TIG is harder than it looks
Ian McVickers30/12/2020 18:40:26
195 forum posts
91 photos
While I`m decent at MIG and MMA welding i`m definately struggling with TIG. I used to be good at gas welding a rather long time ago so I thought this would have been easier to pick up but its proving to be a bit harder.
This was 10mm thick mild steel welded to 5mm thick 50mm box section.
Needs more practice me thinks. I also had a go at aluminium but that was a complete disaster.
Jeff Dayman30/12/2020 18:59:44
2058 forum posts
45 photos
Doesn't look all that bad to me Ian, at least it looks structurally secure. Bit too much heat maybe, and a bit of wandering off the line. A lick with the angle grinder and a dose of paint and you're away.
Anyway, question - are you running the TIG machine continuous or in pulsed mode? (assuming your TIG set has pulsed mode) Pulsed mode gives the opportunity of a half second or so "off time" to get the tip repositioned perfectly for the next arc / rod melt cycle. When you see those perfect "row of dimes" welds by the pro's, they are often done with pulsed mode. I've had good success with it using a friend's professional Miller TIG set. Just food for thought.
Chris Evans 630/12/2020 19:02:41
1863 forum posts
I learnt to gas weld 50+ years ago and got to a stage where I was happy enough with the results. I have had a dabble at TIG and find it difficult.
Dave Halford30/12/2020 19:03:52
1282 forum posts
12 photos
A foot switch is said to help a lot.
Ian McVickers30/12/2020 19:08:44
195 forum posts
91 photos
Jeff the tube was toasty hot by the time I finished it so probably right when you say too much heat. I did wander off the line a bit because I couldnt see it clearly. My adjustable shield doesnt really go low enough to clearly see the gap between the parts so it was difficult to follow. The TIG does have adjustable pulse frequency and pulse duty so I guess I can practice with them next time to see if I can improve.
Ian McVickers30/12/2020 19:12:07
195 forum posts
91 photos
Dave a foot switch is on the shopping list but a few other items are in front of it.
John ATTLEE30/12/2020 19:32:53
10 forum posts
Dave,
I recently bought a decent Miller inverter TIG welder STH 160. It is a light but high quality unit.
I found that even a few amps change in current can make a difference. I found that electrically it is very good.
Unfortunately the control system was obviously designed by an electronic engineer who wants to make everything as small as possible with as few controls as possible. This has meant that I still cannot use (program) the pulse setting. I need an eleven year old to show me how to set it up! What we want is big fat switches.
I am experiencing a problems in avoiding pin holes even in a good quality run. Bit of a problem as my next job is to make a petrol tank for a run up rig for the 27 litre Meteor tank engine.
TIG welders are expensive but do a fabulous job in my opinion.
noel shelley30/12/2020 19:40:44
356 forum posts
9 photos
Hi, Using an EW9 shade might help you ! But why use tig on such thick material, it's the wrong process for this work.. Far to much tig I see looks beautiful but has poor penetration and therefore little mechanical strength. Great for thin tube or sheet in stainless or alli. Your job looks sound, just needs tidy'ing. If you can gas weld then it's likely setting of the machine and the right gas. Good Luck. Noel.
Phil Whitley30/12/2020 20:02:48
1303 forum posts
147 photos
it is difficult at first, but it takes practice, like all welding, and it gets easier. It pays to adjust your welding helmet till you can see as clearly as is absolutely possible, because you need to have a clear view of the puddle, and also to follow the gap you are welding (something that I fail on), my tig is an old school transformer, so no foot pedal, but it is ac/dc and was only £150. It pays to rest your wrists on something, sit down at the job, and concentrate on the puddle. Absolute cleanliness, even on steel is essential, as is a nice clean pointy tungsten. With TIG, you need to be very picky, you cant just point and shoot like you can with mig, and you cant burn your way through dirt, rust and grease like you can with gas and stick
Nicholas Wheeler 130/12/2020 21:01:20
501 forum posts
28 photos
Posted by noel shelley on 30/12/2020 19:40:44:
I'm not a TIG expert by any means, but surely welding two materials that are of very different thickness is one of the reasons for using TIG rather than any other process?
