Vintage lathe cross slide adjustment
Arthur Moore27/12/2020 16:28:30
17 forum posts
13 photos
Hello everyone,
I have a very ancient lathe which I bought at a model railway show for £10 and just had to add a motor and drive pulley.
It seems to be working well, but there is an enormous amount of play in the Y feed - approx 1.4mm.
Does anyone know how to take out at least some of this slack? I guessed I need to hold the nut and that would enable me to unwind the handle. Then either tighten the nut, or add washers as shims and refit the handle. Is that correct?
If so I have another problem. The nut is about 2.3mm thick and 11.4mm across flats (29/64"?) - so what spanner would fit and where do you buy a spanner that thin? Nothing thicker will go in the gap between the handle and the cross slide.
The X feed has almost no slack and feels comfortable to use, but does not have an indicator wheel
Can you buy these wheels? It seems to be 16 turns of the handle to the inch, so 0.0625 per turn.
I guess fitting would be similar to what I have to do on the Y feed?
N.B. I am managing with the lathe as is, provided I always feeding from the same direction, which I believe you should do anyway. But I have to keep on stopping the lathe to measure diameters and then feed back in. There then seems to be the risk of an error of up to 0.2mm.
Thanks for any help and suggestions
Arthur (beginner)
Roger Best27/12/2020 16:56:57
369 forum posts
56 photos
A lot of questions but its still a bargain.
You probably have a worn lead screw nut, so it will need some stripping to tell.
What speed is your motor, these old dears don't have the bearings for high speed?
Jeff Dayman27/12/2020 17:00:06
2221 forum posts
47 photos
Hi Arthur,
You will probably find the nut is badly worn in the cross slide. You can either make a new one or slit the old one and add a screw to make the nut sort of "pinch" the thread to reduce the backlash. However you may find the screw is also worn. New screw can be made or the old one chased (threads made thinner, removing material just enough to take the thread to a uniform state same size as worn part) and a new nut made.
For a spanner I suggest finding a bit of gauge plate (oil hardening tool steel, ground flat both sides, sold by tool suppliers) and hacksawing / filing out the opening to fit the nut, to make a spanner. It may work fine without hardening if you leave enough "meat" beside the opening. 10" or 250 mm long would probably be fine. Wrap the end in electrical tape for good grip and to protect your hands.
You could also buy a thicker spanner (maybe 12 mm ) at a pound shop or cheap imported tool dealer and grind the sides to fit.
Ady127/12/2020 17:02:25
5065 forum posts
734 photos
For thin spanners you buy the cheap rubbish sets, they can be pretty useful
The handle is probably attached to the shaft with a tapered pin
Once you know what make and model you have it's easier to hunt for info, I don't recognise it but someone in here will know
Arthur Moore27/12/2020 17:31:07
17 forum posts
13 photos
Hello again.
The motor is 950rpm with equal speed on the lathe, or 1.6 step up or step down.
There seems to be no identifying marks on the lathe, so I do not know what make or model. I read there were quite a few generic machines made, especially during WW2, so maybe it is one of those?
To remove the cross slide in order to access the cross slide nut do I just keep unscrewing the lead screw until I can pull it apart?
Thanks, Arthur
old mart27/12/2020 17:59:57
3720 forum posts
233 photos
Remove the two screws in your second picture and you can unscrew the leadscrew. The cross slide will probably slide off. If it stops, then you will have to remove the compound with the toolpost and look for screws holding the cross slide nut and remove them.
ega27/12/2020 18:05:01
2496 forum posts
200 photos
Two sources of thin spanners to use for this kind of thing, or modify for such use, are the old Terrys tappet spanners or those sold for adjusting cycle hub cones, etc
Dave Halford27/12/2020 18:16:22
2006 forum posts
23 photos
That's got 6 speeds as it looks to have a back gear.
As Ady says the handle is normally held on with a pin.
old pushbike spanners are another source of thin tools
Clive Foster27/12/2020 18:38:04
3104 forum posts
107 photos
Sounds like you are running the lathe much too fast.
Typical countershaft speeds for machines of that era would be in the region of 250 to 350 rpm. Generally the spindle oiling arrangements for these simple plain bearing headstock machines aren't up to handling speeds above 600 rpm.
Concerning identification the inverted rack with teeth pointing upwards provided for driving the saddle is very unusual. Coupled with the extremely skimpy saddle apron and left hand operated half nut lever for screw cutting it ought to be possible to identify it. I'm fairly sure that a machine with similar features was added to the list at **LINK** sometime in the last 4 or 5 years. I have a horrible suspicion that machine had its feednut cut directly in the saddle casting. If so it will need to be bored out and new nut fitted. Which may be difficult as space will be limited.
