BOB BLACKSHAW | 22/11/2020 12:15:11 |
391 forum posts 82 photos | Hello all, I've made a 2/3rd scale A A Raymans marine steam engine, started on the boiler and now thinking of the boat hull. I made the engine 2/3 rd scale so it will be the same size as my other steam boat engine, and so can scale up to the same hull. The hull on my steam boat is made out of a solid lump of wood carved out, so was thinking of drawing the shape and profiles out of cardboard as patterns. My question is if I had layers of wood planks under 1/2 inch cut out the rough pattern then glued the planks up, would the finished hull warp after it was finished. I've been looking for a sawn up log on my travels but seems a lot more work involved cutting out the shape. Bob
Bryan Cedar 1 | 22/11/2020 13:14:11 |
61 forum posts 1 photos | I would think that if the hull was constructed using glued planks ie, resembling plywood, there is less chance of warping as in proper plywoood. I have two hulls made purely for show constructed this way. |
An Other | 22/11/2020 14:08:32 |
188 forum posts 1 photos | Why not have a browse around the Model Boats site for some ideas and inspiration - go to the ME home page, and scroll right down to the bottom, the link is in the gray box. |
John Haine | 22/11/2020 14:14:46 |
3647 forum posts 197 photos | It depends on the wood. My father made me a model boat from a set of Hobbies plans based on a stack of cut-out horizontal laminations, must have been 1/2" thick I guess. He used offcuts of teak flooring from the place he worked which was having a posh new building put up. Used Casco wood glue. Never any problems with warping that I recall. |
Bazyle | 22/11/2020 14:21:52 |
![]() 5780 forum posts 216 photos | This is an age old traditional method of model boat construction called 'bread and butter' or 'sandwich'. You do keep the planks in line though not cross-plied. Thick planks, like 1 in, are less sawing though if you have a bandsaw or jigsaw it is a doddle. You can just get planks from a timber merchant but unless well seasoned and quarter grain will likely be bowed. This only matters for the bottom plank that is widest. You only need two planks if you are cunning and the hull profile is suitable. When you cut the inside out of the largest profile it can use it for the next but one layer and so on alternately. Some people have even managed to cut at a angle so it fits the nest layer. |
Derek Lane | 22/11/2020 14:33:41 |
![]() 395 forum posts 83 photos | For lightness and room the traditional method of plank on frame it takes a bit of time but well worth the effort. There are also suppliers of fibreglass hulls but finding one in the style and scale that you want may be difficult. As above the bread and butter method can be done and by cutting out the waste from each plank before glueing will reduce the weight early on and save trying to carve the inside. Which ever method you choose think about prop tube and rudder tube placement before starting as sometimes it can be easier to install these as you progress with the hull construction |
BOB BLACKSHAW | 22/11/2020 15:19:38 |
391 forum posts 82 photos | Thanks for the replies, looks like I will go for the sandwich method on the hull, never thought of fiber glass on the outside for strength. Thanks Bob |
Bob Mc | 22/11/2020 15:49:16 |
155 forum posts 3 photos | Hi Bob... I am making a model boat at the moment, this is 'Ravenna' and plans are from a well known supplier, disclaimer, I didn't plan to make a boat but was in the process of changing a wooden slatted venetian blind when it ocurred to me that the wooden slats could be used for something. The 'slats' are I believe Maple and I managed to bend most of them to shape using plenty of clamps. 'Planks' are butted up with plenty of good quality waterproof glue, small gaps filled in with expanding glue and when finished soaked in thinned paint then 4 coats of paint,...still not finished this ... but it looks ok having never had a go at a model boat before. The cabin is now buit up and am making window frame inserts using brass 22mm compression olives which are elongated over a mandrel and silver soldered. I don't know if this is the right way to go about it but I'm not one for convention... Good luck Bob.. |
BOB BLACKSHAW | 22/11/2020 17:39:17 |
391 forum posts 82 photos | You have done a great job of the boat Bob, if mine comes out as good I will be happy with the that. Bob |