Having done some gas welding I found the action of feeding TIG filler rod to be the same, but holding a lighter, shorter torch with on the fly adjustments was much easier. On steel at least.
Aluminium is another matter, as it's very difficult to tell the whether it's hot enough to weld, or about to melt on the floor. You have to speed up as you work along a seam and I don't get enough practice to do this well.
I do most of my workshop welding with the TIG because it's at the end of the bench, whereas getting the MIG out to do it is more of a faff than is justified. But if I'm honest, the TIG is an extravagance that was bought using an unexpected windfall.
Colin Heseltine30/12/2020 21:18:51
559 forum posts
213 photos
I am also trying to learn to use a TIG welder. I started off using the MIG auto dimming helmet but was struggling to see what I was doing. Brought a Parweld True Colour vizor and this transforms things. I can now see the weld puddle. The other thing I did was by a x2 cheat lens to fit in the vizor. This increases the size of what you are looking at significantly. I wish I had bought the x2.5 now.
Trouble is I have not picked the welder up for a couple of months. I had intended to try and use for a few hours every week. I want eventually to be able to TIG ali.
Colin
Pete White31/12/2020 08:47:21
137 forum posts
16 photos
Some interesting points there. Having done quite a bit of gas welding I have been told and thought I could move on quickly, often wrong, ask the wife lol.
There is a place quite close, Hinkley Leics who do 4 hours one to one tig tuition for 80 pounds, was going to go but got talked out of it then and now again Covid!!
Both my Migs have packed up so thought tig would "fill the gap"? nicely. No gas anymore relying on the big oil cooled Oxford and a mates mig when pushed?
Do we all watch to much u tube where the bar gets set high?
Pete
Kiwi Bloke31/12/2020 09:19:36
508 forum posts
Posted by Ian McVickers on 30/12/2020 19:08:44:
It may seem paradoxical, but excessive heat build-up in the body of the work is often the result of using too little current. More current, faster traverse and a helping of reckless abandon may prove better. A foot control makes life so much easier - but you do have to control an extra limb... Also, use a gas lens to economise on gas and get a better view of the electrode, which can stick out more.
Nicholas Wheeler 131/12/2020 09:42:18
501 forum posts
28 photos
Posted by Pete White on 31/12/2020 08:47:21:
You'll spend more than £80 in consumables with poorer results than the tuition.
Chris Evans 631/12/2020 10:44:56
1863 forum posts
Once Covid is under control I will have a search for the Hinkley training facility. I am only about 25/30 miles away and would love to improve.
Pete White31/12/2020 11:30:52
137 forum posts
16 photos
Found it they do lots of thing engineering , I had a chat with the welding instructor, he said he would tailor the time to whatever was requested.
Noting like someone telling you how to do it and then watching and saying where you are going wrong. I seem to remember they are somehow connected to R- Tech, nice machines and you get your fee back if you buy an expensive model.
Joseph Noci 131/12/2020 11:45:53
851 forum posts
1051 photos
Posted by Kiwi Bloke on 31/12/2020 09:19:36:
Very True!
Three important things in TIG welding - ( and a fourth..)
  • Correct current setting - Experiment on similar thickness materials to get it right first.
Don't let the test pieces get too hot while 'testing' as that will mask the correct current setting -
Body weld Position.
Esp when learning, seat yourself at the weld table, use arm rests, be comfortable, rest the weld hand lower wrist on a block of wood placing the tungsten at a comfortable height over the weld line - mock-swipe the weld line so when welding with helmet on visibility you 'naturally' follow the line. Important as it helps you get a feel for the flow of the tungsten over the material - A poor hand position may move in an arc, away from the line, or may swoop the tungsten up or down, dipping into the puddle or increasing the arc length and current, making holes.
  • Visibility.
For beginners, use a decent auto-darkening helmet. If you can't see the weld line in non-dark mode or see the line right ahead of the arc in darkened mode, its set to dark. To start, keep the weld line in view, with the weld pool approaching your view - when experienced you can TIG away from your view, with a hidden weld line - needed in some workpiece orientations..
