Chuck faceplate Clarke for lathes
P Edg03/11/2020 23:50:30
6 forum posts
Hello, does anyone know of a supplier of an off the shelf chuck adaptor faceplate to fit the Clarke cl430/500 lathes? Clark’s own 4 jaw chuck is stupidly overpriced (in my opinion) but its oddly sized at 130mm diameter with a 100mm mounting recess so slightly different to the common Chinese chucks which are all 5mm smaller on both. I’ve searched all the popular home workshop supplier websites but haven’t found anything’s so any advice appreciated, thank you.
Bazyle04/11/2020 00:43:50
6390 forum posts
224 photos
For some reason chuck backplates have become stupidly expensive of late, even cast blanks. Bite the bullet and make your own from a slice of cast iron round. Maybe practice first making a threaded hole or two in an aluminium and then iron bar about 2 in dia. If you mess up on the bigger plate you can glue and screw in a bit of bar and try again.
edit - also to relax a bit it is the register rather than the thread that is important for fit so make a go/nogo gauge for that.
Edited By Bazyle on 04/11/2020 00:46:03
john halfpenny04/11/2020 08:50:00
254 forum posts
24 photos
I'm not sure what Bazyle means by a screw thread, but I imagine you need a simple round with opposing male and female registers, and three peripheral through holes for the mounting studs. I've never seen such a thing, but it would be straightforward to make for someone with precision skills. I managed to find a four jaw on ebay, so you may get lucky.
Michael Gilligan04/11/2020 09:34:00
20289 forum posts
1064 photos
Somewhat bewildered [not only by Clarke’s price for the chuck]
The documentation shows three holes on the spindle nose plate ... but the four-jaw has four fixings
... do they include an adapter plate, or is this just artistic license ‘for clarity’ ?
Personally, I would be tempted to reduce the register diameter, to enable fitment of an alternative four-jaw, and then make a spacer ring [ like a circular-saw blade ‘reducer’ ] for the existing three-jaw.
P.S. ___ in my search for enlightenment, I found this video which you might find useful some time:
**LINK** https://youtu.be/XPpLGtzaErM
Edited By Michael Gilligan on 04/11/2020 09:40:07
john halfpenny04/11/2020 09:39:50
254 forum posts
24 photos
The Clarke four jaw has three mounting studs in the back face..
john halfpenny04/11/2020 09:39:51
254 forum posts
24 photos
The Clarke four jaw has three mounting studs in the back face of a mounting disc, the front of which has a 75mm male register to engage the chuck body. The front screws hold the body to the mounting disc. As I suggested, this may be the best way of adapting to a different four jaw. For completeness, the Clarke four jaw currently advertised has the four mounting screws on a much larger pcd than mine
Edited By john halfpenny on 04/11/2020 10:01:06
Michael Gilligan04/11/2020 09:45:01
20289 forum posts
1064 photos
Thanks for the clarification, John yes
Published photos made it appear [to my innocent eyes] to be front-fixing, with an [unspecified] adapter plate
https://www.chronos.ltd.uk/product/4-jaw-independent-chuck-for-cl500-430-2/
... I would still advocate modifying the nose.
Edited By Michael Gilligan on 04/11/2020 09:48:03
P Edg04/11/2020 15:08:51
6 forum posts
Thanks for all your replies and alternative solutions. I think Clarke must keep theirs vague to stop others copying it!
not done it yet04/11/2020 15:28:32
6891 forum posts
20 photos
Three bolts secure the chuck backplate to the lathe spindle (on its spigot). When the spigot (for the chuck) has been cut, it will be perfectly central for the 4 jaw to be fitted over and the four holes for the chuck bolts drilled and threaded. All parts suitably marked for future assembly in their rightful positions should ensure concentric chuck running, if ever removed (only for balanced running with a 4 jaw, of course). Done it 25 years, or so, ago.
