3/16 Cast Iron Rod
Nick Clarke 328/09/2020 10:42:21
889 forum posts
30 photos
Needing some for the day job, is 3/16 (or metric equivalent) cast iron bara commercial product?
Through a scientific equipment supplier it is silly money so am looking to see if an alternative is available
Stuart Bridger28/09/2020 11:06:06
476 forum posts
26 photos
25mm seems to be the smallest diameter stocked by most suppliers
Rik Shaw28/09/2020 11:15:43
1367 forum posts
373 photos
If I wanted cast iron that small I would find myself an old fire grate basket and turn down some of the bars.
Rik
Speedy Builder528/09/2020 11:33:56
2112 forum posts
146 photos
I seem to remember having that stuff at School, experiment to show how steel expands and contracts on cooling. A bar was heated between a couple of fixed points, a test piece of cast iron was slipped into an eye of the bar at one end and as the bar contracted on cooling, it would snap the test piece.
Circlip28/09/2020 11:42:41
1198 forum posts
Can't get into scrap yards anymore, sash weights must be breathing a sigh of relief. Do you know anyone with a broken machine vice???
Regards Ian.
JasonB28/09/2020 11:49:18
18921 forum posts
2082 photos
I've never seen 3/16" sash weights and not seen CI bar sold in smaller than 25mm
Circlip28/09/2020 11:56:35
1198 forum posts
Well turn it dear Elmer dear Elmer well turn it dear Elmer dear Elmer turn it!
Ian.
Brian Wood28/09/2020 12:27:37
2271 forum posts
37 photos
Circlip,
What a heap of cast iron turnings that would create bringing a sash weight down from about 35 mm diameter to a little under 5mm while at the same time hoping it isn't full of inclusions and holds together while you are working on it.
It is a curious requirement anyway and even in sound material it will be about as fragile as egg shell in that size.
I doubt you could machine it successfully over a length beyond an inch or so. Maybe Nick's scientific supplier is quite right to charge properly for such material!
Nigel Bennett28/09/2020 13:09:40
362 forum posts
11 photos
3/16" cast iron would present great difficulty in manufacture, as it would chill spectacularly and you'd end up with something ferrous that would snap if you looked at it. It would also be extremely difficult to machine. It's simply not practical to make it. Having said that, if some multi-national wanted to produce it by the mile, they'd find a way of doing it.
So I'm afraid you're going to be knee-deep in cast iron dust!
Nick Clarke 328/09/2020 13:41:40
889 forum posts
30 photos
and:-
Is exactly what I would like to use it for, but not at £12 for 6x2" pieces
Pete White28/09/2020 14:37:24
116 forum posts
14 photos
I went to a poor school, no snapping of cast iron there. We had a bar between fixed supports,with a threaded end, the strongest lad in the class would tighten the nut, after heating a slight slender girl would then come on stage and tighten the nut more with ease. You would have to pick the participant differently these day of course and do a full risk assessment due to the heat. laugh
I remember it well,I was that lad, reined by self confidence for years. lol
Pete
p.s. now we have the whole horse to ride, can I suggest that it doesn't have to be cast iron?
Frances IoM28/09/2020 15:27:25
834 forum posts
26 photos
does it have to be round - I have a couple of feet of 6" by 1" cast iron which was easy to get though relatively expensive as compared to steel - saw off 5mm or so then slice on a mill or saw into square section ?
Nick Clarke 328/09/2020 16:21:09
889 forum posts
30 photos
Posted by Pete White on 28/09/2020 14:37:24:
The issue is that it has to be something that doesn't break according to the children's perception, so no plastic, glass or ceramic and that doesn't leave a lot that appears to be unbreakable and strong, but where there is sufficient force as the bar expands or contracts to snap the sample.
Brian H28/09/2020 16:30:40
1806 forum posts
105 photos
Cast iron welding rods are available in 6mm; the problem will be getting a small quantity, unless you need a box full!
Nick Clarke 328/09/2020 16:39:59
889 forum posts
30 photos
Posted by Brian H on 28/09/2020 16:30:40:
I didn't realise they were cast iron - I thought they were high nickel steel
Brian H28/09/2020 16:46:42
1806 forum posts
105 photos
Cast iron can be welded with either a nickle filler of an S.G. iron one.
SIF seem to do S.G. iron rods in either 6 or 10mm
Hope that helps
not done it yet28/09/2020 16:54:12
5034 forum posts
20 photos
I would expect a short length of suitably heat treated high carbon steel would fail with a suitably sudden and noisy mode of failure?
Maybe there might be a few flying fragments, safety pecs and behind a screen for them and also some for you should suffice. Care with safety is possibly one reason for the high price of basically a shear pin. Do you pour cold water over the heated bar to speed things up?🙂
Sleight of hand is a good ploy for experiments such as this - distribute rusty examples of annealed pins for some to try and break, but use a ‘hard as glass’ pin in the experiment.
I used to do the same with a challenge of catching a small rod as it fell through and out of a copper pipe. The magnet had to look like the rod.🙂
Edited By not done it yet on 28/09/2020 16:54:45
Frances IoM28/09/2020 17:22:23
834 forum posts
26 photos
another source of cast iron is brake pads - just looked at a set of 4 I bought for a ?1 at auction in case I could use them looks about 10mm slab bonded to the steel carrier - maybe local garage can supply some worn pads
JasonB28/09/2020 17:27:41
18921 forum posts
2082 photos
I would not have thought a SG Iron rod would break like a grey iron one.
The experiment should work with say 25mm long rod which would not be hard to turn from some sliced up larger good quality grade 260 bar
John Reese29/09/2020 05:35:13
847 forum posts
I have a large amount of cast iron welding rod (R-CI). It is about 3/16" dia. The finish is sand cast and the halve are slightly offset (mold mismatch). I don't see how they could be used for anything but welding. If you need a smooth cast iron rod I suggest you find a larger diameter and set up a hollow mill on the lathe to reduce the diameter.
EngineDIY
