Odd Spanner
‘Adjustable’ 10-22mm
RichardN03/10/2020 12:12:11
117 forum posts
11 photos
Random question- anyone come across a spanner like this before?
Actually it is effective, and varies from 10-22mm. I assume continental origin based on the spelling and metric nature, and was found in a gutter years ago.
Surprisingly useful, but never seen similar for sale? The irregular hexagonal ends rotate on the pins, in case that’s not obvious!
Clive Foster03/10/2020 12:23:29
2459 forum posts
81 photos
There are several variants of this design floating around. I've handled two and seen at least three more illustrated / pictured.
As you say they are effective but can be a pain to get on the nut or bolt head. Hopeless with the modern tapered all ways integrated bolt head & washer systems but can be very good on damaged heads.
I din't particularly miss mine when it disappeared on loan.
David Hill 503/10/2020 12:24:03
23 forum posts
I have a set of three to cover quite a size range. No idea where I bought them, might have been in Germany as I lived there for 15 years a couple of decades ago. Actually, can't ever remember using them as my first choice is always a proper spanner or socket!
roy entwistle03/10/2020 12:27:14
1268 forum posts
I think I've seen them in Aldi, some time ago. I've certainly seen them before
Bo'sun03/10/2020 12:48:05
233 forum posts
Looks like an "Ideal Home Show" special. Bought because it looked good at the time, but then just languishes in a drawer somewhere, because a regular spanner is more convenient.
Rod Renshaw03/10/2020 13:09:54
196 forum posts
+1 for the Ideal Home Exhibition special. Worked OK for a time but snapped when it met a tight nut, and not really missed as it had a tendency to chew up the nuts.
Rod
Jeff Dayman03/10/2020 14:10:00
1914 forum posts
45 photos
The slang in German for that wrench type, at least in Augsburg area, is "mutternwracke". Translated to English, it is "nut-ruiner" (for good reason).
not done it yet03/10/2020 14:25:53
5124 forum posts
20 photos
Not the exact one, but I have one or two in one of my toolboxes... Rarely used.
peak403/10/2020 14:33:36
1244 forum posts
144 photos
I do have a couple of those somewhere, but never been that impressed with them.
Cromna ones however, whilst no longer made, really do work well; they grip rusty and rounded fasteners, as well as round bar if used carefully. Available in sizes 1-4.
Cromna Front
I've not reproduced the photos here to save clogging up the forum storage, but there's a few either side of that photo in my flickr album.
There's also a few extra ones in my Facebook album if you have access to that particular social media.
Bill
MC Black03/10/2020 23:36:30
43 forum posts
I have one.
i think I bought it from Radiospares around 40 years ago.
i think I know where it is too!
Howard Lewis04/10/2020 14:39:54
3757 forum posts
Have number of this sort of spanner, almost all unused, but seemed "A good idea at the time"
If the worst comes to the worst, a "footprint", Stilson or Mole wrench usually do the trick,, but at the expense of the the appearance of the piece being rotated.
Grindstone Cowboy04/10/2020 16:04:14
357 forum posts
28 photos
Have a very cheaply made version (no idea where from, I certainly didn't pay for it) that twists out of shape when used for anything even slightly tight.
I think the basic idea is good, if properly made. I prefer my Adjust-a-Box wrench though.
Rob
Peter G. Shaw04/10/2020 16:52:20
1190 forum posts
44 photos
I have one as in the photo at the top. On one side it says "#A210 Taiwan 3/8-13/16"" (yes one set of double apostrophes from the spanner, and one from me).
On the other side it says " (Strange symbol I can't reproduce) 15-22 MASTER9-14 N".
The heads are chromium plated, and coming off, whilst the main handle looks as if it might be chrome-vanadium.
Peter G. Shaw
Tim Stevens04/10/2020 17:42:29
1271 forum posts
There are many variations of self adjusting spanners around - in general it seems true to say 'They fit every nut equally badly'. But still, 100% better than stillsons - unless you have no regard for the skin on your fingers.
And in case anyone has forgotten, the double apostrophe after a number often means inches. Or it did in the good old days.
Cheers, Tim
Peter G. Shaw04/10/2020 17:48:44
1190 forum posts
44 photos
No Tim, I hadn't - I just wanted to be clear that it wasn't a typing error.
Peter G. Shaw
EngineDIY
