LED lamp innards
Roger Hart18/10/2020 15:32:05
142 forum posts
31 photos
p1040365.jpgp1040364.jpgHad trouble with 20W led bench lamp flickering, been that way a long time, finally swapped lamp and chopped open the offending item. Cut away the grey goop potting stuff and...
Inside is a typical power supply based around a BD3216 chip. A close look shows the mains fuse ended in a dry joint with a black burn mark. Also L3 the buck inductor is missing, it came away with the potting - it too seemed a bit cooked. The mucky soldering on the led assembly is original.
From a quick trace of the circuit the transformer is part of the Vcc power supply and feedback loop.
Now to think of a use for it...
walker midge
Dreweatts
JD Metals
rapid Direct
