JM Wild overhead milling / gear cutting drive motor.
YouraT30/10/2020 14:19:41
33 forum posts
5 photos
Hi all.
I've acquired after much searching a nicely built JM Wild overhead gear cutting drive system, but minus the motor and its pulleys.
I know the pulley diameters and the motor speed (1425rpm), but can anyone help with the as-designed motor rating?
I'm thinking that 1/2hp would be ample for my expected worst case load of pinion cutting, but any knowledge and advice would be appreciated!
Thanks,
Youra.
Roderick Jenkins30/10/2020 17:21:53
1967 forum posts
510 photos
Yours,
According to Tubal Cain's book "Milling operations in the lathe" the JM Wild overhead gear used a 1/8 hp motor which TC thought a bit small for milling rather than clock gear cutting. I have used a similar arrangement with a 1/6hp induction motor that mills steel with a 1/4" cutter.
HTH,
Rod
YouraT05/11/2020 22:01:07
33 forum posts
5 photos
Thanks Rob
1/6hp agrees with advice given elsewhere too - I have a slightly bigger motor to hand, and as long as it's not too heavy, I'll likely go with that.
Youra.
Michael Gilligan06/11/2020 07:27:05
16620 forum posts
723 photos
Just for info. **LINK**
http://www.j-m-w.co.uk/tools9.html
”. A complete construction article on this equipment commenced in the Model Engineer magazine, 20th November, 1981. “
EngineDIY
