Mixed Metals
Simon Neath 221/10/2020 20:44:37
3 forum posts
HI
I am building the Clayton Wagon and have come to the crossheads.
I only have one gun metal casting, don't ask I don't know what happened to the other one. Would it be a problem if I made the other one from brass or should they both be the same material and if so why apart from looks?
Thanks in advance
Chris Gunn21/10/2020 22:08:37
339 forum posts
24 photos
Simon, crossheads are made from gun metal so they wear well, brass will not wear anywhere near as well, could you get a lump of bronze or gunmetal and use that?
Chris Gunn
Simon Neath 221/10/2020 22:36:58
3 forum posts
Hi Chris
Thanks for the advice I have a lump of bronze I can use
Simon
Paul Lousick21/10/2020 22:57:09
1585 forum posts
594 photos
Gunmetal is a variety of bronze and formerly used for making ordnance (guns).
Modern admiralty gunmetal is composed of 88 percent copper, 10 percent tin, and 2 percen zinc and is used for gears and bearings that are to be subjected to heavy loads and low speeds. It withstands atmospheric, steam, and seawater corrosion and is suitable for valves, pump parts, and steam fittings.
EngineDIY
