Milling attachment for Warco wm290vf
Any opinions?
Brian Boyle 123/10/2020 16:55:09
6 forum posts
I am thinking of buying the milling head that fits on the back of the 290vf lathe.
Has anybody got one. what are the disadvantages compared to the full wm16 mill?
JasonB23/10/2020 16:57:19
21322 forum posts
2423 photos
Small size table and lack of any fine feed along the X axis would be the two main drawbacks.
mgnbuk23/10/2020 17:55:26
1031 forum posts
69 photos
Surely the normal lathe carriage feeds are available ?
Remove the lathe chuck to avoid getting caught by it, select a suitable carriage feed and direction, engage the half nuts (or feed shaft if applicable) & run the lathe spindle to feed the carriage under the separately powered milling head. What would normally be considered the lathe Z axis would become the milling machine X axis.
Still have the small table & lack of rigidity normally associated with a "proper" milling machine, though.
Nigel B.
JasonB23/10/2020 18:24:45
21322 forum posts
2423 photos
That's OK for power feed but unless you have the ability to stop exactly at the end of a non through cut then you are faces with how to move the carrage a small measured amount, carrage handwheel dial is only good for 0.020" divisions and does not have much feel for putting on a couple of thou cut or touching off on an edge. This is where a handle on the end of the leadscrew and a 1thou div dial helps like you can find on a Myford or My old Emco for example.
Edited By JasonB on 23/10/2020 18:25:49
jimmy b23/10/2020 19:18:31
737 forum posts
42 photos
I had a milling head on my SC4.
The powerfeed was great, but simply not solid enough.
I ended up selling it and putting the money towards a "proper" mill.
Jim
Dave Halford23/10/2020 19:25:30
1678 forum posts
19 photos
Correct me if I'm wrong here.
You save £300 and gain power feed, but-
Assuming you have to take the topslide off, you still get a tiny table with 2? short tee slots and you have 50mm more height/leverage before you can mount anything compared to the WM16.
I would expect it to chatter like crazy.
Cabinet Enforcer23/10/2020 19:46:26
106 forum posts
You would need a DRO or the x-axis on the leadscrew will drive you potty. The table size is a masive compromise, and you can't realistically keep a vice mounted either.
I think the only reasons to buy one are either a very specific usage case which fits in the machines envelope, or having no space at all for a mill, as I think it is probably slightly better than using a vertical slide.
I seriously considerered getting a milling head for my 280 but I knew I would just get frustrated with the compromise and stuck out for a mill, it was the right decision.
Brian Boyle 123/10/2020 20:16:56
6 forum posts
Thanks for your thoughts guys. It looks like a proper mill is the way to go.
walker midge
Dreweatts
JD Metals
rapid Direct
