5BA Threads
Mike Donnerstag24/09/2020 19:33:04
191 forum posts
40 photos
I'm sure this should be an easy question to answer. I understand that the nominal diameter of a 5BA thread is 0.126" (3.2mm). Is the actual external thread diameter (e.g. of the average 5BA bolt) less than this and, if it is, why is this?
Unfortunately I don't have any to measure, though I do have a 5BA tap and split die, which of course are impossible, or at least not easy, to measure. I suppose I could tap a 5BA hole and adjust the split die to cut an external thread to fit it, and then measure the resulting external thread??
If there are any instrument bowmakers reading this, I have been told that the Hill workshops used a modified 5BA thread for their violin, viola (and possibly cello) bow screws. However, my limited experiments point to it being a straight (unmodified) 5BA.
Any information very much appreciated,
Edited By Mike Donnerstag on 24/09/2020 19:34:01
Edited By Mike Donnerstag on 24/09/2020 19:34:23
Sandgrounder24/09/2020 19:40:55
200 forum posts
6 photos
This should help.
https://www.ring-plug-thread-gages.com/PDChart/BA-thread-data.html
Clive Brown 124/09/2020 19:47:20
506 forum posts
18 photos
I've just measured several 5 BA fasteners purchased via the ME trade. They measure between 0.122" and 0.123" od. I would expect commercial tolerances to be slightly below nominal size.
Mike Donnerstag24/09/2020 20:03:32
191 forum posts
40 photos
That answers my question - many thanks chaps!
Mike Poole24/09/2020 21:27:00
2748 forum posts
64 photos
5BA is handy for threading 1/8” rod.
Martin Kyte24/09/2020 22:20:03
2066 forum posts
37 photos
As I was completing the assemply of a small brass bracket yesterday using a couple of 6BA countersunk hex socket screws it struck me that these must be as rare as hens teeth these days.
I inherited the Lab's old stock of BA fasteners about 20 years ago so they are possibly as much as 50 years old by now, maybe more. I did have the passing thought that maybe I should not be quite so profligate with them but then realised how little the stock had gone down over the last 20 years maybe not.
Someone is now going to astonish me with a supplier no doubt.
regards Martin
Bob Stevenson24/09/2020 22:31:14
437 forum posts
7 photos
As a youngster I was told that BA threads were outmoded and "archaic" and that when I was old I would be able to cast back my memory and remember such a weird pointless thing like old timers then could remember the Boar War.........
But here we are all these years later and BA is still very much alive and indeed, has become more alive during the last ten years or so......In the horological world there are no plans to replace BA and nothing to replace it with as fine metric does not, in practice, turn out to have the same facility or 'feel' in the work.
Keith Long24/09/2020 22:31:46
846 forum posts
11 photos
Posted by Martin Kyte on 24/09/2020 22:20:03:
Yes, Cromwell Tools have them in their catalogue, you might be a bit shocked at how much they cost though.
Brian Morehen25/09/2020 18:11:34
124 forum posts
11 photos
Yes I broke my 6BA taper tap 60 yrs old rpaced from Cronos Tools Cost £1.40 ,
Regards Brian
Dell27/09/2020 08:10:15
41 forum posts
13 photos
I have just received some 5BA cheese head steel screws for a french clock, from EKP Supplies £3.50 for 25 they have steel and brass different heads and lengths.
Dell
Michael Gilligan27/09/2020 08:47:54
16397 forum posts
715 photos
Posted by Bob Stevenson on 24/09/2020 22:31:14:
As a youngster I was told that BA threads were outmoded and "archaic" and […]
Presumably told by someone who didn’t appreciate the sophistication of the thread-form
Blessed are the ‘Bean-Counters” ... ?
Rod Renshaw27/09/2020 10:26:53
174 forum posts
+1 for EKP screws.
They make many of the screws themselves on Swiss automatic machines, all controlled by cogs and eccentrics etc., and which must be almost antiques by now.
Rod
norm norton27/09/2020 13:56:14
134 forum posts
7 photos
BA Bolts have one of the biggest ranges, and he makes a lot of his own.
Martin Kyte27/09/2020 15:38:32
2066 forum posts
37 photos
Posted by Keith Long on 24/09/2020 22:31:46:
Wow, at £2.75 each for the 6BA hex socket countersunk I'm sitting on a fortune not to mention all the other sizes and varieties.
:O)
Martin
Dusty27/09/2020 16:18:21
479 forum posts
8 photos
O.K. if we are boasting, I have a few 7ba socket head cap screws, where did they come from? I hear you say, I wish I could remember.
Clive Brown 127/09/2020 16:48:47
506 forum posts
18 photos
Reeves sell some even BA cap screw sizes at rather less cost.
Bob Stevenson27/09/2020 17:02:44
437 forum posts
7 photos
https://www.hswalsh.com/search-products?search_api_views_fulltext=BA+screws
https://www.cousinsuk.com/product/ba-sizes-assorted
Edited By Bob Stevenson on 27/09/2020 17:05:25
Martin Kyte27/09/2020 17:03:15
2066 forum posts
37 photos
Posted by Clive Brown 1 on 27/09/2020 16:48:47:
Not countersunk hex socket screws they don't
regards Martin
Mike Donnerstag27/09/2020 23:21:07
191 forum posts
40 photos
Having done considerable investigation and experimentation, I found that many threads used for instrument bow screws were in fact modified by over-tightening the die to reduce the major diameter from 3.2mm to 3mm. This was true of the 5BA screws and the 5-40 UNC ‘Inch thread’ screws and means that the standard tap is too large.
Can anyone give any tips on making custom 3mm diameter taps?
Do any bowmakers on here know whether these ‘special’ taps are available anywhere?
Many thanks,
Michael Gilligan28/09/2020 01:20:55
16397 forum posts
715 photos
Posted by Mike Donnerstag on 27/09/2020 23:21:07:
This is all rather bewildering, Mike
In trying to ‘catch up’ ... I have just found this page: **LINK**
https://elcoda.com/bow-screw-250938.html?language_code=en
... which seems to present another ‘variation on the theme’
[quote]
Bow Screw with Rolled Inch Thread, Bronze Eyelets, Violin, Viola, Cello
These bow screws are finely-crafted in the style of the great French bow makers.The rolled thread allows the thread portion of the screw to have a larger diameter than the shaft portion.
Violin,Viola - dimensions 74 mm, thread 1,8", shaft diameter 2,7 mm.
Cello - dimensions 80 mm, thread 9,64", shaft diameter 3,0 mm
[/quote]
Can you provide any close-up photos of typical specimens of what you are working with, please ?
P.S. There are crucial differences between the BA and Unified thread forms, so I think this merits serious further investigation.
EngineDIY