Michael Gilligan04/11/2020 15:32:17
20289 forum posts
1064 photos
Posted by not done it yet on 04/11/2020 15:28:32:
Three bolts secure the chuck backplate to the lathe spindle (on its spigot). […]
Yes, I do understand now yes
... Water under the bridge, as you will see from my previous post
John Forster 129/11/2020 18:44:10
1 forum posts
Hi Guys,
This is the third attempt at posting this so if it come up three times I apologise.
I have a CL500 M lathe and want to replace the 3 and 4 jaw chucks with a collet chuck. does anyone know if Clarke do one? or can anyone tell me the PCD of the boltholes that hold the chucks to the spindle flange?
Also doe anyone know if Clarke do a QCTP for the said lathe? I bought an online one for a mini latheno completely the wrong one AND it was 'Ali' so soft a clart.
Regards. Any info appreciated, especially if MG has a more detailed diagram of item to in the head stock exploded view
old mart29/11/2020 21:33:16
3913 forum posts
268 photos
Check out my recent post on Colin Martin 2's thread "mini lathe upgrade", it is easy to modify the four jaw independent type of chuck. The mini lathes have holes for three jaw and four jaw chucks in the spindle flange, one hole being shared. It would not be hard to drill some extra holes in your spindle.
Edited By old mart on 29/11/2020 21:37:20
martin perman29/11/2020 21:58:43
2058 forum posts
86 photos
Posted by John Forster 1 on 29/11/2020 18:44:10:
Hi Guys,
I have a CL500M, Clarke dont have a collet chuck but there is a taper in the spindle nose so I bought an ER collet chuck with the same taper but there is a limitation, you have to make a draw bar which means short jobs.
Martin P
Edited By martin perman on 29/11/2020 21:59:29
john halfpenny29/11/2020 22:07:46
254 forum posts
24 photos
The Clarke spindle taper is Morse. No Clarke QCTP, but a chinese one fits -marked 250-100
Edited By john halfpenny on 29/11/2020 22:11:31
Michael Gilligan29/11/2020 22:11:04
20289 forum posts
1064 photos
Hi Guys,
Sorry to disappoint you, John
My clip of the diagram came from here: **LINK**
https://www.clarkeservice.co.uk/technical_information/metalworking/cl430-500m_tech.pdf
... and that’s pretty-much all I know about them
Howard Lewis30/11/2020 15:37:15
6317 forum posts
15 photos
If you want to pass longer material through an ER collet chuck, ER chuck on a backplate are available. I bought an ER32 from Warco. It might need an extra adaptor backplate to fit it to your CL500M
The Warco backplate seemed to be hardened, may not be possible to drill to match the flange on the CL500M, hence the adaptor suggestion.
Howard..
john halfpenny30/11/2020 17:39:46
254 forum posts
24 photos
I have remembered that Clarke do sell a collet chuck with Morse taper. It comes with a set of metric spring collets which look like ER, but are not. It's intended for the mill/drill, but would of course fit the chuck spindle taper - probably with the mill-drill drawbar
john halfpenny30/11/2020 19:08:17
254 forum posts
24 photos
I think my idea will also require an MT3/MT2 sleeve
Howard Lewis01/12/2020 16:43:01
6317 forum posts
15 photos
An ER collet chuck, which will limit the length of material that can be held, will be available from suppliers other than Machine Mart. It is possible that it will be almost the same item, but possibly cheaper.
Search Arc Euro, Warco, Chester, Axminster, RDG, for a start. All these offer ER chucks for either Lathes or Milling machines..There will be other suppliers as well, without a doubt. Look at their websites.
Ian B.01/12/2020 17:26:38
169 forum posts
5 photos
Can I add Chronos to Howard's list please. All my ER32 items came from.them. I have one for the WM180 lathe, one for the Mini Lathe and also a morse taper one for the mill along with all my collets. They seem to have quite a selection. Usual disclaimer other than satisfied customer.
As regards backing/adaptor plates for lathe chucks it might be worth studying Warco's website. I needed an adaptor for another joband they did a range of cast iron part machined items. These you can then finish accurately to your particular machine. Mark up its position on the mandrel, don't remove the chuck from it and it will be as accurate as the machine can make it.
Dreweatts
Rapid RC
