Myford M Type tailstock alignment
How to go about it please?
Chris V10/10/2020 10:00:12
262 forum posts
41 photos
Good morning all,
I have finally mounted up my Myford M type and have found the tailstock is a tad out of alignment.
I have been looking at test bars, the 1MT to fit this lathe seem only to have 4" or 100mm of straight, plus the MT section. Could someone please explain how you go about aligning the tailstock? test bar in the tailstock? Some other method between centres?
Not having experience of this I'd have thought a longer bar between centres would be the way to go, but I just don't know?
Chris.
Ady110/10/2020 13:56:14
3939 forum posts
522 photos
I just line up a couple of dead centre points for general work
Unless you have a brand new machine then the bed will be worn and the error varies with distance
Use a DTI for more accurate work
Only do mega-accuracy when you have to, especially on an old hobby machine
GL
edit: The AK47 rattles like a box of screws when you shake it because of the tolerances... but it's apparently been quite a successful and reliable product, high accuracy isn't always required
Bazyle10/10/2020 15:29:24
5556 forum posts
207 photos
The only thing a Morse test bar is necessary for is checking that the morse socket is aligned with the spindle bearings. Nothing else and you can do that with a DTI anyway. If you put a round bar in the 3 jaw and gently turn a little off the eaxtremity it will be by definition aligned with the spindle over that bit. You can then compare that to the periphery of your tailstock barrel with a DTI top an side. Helps to make the turned portion the same dia as the barrel but not essential.
Bear in mind next time you sneeze it will go out of alignment so don't sweat over it.
Chris V10/10/2020 15:56:13
262 forum posts
41 photos
Thanks Ady1, thats a fair point well made.
Thanks Bazyle, ok I will leave off buying a test bar for now. Yes I don't think dropping the tailstock on the bench helps either...oops!
Chris.
David George 110/10/2020 16:17:18
1381 forum posts
448 photos
Hi Chris I use a dial indicator mounted on a piece of bar in the chuck. I put it on to a center or inside the Morse taper.
When you rotate the spindle it will show the amount you are in error and it is easy to adjust sideways . You should always put in a piece steel in the chuck and turn it parrallel  to check headstock for misalignment without a center.
David
Edited By David George 1 on 10/10/2020 16:22:36
Chris V10/10/2020 16:42:39
262 forum posts
41 photos
Hi David,
Ah thank you, I like it!
I got a second hand dial indicator, when I depress the tip the needle appears a bit sticky, is this normal or should I be looking for a better one would you say?
Chris.
David George 110/10/2020 16:59:54
1381 forum posts
448 photos
Hi Chris if the needle sticks it won't tell you if it is true or not. What make is it perhaps a bit of a clean will help. I had one which stuck sometimes and a soak in a cleaning solvent and a good vigorous work at the same time worked wonders after it dried out. If not perhaps a new one?
David
Chris V10/10/2020 17:24:59
262 forum posts
41 photos
Thanks David,
Yes that's what I thought but thought i'd best check! I will post photos later or in the morning, I think I have two types with different tips...
Chris.
Howard Lewis11/10/2020 09:03:20
3757 forum posts
If you can find an alignment bar that is accurately centred at both ends, Tailstock alignment can be checked by mounting the bar between centres and adjusting the Tailstock until the DTI reading is the same at both ends.
Yoiu can make your own alignment bar by taking the largest diameter of bar, prefereably silver stee, or prcision ground bar. The bar is passed therough the hedastock mto leave very small length sticking out of the 4 jaw chuck. The chuck is adjusted to centre the bar to the level of accuracy which you consider acceptable. This procedure is then repeated for the other end of the bar. You then have your alignment bar.
Mount between centres and align the tailstock, .
If the bar is slender, as it will be for a 1 or 2 MT Headstok bore, use only minimal end load on the centres to avoid introducing any bend.
Chris V11/10/2020 10:22:26
262 forum posts
41 photos
Good morning David & Howard,
So attached are my two second hand indicators, the larger one is a bit sticky but if the plunger is part depressed then actually it seems ok. The Verdict one has a different tip?
