Indexer?
martin cross 128/10/2020 20:17:18
24 forum posts
36 photos
I've been 'given' one of these (£10), it has a Burnerd chuck attached to it. All seem in good condition, I haven't had time for a real good look at it but wondering how to remove the chuck, supposing it can come off?indexer.jpg
Bazyle28/10/2020 20:35:37
5555 forum posts
207 photos
That style normally is for 5C collets so maybe the chuck is on a 5C shaft and has a small locking ring at the back or is glued in.
A picture of the actual one would be interesting.
Edited By Bazyle on 28/10/2020 20:36:22
JasonB28/10/2020 20:44:41
19085 forum posts
2100 photos
As said the chuck may be on a 5C arbor, undo the knurled ring on the back end, may need a slight tap with a soft hammer to release the taper
martin cross 128/10/2020 20:51:44
24 forum posts
36 photos
I'll have a look tomorrow, and get me hammer ready.
martin cross 128/10/2020 20:52:55
24 forum posts
36 photos
JasonB29/10/2020 06:55:02
19085 forum posts
2100 photos
A view from either end would be better then it would be possible to see if the chuck has screws from the front directly into the index ring, the index ring may have CSK holes in it for screws into the back of the chuck or the nut on the back as mentioned above.
martin cross 129/10/2020 09:19:15
24 forum posts
36 photos
JasonB29/10/2020 10:01:30
19085 forum posts
2100 photos
So you are missing the nut to draw in a 5C collet or a chuck mounting arbor.
Are there any cap head screws visible on the face of the chuck? If there are then these are most likely holding it to the index ring so undo those.
If there are no visible screws then undo the clamp screw at the rear of the indexer and then screw off the clamp and slide the spindle out. You can now see if there are any screws countersunk or counterbored through the index plate holding on the chuck
John Reese31/10/2020 01:49:02
848 forum posts
It resembles a Kalamazoo indexer. I have one suggestion for an improvement: Mill or grind flats on the sides parallel with the rotation axis. That will allow it to be held in the vise.
Paul Lousick31/10/2020 02:17:51
1576 forum posts
594 photos
Have you removed the 2 clamps at the rear end ? There maybe something behind them that releases the spindle and chuck.
Bazyle31/10/2020 10:31:46
5555 forum posts
207 photos
It looks like the two hinged parts at the back are held closed by a screw you haven't shown us. Do their sloped edges fit into a groove in the back of an arbor? Is the step in the bore indication of a tube, the back end of a 5C fitting, perhaps just held by rust?
martin cross 131/10/2020 14:18:24
24 forum posts
36 photos
I have dismantled and cleaned everything, and posted some more pics in the album which perhaps better shows how things fit together. Undoing the clamp at the rear allows the shaft and chuck to come out, the chuck is attached to the head by three bolts. There is what appears to be a short sleeve inside the bore held in with a split pin which when removed doesn't allow any movement of the sleeve, it may be a very tight fit perhaps. But the internals and condition appear ok and so I'm happy with it.
EngineDIY
