Graham Meek’s Super 7 Tailstock Dial
Question about machining sequence
Mike Crossfield26/10/2020 07:41:03
253 forum posts
36 photos
Having recently completed my last major project I have started building Graham Meek’s Super 7 tailstock dial (MEW 279/280). At the moment I am puzzling over the best machining sequence for the main body of the device (the Backplate). There are some critical dimensions and concentricities, and few clues in the articles as to how best to achieve them. I would be very pleased to hear from Gray or and/or anyone who has successfully constructed this useful accessory.
Thanks
Edited By Mike Crossfield on 26/10/2020 07:43:51
Edited By Mike Crossfield on 26/10/2020 07:45:34
Graham Meek26/10/2020 16:00:29
330 forum posts
227 photos
Hello Mike,
From memory the machining sequence went something like this.
The Face and Outside diameter where the dial goes were turned. The main bore was drilled, bored and reamed to take the Oilite bush. Then the counterbore to clear the input gear was also machined at this point.
The part was then reversed in the chuck, (I used soft jaws for this operation), the part is then brought to length. The boss diameter was then machined, along with the blend radius and chamfer. The thread diameter is then roughed out and the undercut for the thread machined to size.
Griping on the roughed out thread diameter in a chuck on the milling table the Idler gear pocket was machined using coordinates. The part was then mounted on a spigot mandrel by the main bore, (dial end nearest chuck). The thread diameter is finished machined and the thread screwcut to the 3 wire dimension in the text.
Hope these notes help?
Gray,
Mike Crossfield26/10/2020 17:38:01
253 forum posts
36 photos
Hello Gray,
Thanks very much for the prompt and very helpful reply.
Just what I need.
Best regards
Keep safe
Graham Meek27/10/2020 11:10:22
330 forum posts
227 photos
Hello Mike,
You are welcome, if I can help you further in the future just ask.
Gray,
Mike Crossfield27/10/2020 17:50:48
253 forum posts
36 photos
Hello again Gray,
I have cut the input gear and the idler gear (imperial) using cutters made according to the dimensions in Figure 5 in MEW 279, allowing for the drawing error noted in MEW 280. However the meshing, although close, doesn’t seem to be quite right. I made the cutters very carefully using the DRO on my mill. I don’t think I made any significant error, and I suspect there may be another drawing error in Figure 5. I think I can see in photo 6 In MEW 280 another cutter dimension (0.55 versus 0.62) in your original drawing which is different from that in Figure 5. If you wouldn’t mind I’d be very grateful if you could check that all the Figure 5 cutter dimensions are as you intended.
In view of these problems with the Figure 5 cutter dimensions, it would be reassuring if you also check that cutter data in Figure 6 is as you intended. I’m sorry to bother you with this, but I don’t know how to calculate the cutter dimensions for myself.
Many thanks
Martin Kyte27/10/2020 18:28:57
2348 forum posts
39 photos
Hi Mike
You may have found it already but the original build thread is here including all the drawing dim queries
Meek Tailstock thread
I'm very pleased with mine so well worth persisting.
regards Martin
Mike Crossfield27/10/2020 18:42:30
253 forum posts
36 photos
Hello Martin
The thread you linked to is the one I started when I pointed out two obvious drawing errors, and I am very familiar with it. However no other errors apart from those I pointed out were mentioned. I now think there is at least one more, which is why I am now querying the MEW drawings again with Gray.
Martin Kyte27/10/2020 19:49:00
2348 forum posts
39 photos
OK no worries, didn't realise it was your thread.
regards Martin
Graham Meek28/10/2020 12:20:21
330 forum posts
227 photos
Hello Mike,
I have just rechecked my drawings and the dimension is 0.55 mm. You say the gears are close, but not right. In what way? Are they too loose, or do they bind? Will one gear run smoother if it is turned over, (symptom of an offset cutter)?
As regards what appears in the Magazine, my copies were loaned to a friend pre-Covid outbreak, so I cannot currently access them. If you can scan your copy and jog my mind I would be grateful. I have checked all the photographs submitted but cannot see any reference to 0,62 mm.
Gray.
Mike Crossfield28/10/2020 13:49:43
253 forum posts
36 photos
Hello Gray,
The gears I cut ran very smoothly together, but had what seemed to me to be excessive clearance when set up at the specified spacing. Turning one over made no difference. I set them up in my clock depthing tool so that I could play around with the gear spacing and I found that the teeth bottomed out before the play reduced to zero.
Photo 6 in the magazine shows your test rig and your prototypes. I noticed that the hardware was laid out on the gear drawings, and in the top right hand corner of the photo I could see the dimensions for the idler gear cutter. This shows an offset of 0.62 rather than the 0.55 detailed in magazine Fig. 5. I haven’t yet made a new cutter using the 0.62 dimension, but I think it will reduce the clearance I am seeing.
I would be happy to scan the Figures from the magazine showing the cutter dimensions so that you can check them against your originals, but I don’t know if this will upset the magazine publishers? Perhaps somebody could advise?
Best regards
Mike Crossfield28/10/2020 14:21:55
253 forum posts
36 photos
Hello Gray,
I have sent some drawings to your gmail address.
Best regards
Mike Crossfield29/10/2020 10:45:21
253 forum posts
36 photos
Just to draw a line under this, Gray has very kindly checked the MEW drawings against his originals and confirmed that, apart from the two errors noted in MEW 280, they are correct.
JD Metals
