Allchin outer wrapper
Dougie Swan20/12/2020 16:06:12
214 forum posts
53 photos
Hi
I bought a pair of half built allchin boilers from the well known site
I have found, surprise surprise, that the outer wrappers are wrong
In a nutshell the stay holes have been drilled in the wrong place
But the wrappers are also too long so the problem could be fixed by cutting each side, removing the excess and re joining the sides back together which would bring everything back into line
This would mean a but joint either side with a strap on the insides
My question is will this be a safe way to fix it
Thanks in advance for any advice
Dougie
Clive Brown 120/12/2020 16:29:13
743 forum posts
37 photos
If properly done, I'd see that as being safe but possible drawbacks are that:-
Depending just how far your boilers are completed, it might be difficult to silver-solder and inspect.
A boiler inspector might consider your boiler as too much modified from the published design. Butt strap joints seem a bit out of fashion nowadays.
Phil H120/12/2020 20:33:57
425 forum posts
46 photos
Doug,
A few snaps might help. It is interesting so well worth taking a few minutes to upload..
Phil H
Dougie Swan21/12/2020 13:44:43
214 forum posts
53 photos
Hi and thanks for the replies
I may have mislabelled the parts I bought as part built as only one of the tubeplates was silver soldered and it was scrap
I hope the pictures I have will upload okay
The wrapper is too long by 3/8 but the previous builder has cut the stay holes before reducing the size
I was thinking of cutting each side, removing the excess and but joining the sides back together
My other option is to buy a new copper sheet which will be in metric 2.5mm and make a new wrapper
Dougie
Clive Brown 121/12/2020 14:19:24
743 forum posts
37 photos
I think I'd make a new wrapper. IIRC, the stay positions are marked off the drilled hornplates so that would be an easier course of action to make an accuratejob.
rapid Direct
JD Metals
walker midge