I'd undo the two screws holding the handle assembly to the cross slide then wind the screw out so you can see whats going on and, hopefully discern how it's all put together. On a machine like that expect some creative simplicity to minimise the number of parts. With the screw assembly removed pull off the cross slide too so everything can be examined and given a proper clean.
Bazyle27/12/2020 19:01:31
6295 forum posts
222 photos
It looks like one of the RandA type which were made by and for a number of companies.
Backlash isn't a problem until the nut fails to hold and skips a 'tooth'. Learn to tlive with it for the moment until you get to know more about lathes otherwise you'll get bogged down in a repair cycle and not make anything for months,
A more pressing problem is a countershapft to bring th espeed down, but you can make wooden pulleys and run a shaft in plummer blocks on a wooden frame.
Clive Brown 127/12/2020 20:41:27
807 forum posts
39 photos
11.3-11.4mm a/f is 3/16" Whit. or 1/4" BSF spanner size. The nut won't be too tightly done up. A piece of 3mm mild steel flat, a hacksaw and a file wil soon produce a spanner.
Nicholas Farr28/12/2020 09:27:27
3311 forum posts
1529 photos
Hi Arthur, I agree with Bazyle that it looks very much like the RandA designs or the variants RandA lathes If it is slack between the cross slide and the screw you feel you need to adjust, you will see a noticeable gap between the nut and the cross slide when you wind the handle one way or the other. If there is no noticeable gap, it is likely that the thread that the screw, screws into is worn, which may be an extra problem for you, as with most of these types of models, they have the screw thread cut into the saddle casting and there isn't much metal to bush and re-tap a new thread, the photo below shows a RandA one that I have, to show you what I mean.
Yes, if you continue to wind the cross slide out, it should most likely come off the saddle when the screw comes to the end.
Regards Nick.
Edited By Nicholas Farr on 28/12/2020 09:29:46
Mike Hurley28/12/2020 09:58:34
305 forum posts
87 photos
If you need to remove the handle(s) they are usually held in situ on these older machines with a taper pin. These can be a bit of a sod to get out if they have been fitted flush both ends, and will have corroded a little so won't come out without a fight. Carefully clean off any grot and polish the handles boss, then use a magnifier and you should just be able to detect which is the 'thick' end and which the 'thin'. Get / make a proper sized drift sized for the 'thin' end, support the other side of the boss and tap away.
Dont go too heavy, a little heat may help. If you're too enthusuatic you will sort of 'rivet' over the thin end and it will be almost impossible to get out without drilling.
£10 for a lathe like that Arthur? You're obviously like one of those Lucky people I see on the Antiques roadshow on tv who buys a piece of costume jewellery from a charity shop for 50p and it turns out to be Faberege worth £1000's! If I spent 50p like that I'd usually find out that it was only worth 20p! Happy turning!
Edited By Mike Hurley on 28/12/2020 09:59:57
Arthur Moore28/12/2020 12:12:00
17 forum posts
13 photos
Thanks for all your helpful replies. It is good to know which machine I have. It looks as if someone has fitted a new handle to replace the screw cutting gears.
I think Nick has accurately described the problem <<If it is slack between the cross slide and the screw you feel you need to adjust, you will see a noticeable gap between the nut and the cross slide when you wind the handle one way or the other.>>
So hopefully not the more serious problem of the saddle casting being worn.
I shall either find or make a spanner of the correct size and see what happens if I turn the nut. If that does not help I will probably take Bazyle's advice and leave well alone.
Mike - thanks for your kind comments. I shall know not to bin the lathe if Father Christmas brings me a nice new one! (Only joking - but it is nice to know that these old tools are appreciated). I am lucky enough to have a BCA miller similarly acquired from a friend who just wanted rid of it to make room on his bench.
I really need as high a speed as possible for making very small parts, such as top hat bushes 4mm across in brass or plastic . I am currently running on the lowest main drive setting (600rpm) and obviously only take small cuts. I tried with the back gear and the cut was really rough at such low angular velocity. I only use the lathe intermittently as I keep checking diameters, so do not think I can reduce the speed further, but your comments were very helpful. I shall know not to use her at 1500rpm!
Arthur
Howard Lewis28/12/2020 14:07:26
6013 forum posts
14 photos
For a machine of that vintage, the nuts are very likely to need Whitworth or BSF spanners, not Metric or A/F..
