Hardly a workshop tool but....
David Colwill | 01/11/2020 10:41:58 |
737 forum posts 38 photos | Over the last couple of years I seem to have started to feel the cold a little more. This is particularly bad when my feet get cold. I bough a rubber mat off ebay for £21.99. It is 5 foot by 3 foot and about 3/8" thick. The sides are bevelled and and it has holes that allow oils swarf and finished components to fall in to. It has made a huge difference to working on the lathe and I have now ordered another for in front of the bench. There are a number of people selling these and I have no connection with any of them. Regards. David. |
Mike Hurley | 01/11/2020 11:09:45 |
97 forum posts 53 photos | Yes, we all start to feel the cold as we get older... I tend to find that any kind of mat / carpet can sometimes be a bit of a nuisance by moving slightly or creasing up and me tripping on the bits that subsequently stick up. I made up a couple of lengths of wooden 'duck boards' - simply long strips about 30mm wide nailed onto occasional cross pieces, with about a 25 mm gap between each. They keep your feet off the cold concrete, let metal turnings drop through easily and are easily lifted to find that vital last screw you just dropped (or simply to clean). Just my personal preference, but obviously whatever suits the individual. is fine. Mike |
Bazyle | 01/11/2020 11:28:53 |
![]() 5831 forum posts 216 photos | You had a 5ft x 3ft clear floor space in your workshop !!!!! Do they sell 18" x 2ft pieces? |
Jouke van der Veen | 01/11/2020 11:32:21 |
85 forum posts 8 photos | I suppose you can cut it? |
Speedy Builder5 | 01/11/2020 11:35:13 |
2257 forum posts 170 photos | I use old carpet, beside the lathe I have a floor mat, probably ex Sketchly office services which served as the door mat to a company, tapered rubber edges (Non trip) and some sort of man made fibre carpet. My Dad's workshop had 1/2" ply boards over concrete. The boards were originally used as sacrificial boards under alloy sheets which were routed out for aircraft panels. |
Alistair Robertson 1 | 01/11/2020 11:40:40 |
130 forum posts 6 photos | I bought a couple 600 x 900 mats from BigDUG **LINK** They wanted to charge £15 delivery but I objected as the charge did not show until checkout so I got free delivery! They are very good mats and perfect for a workshop. |
David Colwill | 01/11/2020 11:58:48 |
737 forum posts 38 photos | Posted by Bazyle on 01/11/2020 11:28:53:
You had a 5ft x 3ft clear floor space in your workshop !!!!! Do they sell 18" x 2ft pieces? Damn it! I must have been burgled. Alistair. I looked at the smaller mats but they were nearly as much as the larger ones (on ebay at least). Jouke van der Veen. I will probably get another and cut it in half as this seems to be cheaper than buying smaller ones. David. |
Paul Lousick | 01/11/2020 12:12:09 |
1707 forum posts 627 photos | Try your local hardware store. If like the ones here in Australia they sell a number of rubber mats of various cut sizes and on a roll and sold by the metre. Insulation from the cold is not as big a problem here but is good to stand on and prevent aching feet from standing on a hard floor. I also have a 6' x 4' x 1/2" piece on the floor of my car trailer to cushion the load. Paul. Edited By Paul Lousick on 01/11/2020 12:16:08 |
HOWARDT | 01/11/2020 12:28:37 |
703 forum posts 25 photos | I use foam rubber mats from Halfords, and other places. Pack of six, I think 600mm square, link together with edge pieces, £10 the set. Used them both in the shed on wood floor and garage on concrete, been down four years and still good, insulate well. |
Nick Clarke 3 | 01/11/2020 12:32:45 |
![]() 1154 forum posts 48 photos | Posted by HOWARDT on 01/11/2020 12:28:37:
I use foam rubber mats from Halfords, and other places. Pack of six, I think 600mm square, link together with edge pieces, £10 the set. Used them both in the shed on wood floor and garage on concrete, been down four years and still good, insulate well. plus 1 |
not done it yet | 01/11/2020 12:38:27 |
5776 forum posts 20 photos | I also have a 6' x 4' x 1/2" piece on the floor of my car trailer to cushion the load. We have had this sort of thing for over 25 years, at least. No idea where the roll came from, back then. My ex installed a strip in the bathroom and I later used the rest in front of my workbench and lathe.🙂 |
Circlip | 01/11/2020 14:16:02 |
1244 forum posts | 2" x 3/4" laths spaced to suit on 3" x 1" battens, make whatever size you want. Regards Ian. |
duncan webster | 01/11/2020 14:57:30 |
![]() 3130 forum posts 52 photos | When I converted my garage I had the floor covered with mastic asphalt to get it level and waterproof, then 25mm polystyrene covered with flooring grade chip board, all topped off with the old vinyl flooring from the kitchen. Only downside is you have to cut holes and fit packers under machine feet, but I don't move the machines around very often. |
Brian H | 01/11/2020 15:11:05 |
![]() 2097 forum posts 113 photos | I used some of the rubber tiles sold for garages and gyms etc, that interlock together. Not expensive. Brian |
Zan | 01/11/2020 15:36:04 |
225 forum posts 18 photos | I have several of these. one is about worn out after 10 years 1 collecting swarf so it doesn’t get embedded into shoes 2keeping feet warmer 3 stopping small parts dropped getting lost, they lodge in the holes
Ady1 | 01/11/2020 15:43:45 |
![]() 4285 forum posts 641 photos | Solid concrete garage floor so a pair of old knackered hillwalking boots, so a comfy fit, and double socks A fleece beanie helps too And I'm a bad boy but I use leather working gloves too, those yellow things, they make a huge difference when the temp starts heading towards zero, otherwise the cold metal sucks the heat right out of your hands Means I can work in comfort all winter, my hands are clean and I really can't remember the last time I had to dig out a bit of swarf Edited By Ady1 on 01/11/2020 15:46:53 |
Steve Withnell | 01/11/2020 16:03:31 |
![]() 832 forum posts 219 photos | I just use a couple of layers of carpet offcut...
Chris Evans 6 | 01/11/2020 16:17:53 |
![]() 1880 forum posts | Posted by Nick Clarke 3 on 01/11/2020 12:32:45:
I use foam rubber mats from Halfords, and other places. Pack of six, I think 600mm square, link together with edge pieces, £10 the set. Used them both in the shed on wood floor and garage on concrete, been down four years and still good, insulate well. plus 1 Plus 2 I have covered my entire double garage floor with them. |
larry phelan 1 | 01/11/2020 16:29:57 |
971 forum posts 14 photos | Been using homemade duckboards for years,, cheap simple, and they really work ! What more could you want ? |
Martin Kyte | 01/11/2020 17:14:29 |
![]() 2309 forum posts 38 photos | I have flooring grade tongue and groove chipboard on top of underlay on a concrete base. Works very well. regards Martin |
