making good progress with the Stuart Victoria and decided I had enough parts to see what it looks like with them put together
mechman4807/03/2021 18:55:48
2933 forum posts
460 photos
Made a start on my next project; Scotch yoke engine designed by Bob Middleton..
George.
Martyn Edwards 107/03/2021 19:16:13
24 forum posts
59 photos
Spent a few hours machining and putting together one one of the Cringle vertical boilers today.
JasonB14/03/2021 18:15:12
21318 forum posts
2420 photos
Work continues on the Stuart Victoria. I decided I did not want to raise the engine up on a plinth which means the supplied outrigger bearing base is too tall so drew up a new one in Alibre and got the KX-3 to spit it out, quite pleased with the finish which will be good enough to paint straight onto. All the vertical faces have a 2degree draft angle to make it look more like a casting which meant the cutter went round the contour lines moving outwards slightly with each 0.25mm step down. Running at 5000rpm and a feed of 600mm/min it took about 25mins to do the finish contour cut.
I was not keen on the supplied bearings which had already been made to drawing as the hex heads overhung the sides so make up a couple of new bearing blocks and separate bearings.
Most time this week has been spent on the valve gear, eccentric, etc which is now all but done
Edited By JasonB on 14/03/2021 18:15:49
Dreweatts
walker midge
JD Metals
rapid Direct
