Taper identification
Me.30/10/2020 12:32:57
42 forum posts
1 photos
OK thanks for that - but at the moment it is neither 30 or 40 - its in-between the two - it has the same angle as the 30 40 50 etc but its larger than a 30 and smaller than a 40.
Specific to the Herbert machines of that age....
Having looked at tooling for the 30 I would love to have it a 30 but until someone comes up with the perfect solution i can only work with what I have......
Brian H30/10/2020 12:50:23
1862 forum posts
106 photos
If it's in between 30 & 40 then it sounds like it's a 1 3/8NS (non-stick). I did wonder about that but the suggestion that it had been re-machined fooled me, unless someone had just taken off a small amount to clean it up.
Brian
Alistair Robertson 130/10/2020 13:00:53
116 forum posts
6 photos
Ah, Then it is most certainly BT35 which was used in the early 60's but is being used on some mainly Japanese CNC mills today.
Not common so machinung out to BT40 would certainly be the way to go, both practically and financially!
Me.30/10/2020 13:29:30
42 forum posts
1 photos
surprisesurprisesurprise BT35..... ahhhh - where how what..... Anyone got the dimensions of a BT35 taper... do you think it would be that simple.
I'm taking the machine apart for a good clean and service and its a very easy machine to work on - aorta's from the weight - so removing the spindle should be pretty straight forward.... I hope.
Me.30/10/2020 13:34:08
42 forum posts
1 photos
Found a dimensional drawing of the BT35 and that looks too big - it looks like its 38mm at the largest section on the taper I only have 34mm ish where then BT30 is 31mm ish....
I had my hopes up then....
Emgee30/10/2020 14:11:06
1764 forum posts
237 photos
Perhaps this is as yours ?
Pete White30/10/2020 14:33:03
121 forum posts
14 photos
It is as Brian says I am sure. If you make a sleeve you only need one, then all int 30 stuff will fit, new stuff is not expensive from our sponsors. Can you send a pic of that one tool that you have with the ns taper, I would not carve that up. If you make a sleeve and mess up you can easily have another go, it can be a little tricky to get the diameters right, a little bit changes to lengh quite a lot, if you see what I mean,
Me.30/10/2020 14:36:19
42 forum posts
1 photos
Thanks  - mine doesn't have the tangs as per the drawing - but I would have thought it was if its from a Herbert machine.
Posted by Emgee on 30/10/2020 14:11:06:
Edited By Me. on 30/10/2020 14:37:33
Me.30/10/2020 14:41:01
42 forum posts
1 photos
Hi Pete
The picture is at the start of the thread - that is the only thing that fits in my spindle.
Posted by Pete White on 30/10/2020 14:33:03:
EngineDIY
