From ebay
Arthur Goodwin | 25/11/2020 19:57:17 |
41 forum posts 18 photos | Hi I have purchased an hall effect sensor and display unit from ebay. The instructions are in chinese and the vendor has been no use at all. Has any body got a wiring diagram that i could use Thanks |
Mike Poole | 25/11/2020 20:08:11 |
![]() Moderator 2849 forum posts 67 photos | There are a few different versions, I am guessing the sensor has three wires brown/blue/black. Brown is positive blue is negative and black is the output, the display will also need the same supply. A picture of what you have will help. Mike |
JasonB | 25/11/2020 20:13:12 |
![]() Moderator 19589 forum posts 2150 photos 1 articles | If it's a tacho then the 5 connections to the ribbon wire are |
Grizzly bear | 26/11/2020 20:30:55 |
261 forum posts 8 photos | Any use? Introduction Hall Effect Switches Sensors Circuits Tutorial (bristolwatch.com) Bear.. |
