Horizontal hit and miss engine
Andy Gray 326/09/2020 22:06:29
24 forum posts
I asked a question about cylinder oilers on here a few days ago that JasonB was good enough to answer.
Here's the engine that I've been working on. It is my own design, and scratch built from bar stock using my 7 x 14 Chinese lathe.
Thank you.
Edited By Andy Gray 3 on 26/09/2020 22:08:01
Emgee26/09/2020 22:12:31
1729 forum posts
232 photos
Hi Andy
That looks good and runs exceptionally well, is it just on fuel vapour ?
Emgee
Henry Brown26/09/2020 22:48:17
297 forum posts
83 photos
Very nice Andy, well done!
Did you make the fuel tank? I have a similar task imminent and would be obliged for any tips.
Andy Gray 326/09/2020 23:17:30
24 forum posts
Posted by Emgee on 26/09/2020 22:12:31:
Thank you! smiley
It has a fixed choke carburettor (fuel mixer?)  with a simple spray bar and needle valve that draws liquid fuel (Coleman fuel) from the tank.
Fuel mixer
Edited By Andy Gray 3 on 26/09/2020 23:19:27
Andy Gray 326/09/2020 23:39:57
24 forum posts
Posted by Henry Brown on 26/09/2020 22:48:17:
Thank you also! smiley
The tank body is chromed brass bathroom waste pipe. (I had an off-cut).
I wanted a brass bodied tank, but the price of brass tube seemed horrific - more expensive than solid bar of the same size. I tried all sorts to strip the chrome off the bit of pipe I had and failed, so ended up just using it as it was - it turned out OK!
The ends of the tank were cut out of ~2.5mm brass sheet and both faces of each end were turned. prior to assembly, using superglue to hold them to a piece of faced-off aluminium bar in the manner of the Clickspring Youtube channel:
  • Centre punch brass sheet, scribe circle, saw roughly to size, then glue to the 'face plate' using a centre in the tail stock to locate the punch mark on centre,
  • Turn the OD and face off to leave a small pip in the centre. Machine a small shoulder to fit inside the tube.
  • Remove from faceplate and glue the opposite face using the pip to centre in a suitable hole in the 'faceplate'
  • Face off and round corners.
  • Remove from face plate. The pips stay on the inside faces (but nobody can see them wink)
These were a nice, tight fit in the tube, and I just soft soldered them on (one at a time) by laying a ring of 0.5mm multi-core solder inside the tank and gently heating until it flowed into the joint, The second end had to be done 'blind', but it worked OK. (The bosses for the filler and fuel off-take fit through holes drilled in the tube and were soldered on from the inside with plumbers solder before fitting the ends.
I hope that makes some sense!
Another edit for a photo:
Edited By Andy Gray 3 on 26/09/2020 23:41:26
Edited By Andy Gray 3 on 26/09/2020 23:45:01
Edited By Andy Gray 3 on 26/09/2020 23:48:48
JasonB27/09/2020 07:07:38
18919 forum posts
2082 photos
Now that is a good runner and looker too, usually I'm not keen on the barstock and cap screw look but you have executed it very nicely particularly with those recessed heads..
I also like the easy way that the lever over rides the governor latch while the engine is running.
Brian Baker 127/09/2020 07:54:53
134 forum posts
27 photos
Very good Andy, could that be written up, with drawings, for publication in Model Engineer?
Henry Brown27/09/2020 08:09:52
297 forum posts
83 photos
Thanks for such a detailed description about the fuel tank Andy, I'll be using a similar method! I plan to roll a sheet of brass to make the tube and then solder the ends in. Still not sure how to make the log joint between the ends yet so a bit of experimentation before I start I guess.
I just re-watched the video and it really is a credit to you, you must be very pleased with the end result...
Baz27/09/2020 09:34:18
476 forum posts
+1 for seeing it written up in Model Engineer, I am sure quite a few people would like to make one, a very nice looking engine, well done Andy.
Andy Gray 327/09/2020 11:41:46
24 forum posts
Thank you all very much! smiley
I'm not sure what would be involved in writing it up - I have (rudimentary) drawings for ~90% of it, but didn't take many photos during the build.
(I hesitate to confess that I haven't looked at the Model Engineering magazine since my father dabbled in model engineering in the early 1980s - there were plans for a shuttle valve engine from a small traction engine that my father and I started building at night school.)
Ron Laden27/09/2020 12:11:54
2010 forum posts
401 photos
Excellent and such a sweet runner, it also speaks volumes for what can be achieved on a Chinese Mlini Lathe.
Great stuff.
Ron
Jim Nic27/09/2020 13:25:22
271 forum posts
163 photos
That's really nice, well done.
Jim
Andy Gray 327/09/2020 22:06:30
24 forum posts
Thank you! smiley
Mike Poole27/09/2020 22:19:16
2750 forum posts
64 photos
A very attractive engine, not everything needs to look as though it was built by the Victorians. I like it.
EngineDIY
