CNC mill questions
Philip A01/11/2020 10:43:26
37 forum posts
Now that I've got the hang of my mini lathe I'm starting to dream about a similar milling machine.
As an example, if I wanted to mill something like winch fairlead below, how would a milling machine cut those arcs? Would that require CNC ?
If all I need is the capability to cut arcs then would CNC on just the X any Y axis be enough? Or is there a non CNC alternative I could look at?
If a sieg (or similar) mini mill is converted to CNC can it no longer be used manually?
The Sieg conversion kits seem to go for ~£700, plus cost of stepper motors + controller. Any idea what sort of saving would be made if I made the kit myself? And is a Sieg X2 or SX2P mill capable of making a bit to convert itself to CNC?
Thank you!
Tony Pratt 101/11/2020 11:05:02
1692 forum posts
8 photos
The slot end arcs would be cut with a 'normal' cutter, corner rounding cutters are available to do the slot blend rads. The end rads would typically be done with a rotary table after milling the angles so CNC is not needed. Don't know about the Sieg conversion but all the CNC mills I have worked on do have some sort of switchable electronic hand wheel so all the 3 axis [or more] can be moved by 'hand'
Tony
Emgee01/11/2020 12:11:46
2156 forum posts
265 photos
Hi Philip
You could make the part on a conventional mill with the aid of a rotary table and internal radiused cutter but would involve a number of set-ups, with cnc the blank material could be drilled and counterbored then screwed down to a sub-plate to allow the rest of the part to be completed with 1 further set-up on a cnc machine.
What does a £700 mill conversion kit contain ? (3 ballscrews, ballnuts and fixing fixings ? )
Emgee
Philip A01/11/2020 14:34:10
37 forum posts
Posted by Emgee on 01/11/2020 12:11:46:
Hi Philip
Emgee
Hi emgee this is what you get for ~£700:
Emgee01/11/2020 14:42:18
2156 forum posts
265 photos
First step of you want to use CAD/CAM is make the model, either drawn in 2D or 3D in this case Fusion 360 as I need the practice. Picture of the completed model based on your picture.
Emgee
Zan01/11/2020 15:32:43
282 forum posts
19 photos
Philip,
I have converted my sx2 +. Send me a pm n I’ll talk to you
BOLDON
JD Metals
walker midge
rapid Direct