It is imperative that the weld puddle is CLEARLY visible - often maltreatment of the helmet results in lots of fine scratches on the lens cover - Don't grab the nearest rag, or tissue/towel and with vigour clean the lens with a circular wipe pattern! Now when the arc strikes, the view is lost in lots of little starburst patterns, with a very bright hazy area at the puddle....
Magnification of view is a great aid to steadying the hand - try it - with normal eye view, get up close to a human hair and try cut the end off with a scalpel - note the hand shakes, etc. Now do that under a microscope - suddenly the knife tip is rock steady...
So if you are jittering the tungsten around the puddle, and digging the weld wire everywhere else, get close up, put on some 2 or 3X magnifiers and get to maybe 10 or 15cm of the weld.
  • A 4th item is relevant when welding aluminium -
Aluminium requires AC current to ensure proper surface oxide removal during welding.
The joint MUST BE a very good fit - small gaps can be closed, - 0.2 - 0.4mm not more, and NOT at the start of the weld point! If you try the latter, the two halves of the joint will melt and peel away from each other - if you are good you can quickly bridge the gap with melt from the feed wire - if not, you ruin the part.
Aluminium requires LOTS more current due to its thermal performance. Starting cold, can require up to 2 to 3x the current needed to do mild steel of the same. And its the start of the Ali weld job that normally messes you up - the heat just conducts away to fast, so you up the current, and halfway through the job start melting big holes in the job as the job has heated up a lot.
Heat is your friend in this - pre-heat the Ali job first- Gas torch, oven, whatever -
To start, the parts must be VERY clean around the weld area - use a stainless steel wire brush ( one reserved ONLY for this - don't use it on the Morris's brakes and wash in petrol and use it on your weld..).Then wipe down with a damp ( NOT wet) CLEAN cloth with a solvent like acetone. Now, don't touch with bare fingers, or with the dirty weld gloves, at least not on the weld areas!
Now, if going to pre- heat - first mock-fitup and get the position right, get your weld position right, weld flow direction sorted, etc. The put the bits in the oven, or heat in place with a torch, etc - the old trick of some soap on a free spot, turns black(ish) when hot enough - works ok. THEN when hot, a quick wire brush over the weld area to get rid of the new oxide helped along by the heat, and you are ready to go.
When you weld, if you dip into the puddle, STOP - don't try to fudge your way along - it will only get worse. Re-grind that tungsten, ball it, CLEAN the weld with the brush, or if bad, a file ( NOT USED ON STEEL/BRASS etc!) and start again.
This may all seem onerous, but welding Ali is quite unforgiving. Once you get the knack you will quickly learn what you can forego in all the above processes and the weld is easy..
TIG is not hard - like everything we do, just needs a little practice and some common sense - and a bit of study!
Joe
Edited By Joseph Noci 1 on 31/12/2020 11:48:31
noel shelley31/12/2020 13:33:45
356 forum posts
9 photos
Spot on Joe, there is much wisdom in this post.
What is often not known is that aluminium when cut, ground or machined ALMOST INSTANTLY forms an insoluable oxide in air, it is this oxide film that makes aluminium much use at all, as chemically it is a very reactive metal. So if it is not cleaned IMMEDIATLEY before welding trouble can be expected.
Since the consequences can be catastrophic I will repeat the following !!! NEVER grind aluminium AND iron on the same machine without cleaning all dust out of the guard BEFORE and AFTER use. You will create a chemical fire at some 3000*C commercially known as the THERMIT process. ME carried a report on an accident of this sort many years ago, but with many newcomers to the hobby and this not being an obvious hazard I feel it should be raised regularly. Keep safe Noel
noel shelley31/12/2020 13:35:11
356 forum posts
9 photos
SORRY FOLKS ! THINGS RUNNING SLOW THOUGHT IT HAD NOT BEEN SENT.
Edited By noel shelley on 31/12/2020 13:37:04
Andy_G31/12/2020 17:49:36
111 forum posts
Posted by Ian McVickers on 30/12/2020 18:40:26:
TIG is harder than it looks.
Can't think what you mean...wink
I'll get there... laugh
JD Metals
