Throw away slot drill
BOB BLACKSHAW29/09/2020 10:58:42
339 forum posts
68 photos
Hello, I have just recieved a 1.3mm Clarkson slot drill,this will be used on brass only. On the box it states throw away, I understand that its difficult to resharpen a small cutter but I've seen this before on larger slot drills, its HSS I know that I won't throw it away.
Bob
JasonB29/09/2020 11:25:58
18901 forum posts
2082 photos
1 articles
The fact that they cost less than a fiver makes it uneconomical for industry to sharpen them so more cost effective to replace hence the FC-3 type are known as throw away. I sharpened some on the ARC EMG-12 when I had it for test.
Roderick Jenkins29/09/2020 11:26:57
1945 forum posts
503 photos
Dennis Chaddock designed the Quorn tool and cutter grinder to enable these small cutters to be sharpened for making his model of a BRM engine.
Rod
old mart29/09/2020 13:45:17
1997 forum posts
151 photos
Tony at work used FC3 1/8" end cutting throw aways to cut an axial locking pin hole on the inside of Hercules C130J propellor hubs. The holes were half in the aluminium hub bodies and half in the rear of the inconel studs which held the hub onto the gearbox output shaft. Not a job for the inexperianced or faint hearted. He used a huge SIP jig borer.
Edited By old mart on 29/09/2020 13:46:54
EngineDIY
