riveting
Peter Etherington 222/10/2020 18:42:25
21 forum posts
Just wondering if I could use one of those cheap 1/2 ton arbor presses to set rivets in some thin plate. Peter
Andrew Johnston22/10/2020 19:21:27
5750 forum posts
662 photos
Depends on the rivet size and material?
Peter Etherington 222/10/2020 19:41:51
21 forum posts
1/16 brass rivets to sandwich very thin stainless and thin aluminium
Edited By Peter Etherington 2 on 22/10/2020 19:44:10
JasonB22/10/2020 20:07:21
19178 forum posts
2107 photos
Should be OK on the stainless but you may find that the aluminium tends to bulge outwards if the rivits are near an edge.
Peter Etherington 223/10/2020 10:37:58
21 forum posts
Thanks very much. Peter
DMB23/10/2020 11:55:48
1040 forum posts
Hi Peter,
Not done much riveting but one occasion the formed heads had a sort of collar and the pre - formed heads likewise, if I remember, it was many years ago. I was advised by a fellow member who trained as a school metalwork teacher to buy a riveting snap set from the same source as the rivets. Then one should fit the other properly. Unfortunately my supplier at that time, ol' Chas. Kennion now long gone! So I would need to try what I still possess or get new lot.
Regarding your query, if in doubt, try out what you want to do on some spare bits of identical metals and of course, same thickness(es). You could have some difficulty as JasonB said above, asthe metals are dissimilar, one being soft as chewing gum and the other considerably harder.
HTH and good luck,
Peter Etherington 223/10/2020 12:42:20
21 forum posts
thanks john
Martin Kyte23/10/2020 13:38:32
2132 forum posts
37 photos
Chas. Kennion now long gone! ?
Not so much gone as evolved into GLR Kennions
Unless you are talking about a different Kennion
regards Martin
Edited By Martin Kyte on 23/10/2020 13:38:58
EngineDIY
