Axminster SX2 LED Work Light
Kevin McCarthy27/09/2020 18:03:25
3 forum posts
Hi,
I have recently aquired a 2018 Axminster SX2 Mini Mill and have added a Round LED Ligh to the Spindle Top. I would like to power this via the machines 12vdc Supply rather then having another external power supply. Can anyone suggest a safe take off point on the PCB that I can do this with out damaging any of the boards in the process? I beleive J1 on the main PCB Terminals 1 &2 have a 12vdc output but dont want to damage anything if this output is sensitive etc?
Thanks for any advice you can give
Kev
noel shelley27/09/2020 18:50:51
116 forum posts
Hi first check the output of the power supply and the rating of the led you want to use.There may not be spare capacity. I would be wary, for what a small 240 to 12v transformer would cost plus a small rectifier and smoothing condenser I would start from scratch. Or plan B, use a redundant power supply form almost anything or an old battery charger( this may need a bit of smoothing) that gives 12v dc.
Good luck Noel
Kevin McCarthy27/09/2020 19:24:46
3 forum posts
Hi Noel,
Thanks, I am bit weary of connecting anything to the mills PCB's in case of any issues etc. I'll go with a seprate plug in 12vdc to power the LED thus removing any risk to the Mills PCB's. These are avaliable easily from ebay etc. The LED is an SMD 60mm rated at 12v-24v Angle Eye for Automotive so is going be a low wattage rating pos 40ma but havent checked this, fits great on the Mill
Thanks for coming back me
Jon Lawes27/09/2020 20:14:21
403 forum posts
I concur, better to blow a cheap PSU than your milling machine PCB.
Kevin McCarthy27/09/2020 21:43:00
3 forum posts
Thanks Jon, yer I think the Boards on the SX2 can fail if you play with them not knowing the in depth electronics of them
Cheers Kev
EngineDIY