The threads wiil probably be BSW or BSF, with possibly BA for things like gib adjusters.
You need to distinguish between slack and backlash
Backlash is wear between leadscrew and nut, and unless there is provision for reducing backlash, such as split nut, short of making new parts, there is not much that you can do about it. You just learn to take out the backlash as you use the machine. (If you overshoot, back off by more, at least twice, than the backlash and then advance to where you want to be )
If there is play between the handle and the cross slide, if possible the handle can be moved along the Leadscrew to close the gap. If the position of the handle is fixed, by a pin, the space can be filled with one or more washers, or even better, a custom made spacer. Which you can make on the lathe!
For this lathe, if Imperal, as it seems to be with a 16 tpi leadscrew, you need to work in inches and thous, to make life as simple as possible. Try putting on a cut of 0.02 mm using a dial with 125 graduations, let alone 62.5!.
If you want graduated dials, you will have to add them. (Whjch means making, or finding some kind soul in your Model Engineering Club who will make and fit them for you) You certainly won't find any "off the shelf".
A dial for a 16 tp[i leadscrew will need 62.5 graduations to give 0.001" increments. "And a Half"?
Yes! I made one for my Adept Shaper. It looks a bit odd with 62 evenly spaced marks and then a half size gap, but that is what it takes, unless half thou graduations turn you on. For those you would need a larger diameter dial to accommodate the 133 marks with a sensible spacing. The wider the spacing, for a thou, the more accurately you can estimate lesser parts.
Probably essential on a machine with plenty of backlash.
Arthur Moore28/12/2020 17:07:43
17 forum posts
13 photos
Success!! I found an unmarked spanner deep in a box in the garage and that fitted the nut. I held the nut and the handle just unscrewed. A wrench on the shaft held that still while I tightened up the nut to take up the slack, without making it too tight, then I held the nut to re-tighten the handle.
It is now sweet to use with a sensible amount of free movement, but the handle doesn’t flop around any more.
Now all I need to do is to get to grips with thou, when all my drawings are in mm.
I am currently doing some data inputting of accident reports for the National Railway Museum and that has a column in £-s-d and that is nearly as bad to remember - next year is fifty years since it was phased out!
Thanks again for all your help
Arthur
Howard Lewis28/12/2020 17:14:31
6013 forum posts
14 photos
Set your calculator to divide by 25.4, or better still set up a spreadsheet to calculate all the dimensions for you.
Bet that the dimensions will be whole mm, leading to some strange Imperial decimals, unless they have already been translated from the original Imperial to a Metric (possibly the nearest ) dimension.
Good luck
Arthur Moore28/12/2020 17:31:06
17 forum posts
13 photos
Hi Howard,
I think I will pin a crib sheet over the lathe with mm and a separate 0.1mm column as I usually get somewhere near, measure and then take off the last few thou with rather more care.
Arthur
Howard Lewis28/12/2020 17:48:55
6013 forum posts
14 photos
The problem that I envisage is that the original drawings were possibly done in 1/64. Someone converted 64s to nice decimal dimensions.
Then along came someone else who calculated the Metric sizes and probably rounded them up or down to nice round numbers.
End result is likely to be 1/2" becoming 12.7 mm "so lets call it 13 mm". If you are lucky. 3/8" became 9.5 mm
End result something which which is even further away from being a true scale model to become something which may begin to look a little odd and out of scale.
That might even be a benefit. But you may not know until the model is well on the way to completion
Shades of "Send reinforcements, the battalion is going to advance" becoming "Send three and fourpence, the battalion's going a dance"
Meccano Ltd used to make Dinky Toys from actual manufacturer's drawings, but with slight modifications to keep the model looking true to scale! They didn't always succeed.
Arthur Moore28/12/2020 18:10:24
17 forum posts
13 photos
Hi Howard,
Although I used to do 5" live steam I lived abroad for a while with no workshop and now I am back in the UK I model in 7mm / ft (which has always seemed to me a particularly weird scale).
I use a mix of scale drawings (which may not be accurate), scaling from works drawings where available and photos, which show things like rivet details and class variations not apparent from the drawings. I also think you have to try to make it look right - which beading actually shows, what disappears in the paintwork.
At least when they are my own drawings any errors are my fault, but in these small scales you also have to make allowances for issues such as back to back being wrong and material thicknesses and clearances which have to work. Still it all keeps my mind active.
Arthur
Rapid RC
Dreweatts
