Remember that old article by Base Circle ?
Cutting Gears on the Shaper ...
Michael Gilligan28/10/2020 07:32:43
16639 forum posts
725 photos
This guy takes us on his own ‘voyage of discovery’
https://youtu.be/so4O_yxUfCE
Clive Foster28/10/2020 09:40:20
2466 forum posts
81 photos
I often find these "oops, that didn't go quite to plan" you tube videos more interesting than the" look how I did a wonderful job" ones.
Especially when the oops, as in this case, turns out to be exactly the reason why I've not tried myself.
The indexing issue is rather glossed over in the original article.
Seems to me that a better way would be to self index on the gear being made by registering "180° + one tooth" opposite the previous cut. That way any errors get spread around and you don't need another gear of the same tooth count for indexing or have to drill a hole circle in a dividing plate. Doesn't have to be 180°, pretty much any angle will do so long as the offset is one tooth space.
I wonder if a section of steel band drive belt would work in place of the wire?
Ady128/10/2020 09:58:05
3955 forum posts
522 photos
The index locking pin system is really critical or you get errors that mess things up
The whole process is highly dependent on virtually no appreciable errors when using a shaper and is not easy to achieve when being set up from scratch
Michael Gilligan28/10/2020 11:09:09
16639 forum posts
725 photos
Posted by Clive Foster on 28/10/2020 09:40:20:
Some previous discussion on this forum covered that, Clive
... If I can find the relevant thread, I will post a link
Clive Foster28/10/2020 11:29:34
2466 forum posts
81 photos
Accurate indexing is always the key to making good gears. Most especially avoiding cumulative errors.
Consider a 36 tooth gear. For practical purposes each tooth is 5° wide so a 0.1° indexing error on each shift means 3.6° by the time you get to the last tooth. Which will be very thin.
Spread the 0.1° error out evenly around all the teeth and all will be a touch thin but the gear should be fine for undemanding applications like change wheels. The method does inherently produce a correct involute form within the inherent limitations of being generated from many small line cuts. So I'd be unsurprised to discover that the result of evenly spread indexing error corresponds to the sort of addendum and dedendum modification used to adjust the centre to centre distance when standard gears won't fit. If so the gear should run just fine against a properly sized one.
Michael Gilligan28/10/2020 13:19:08
16639 forum posts
725 photos
Posted by Michael Gilligan on 28/10/2020 11:09:09:
Start here, Clive : **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=124817
Clive Foster28/10/2020 13:48:36
2466 forum posts
81 photos
Thanks for the link Michael. I now remember reading that at the time.
IanT28/10/2020 16:23:54
1680 forum posts
163 photos
These Guys got the 'Base Circle' method to work some three years back - as part of an "Emma's Spareroom" challenge. They had similar issues with indexing and PCDs at first if I remember correctly.
They used a more robust (purpose made) indexing head that probably didn't have as much give in it as the other guys angle-plate setup. Interesting use of 3D printed parts too (and they even managed to give a tongue-in-cheek plug to Stephan G.)
Shaper Cut Gears from Oz
IanT
Edited By IanT on 28/10/2020 16:24:57
EngineDIY
