Unimat 3 vertical mill/drilling attachement pulley
Alan Gosling20/10/2020 13:08:08
6 forum posts
Hi, I have received a Unimat 3 lathe and vertical drilling/milling attachement. Everything is in good order except the drive pulley for the vertical attachement is broken.
Anyone know where i can get a new one or can someone supply me the sizes so i could make one on the lathe? The pulley appears to be screwed on and at present the remaining bit has not been removed.
Alan
JasonB20/10/2020 13:22:18
19098 forum posts
2100 photos
1 articles
Have a word with Pro Machne tools, they list a metal replacement.
Alan Gosling20/10/2020 13:28:09
6 forum posts
thanks that is excellent
JasonB20/10/2020 13:31:06
19098 forum posts
2100 photos
1 articles
If you do want to make one it's the same as the lathe Or you could just swap them over as needed
Alan Gosling20/10/2020 13:51:50
6 forum posts
Thanks for confirming it is the same as the lathe
not done it yet20/10/2020 13:57:59
5124 forum posts
20 photos
At over £43, I expect you will make one?!
I have a whole string of ally pulleys.  I would send you one at cost (might not be economical, depending on your location) if I have one of the right size.
Edited By not done it yet on 20/10/2020 14:01:41
John Olsen20/10/2020 21:37:58
1104 forum posts
91 photos
1 articles
On my Unimat 3, of nearly 40 years vintage, the pulley thread on the vertical attachment is 12mm by 1mm pitch. The one on the lathe spindle is of course 14mm by 1mm pitch, so that you cannot use the lathe pulley on the vertical spindle. Later production may of course vary, and it would have been a sensible idea if they did later make them the same . I made a set of toothed belt pulleys for my machine, which is quite a worthwhile modification.
Incidently, the speed ratings on the nameplate are purely the product of somebodies fevered dreams and the actual speeds are totally dependent on the load anyway. This does not seem to matter much in practice.
Alan Gosling21/10/2020 15:58:02
6 forum posts
Posted by John Olsen on 20/10/2020 21:37:58:
Thanks John my machine wiill be about that age as well. I have now sourced the correct pulley and about to post seperatly for anyone else
Alan Gosling21/10/2020 16:05:39
6 forum posts
Posted by JasonB on 20/10/2020 13:22:18:
I have now found the correct pulley after several emails to emcomachinetools.co.uk Vertical pulley for unimat 3 vertical attachement
EngineDIY