Howard, thank you something like this was in the back of my mind. Its the small bore size creating the issue in my head at least, you would think there is a market for between centres test bars especially for those with smaller lathes but I cannot locate one online?? I was wondering if to make one if I got a larger dia ground bar say 1" or so, one end in the 3 or 4 jaw chuck and then centred the far end say 12" long accurately within a fixed steady, drill the centre and then reverse the bar and centre drill the other end. Does this seem a reasonable way to do it?
Chris.
Nicholas Farr11/10/2020 10:33:08
2477 forum posts
1198 photos
Hi Chris, this test bar has centres at both ends and the parallel part should be long enough to test for centre alignment 1 MT Test bar
Regards Nick.
Chris V11/10/2020 11:47:03
262 forum posts
41 photos
Hi Nick,
Thank you yes I have found plenty of these but I'm after a longer one around 12". Have found one in Ali this morning but I shall not be buying that, must be a steel one somewhere?!
Regards Chris.
David George 111/10/2020 12:35:08
1381 forum posts
448 photos
Hi Chris the verdict DTI woulc be perfect to set the center. How good is the chuck on your lathe if it is reasonable ie within a few thousands of on inch you can put piece of 20 mm steel in the chuck and just turn it parallel with a sharp tool and measure it end to end and see what you get.
David
Edited By David George 1 on 11/10/2020 12:35:34
Chris V11/10/2020 14:12:49
262 forum posts
41 photos
Thanks David, good to know about the Verdict one, I shall take a closer look at getting that set up. I don't know as yet about the chuck, once I got the lathe running the one thing I noticed was the tailstock being out so was concentrating on that. With the method you just describe how much metal protruding from the chuck would you suggest given no tailstock is being employed?
I was just re acquainting myself with L H Sparey's The Amateurs Lathe and see the method I suggested using a fixed steady above is described in the text, so I must have remembered that! Also a method without using a test dial but a sharp tool in the toolpost and a sheet of white paper to aid seeing whats what,...this could be more my level right now! (-:
For checking the dia of a turned piece, is a micrometer (which I have not got) the correct tool or a digital Vernier caliper?
Chris.
Chris V11/10/2020 14:24:59
262 forum posts
41 photos
Hi again David, I just realised you didn't actually say don't use the tailstock, I just assumed!
Thanks
Chris.
David George 111/10/2020 15:14:08
1381 forum posts
448 photos
Hi Chris I just noticed you havn't got a micromiter. I have a spare 0 to 1 inch if you want it I have dropped you a message with my email addresses. I couldn't work without one to get things accurate you will struggle with a caliper.
David
Bazyle11/10/2020 15:34:17
5556 forum posts
207 photos
The plunger type of dti can suffer from gooey oil on the sliding portion. As mentioned try a little solvent. If you feel inclined to oil it don't use slideway oil, preferably use minimal clock oil which is designed to not dry out.
roy entwistle11/10/2020 15:43:34
1268 forum posts
All you need is two centres and a magnifying glass. Years ago we turned a centre in the chuck, put a hard centre in the tailstock and trapped a steel rule between the points
Chris V11/10/2020 16:19:21
262 forum posts
41 photos
Thanks Bazyle, yes good point, I have some light sewing machine oil I can use.
Thanks Roy, the rule trick is how I found out it was out of line! Compound magnifying glass is already on order (-: plus another for spare for when I cannot find the compound one!
Chris.
Howard Lewis11/10/2020 17:26:08
3757 forum posts
Whereabouts are you Chris? In UK I hope.
One of us could get a piece of sturdy, say 1" dia Sillver steel (which will be 13" long ) and make one for you if you like. My lathe will pass 1" through the Headstock. The larger diameter will be stiffer and less likely to bend with any pressure from the centres, or to sag under its own weight..
If its not too far, you could come and see the whole process, if you wanted It shouldn't take too long
Or maybe someone closer to you would do it.
But you need not to be claustrophobic, or fastidious!
Howard..
Edited By Howard Lewis on 11/10/2020 17:26:43
EngineDIY
