.DXF Files for Meccano Chain Wheels
Steve Withnell24/10/2020 18:11:16
821 forum posts
217 photos
Where can I get hold of meccano chain wheel drawings in .dxf format ?
I have an old radio that using rubber drive belts for part of the tuning mechanism and they perish very quickly, as they get cooked by the valves.
Meccano chain drives would look neat and be a long lasting solution.
TIA
Steve
Steviegtr24/10/2020 18:18:33
1625 forum posts
196 photos
Dad used to use elastic bands. Usually worked.
Steve.
not done it yet24/10/2020 18:20:39
5123 forum posts
20 photos
Use nitrile instead?
JasonB24/10/2020 18:26:56
19087 forum posts
2100 photos
If you have CAD then you could draw them up from this
Jeff Dayman24/10/2020 18:46:04
1913 forum posts
45 photos
Seems to me I have seen some radio tuners on old radio equipment (maybe ex Canadian Army from ww2 era) using a thin wire rope like a bicycle brake cable. The wire rope was fixed with a clip to each rotating drum, and each drum had a few turns. The wire rope ends were terminated with eyes which held an extension spring to keep rope tight on drums and take up any play from heat expansion, rope relaxation, bushing wear, etc.
Meccano chain as you suggested would probably work great too. if the items to be coupled make the chain move less than the span between them plus the length of an extension spring, you might be able to use an extension spring to take up any slack in the chain and keep the chain snug on the sprockets. Just food for thought.
Michael Gilligan24/10/2020 18:46:58
16613 forum posts
723 photos
Posted by JasonB on 24/10/2020 18:26:56:
Nicely drawn, that yes
Lessons could should be learned
Grindstone Cowboy24/10/2020 19:00:40
357 forum posts
28 photos
Posted by Jeff Dayman on 24/10/2020 18:46:04:
Radio dial cord, like this - used to be available from such suppliers as Maplins.
Rob
JasonB24/10/2020 19:02:45
19087 forum posts
2100 photos
I just learnt thiswink 2
Bazyle24/10/2020 19:15:00
5555 forum posts
207 photos
Just for general interest. Meccano did not design the chain and sprockets for themselves. They just used ones that were in mass production already for the drive in player pianos.
Martin Cargill24/10/2020 19:16:18
148 forum posts
What about using Mammod style spring drive belts? or if smaller ones are required the springs from the back of shaft oil seals.
Martin
Bazyle24/10/2020 22:11:06
5555 forum posts
207 photos
That link to the Meccano drawings is realy interesting. In looking at some of the gears and wheels I see they use the word 'pummel' as a noun for the boss. This is not mentioned in the online dictionaries I checked, most not even acknowledging a noun and only wanting to recognise 'pommel'.
Michael Gilligan24/10/2020 22:25:32
16613 forum posts
723 photos
Posted by JasonB on 24/10/2020 19:02:45:
I didn’t mean you, Jason ... I was thinking more of a recent ‘reworking’ fiasco
The Meccano drawing is a model of clarity, and remains useable
JasonB25/10/2020 06:28:26
19087 forum posts
2100 photos
Yes everything is on the drawing *, the only thing I had to make a call on was whether the 0.015" was a straight line between where the two arcs meet the OD or if it were the length of the small arc, though it would not make much difference on such a small dimension. I did learn a little as it made me think how best to draw it and did use one option that I don't use often. I'm just waiting for Dave's pencil drawn on nowsmile p
* :Looking again I see it was steel and I coloured it for brassblush
SillyOldDuffer25/10/2020 11:49:48
6437 forum posts
1419 photos
Posted by JasonB on 25/10/2020 06:28:26:
I learned from this one too. My attempt in Qcad:
It's wrong! Right at the beginning I misplaced the tooth valley by centring its radius on the pitch radius circle, which is not what Meccano Ltd drew.
I looked 'Pummel' up in my big dictionary. Must have been old-fashioned in 1944 because it's an archaic spelling of 'Pommel', which includes the meaning 'boss'. Pommel and pummel are interesting. To pummel is to beat, and the pommel of a medieval sword (the round ball on the end of the handle),  is used to balance the blade and hammer people.
Edited By SillyOldDuffer on 25/10/2020 12:10:07
JasonB25/10/2020 12:23:59
19087 forum posts
2100 photos
Was the boss fixed to the sprocket by expanding the end Pummel "beat" may be appropriate
blowlamp25/10/2020 12:36:51
1442 forum posts
97 photos
Here's mine in MoI.
Martin.
Steve Withnell26/10/2020 16:58:02
821 forum posts
217 photos
Thanks Jason, helpful as ever.
Much appreciated.
Steve
Engine Builder26/10/2020 17:59:54
233 forum posts
This site has all the Meccano original part drawings. I have made some parts using them.
Meccano Drawings
Steve Withnell27/10/2020 12:10:31
821 forum posts
217 photos
Started drawing my version - thing I can't work out is how to establish the centre for the 0.125inch radius? The valley and 'flat' on the tooth I can work out, but finding the centre is defeating me!
Steve
JasonB27/10/2020 12:17:12
19087 forum posts
2100 photos
I did not find it but could measure from my drawing. I drew a 0.250dia circle and made it tangental to the 0.046" one for the valley and then also made it pass through (coincident) one end of the 0.015" arc.
Edited By JasonB on 27/10/2020 12:21:12
EngineDIY
