New Lathe at Lidl
Ady101/12/2020 10:01:22
4233 forum posts
593 photos
Ketan will be shaking in his boots
VFD etc etc etc
LidlMyfordSuperOne
Edited By Ady1 on 01/12/2020 10:02:10
Michael Gilligan01/12/2020 10:10:18
17318 forum posts
786 photos
The idea of turning wood, of 25cm diameter, on THAT, is terrifying surprise
JasonB01/12/2020 10:18:06
19961 forum posts
2178 photos
Should be OK for a bit of bowl turning, many moons ago we had one of those wood lathes that you clamped an AEG drill into which was not as substantial as that.
Henry Artist01/12/2020 10:31:04
121 forum posts
46 photos
Hmm... a 500w motor with a speed controller for £60.
I can think of a few vintage lathe owners who could easily adapt such a motor for their own lathes. wink
Michael Gilligan01/12/2020 10:41:14
17318 forum posts
786 photos
Posted by JasonB on 01/12/2020 10:18:06:
Should be OK for a bit of bowl turning […]
Did you mean bowel churning ?
Bazyle01/12/2020 10:43:38
5785 forum posts
216 photos
For a metal turner who doesn't want to get shavings on the oil all over his main lathe to make a small handle or bung for turninga tube it could be a reasonable thing to put in a corner and just use occasionally.
I'm wondering if the 500W 800-3000rpm self contained speed controlled motor is a viable unit in its own right for powering a small lathe like a ML1 or RandA. Has a convenient mounting rail to enable it to mount behind the lathe and move along to power a clockmaker's cutting frame etc.
Roderick Jenkins01/12/2020 10:56:02
2047 forum posts
546 photos
My first lathe was one these:
(Image from lathes.co.uk)
Worked fine within its envelope. A bit noisy though. The Lidl one should be fine for small bowls, tool handles and candle sticks like I used to make.
Rod
mgnbuk01/12/2020 10:56:33
929 forum posts
65 photos
I wonder what kind of motor is inside that ?
The description of the speed range as being "No load speed" & the price point makes me think it would be a pistol drill style brushed universal motor with a basic triac speed control.
Should that turn out to be the case, I'm not sure I'd want such a drive on a metal cutting lathe ?
Nigel B.
ps. Just watched a bit of a YT video showing one of these in use - sounds rather pistol drill-ish & slows down very noticably under load.
Edited By mgnbuk on 01/12/2020 11:00:14
Michael Gilligan01/12/2020 11:05:45
17318 forum posts
786 photos
Posted by Roderick Jenkins on 01/12/2020 10:56:02:
Which surely didn’t include turning [nearly] 10” diameter wood
 Here is Lidl’s claim:
  • For processing wooden workpieces up to 60cm in length and 25cm in diameter
I wonder how they define “processing” dont know
Edited By Michael Gilligan on 01/12/2020 11:11:21
Nicholas Wheeler 101/12/2020 11:11:56
504 forum posts
28 photos
Rod
We've still got one somewhere.
As the only wood turning I do is for handles, and that is really rare, I just use the metal lathe
Roderick Jenkins01/12/2020 11:30:47
2047 forum posts
546 photos
Posted by Michael Gilligan on 01/12/2020 11:05:45:
The Lidle lathe comes with a faceplate so I can't see why you couldn't make a shallow 10" bowl starting with a round bandsawn blank. The motor has a claimed 2/3 hp.
Rod
KWIL01/12/2020 11:46:22
3352 forum posts
66 photos
You had better bandsaw that blank round, otherwise it will be a flyer!
Michael Gilligan01/12/2020 11:47:38
17318 forum posts
786 photos
O.K. .... I give up
Roderick Jenkins01/12/2020 11:57:57
2047 forum posts
546 photos
Here's a YouTube video **LINK**
Doesn't look like the most pleasant wood turning experience but seems possible frown
Rod
Bo'sun01/12/2020 12:12:15
358 forum posts
I like the way he skipped the footage of getting it round. All looked a bit precarious for my liking. I'll stick to my Tyme Cub thank you.
JasonB01/12/2020 12:22:14
19961 forum posts
2178 photos
Considering it was a badly balanced blank and the woods got some spalting it did not cut too badly, once he turned the speed up about 4.30 in there was less stalling.
Rod your old one looks solid compared to what I first used, this is not a good image but shows it was just a couple of brackets that screwed to the edge of a bench. Though not the thing to put a bit lump of natural edge green oak on.
larry phelan 101/12/2020 13:34:44
948 forum posts
14 photos
I remember when those hand drill/lathes/saws/sanders ect were all over the place, you could even drill holes with it One of them, a Bridges make was claimed to drill 5/16" holes at 3500 rpm, it did, but the drill bits did not like it
I think the idea was to make "A drill for all seasons", but the bearings did not last too long.
A friend of mine might be interested in the Lidl one, when it gets here.
Harry Wilkes01/12/2020 13:46:06
1054 forum posts
64 photos
Rod
Had one too and turned a dam sight more than wood on it smiley
IanT01/12/2020 14:33:46
1801 forum posts
176 photos
This YouTube shows a more likely use of the Lidl lathe - I have something a bit heavier for my woodturning but this machine might suit some craft hobbyists for smaller turned work. I think they are who this machine is probably aimed at.
Lidl Lathe turning Smaller Part
IanT
Edited By IanT on 01/12/2020 14:38:15
Ady101/12/2020 14:38:31
4233 forum posts
593 photos
Oh boy that was a scary video...
JD Metals
