Vacuum Pump Advice Please!
SillyOldDuffer24/09/2020 16:55:32
6331 forum posts
1389 photos
Another fine mess I've got myself into. I'm building a clock (which doesn't work yet) intending to run the pendulum in a vacuum. Years ago I bought an Edwards 3B vacuum/compressor from a nice man at a car boot sale who assured me it was a high-vacuum pump. Was he a naughty fibber?
Got it home, fired it up for a quick test, seemed to work but not good today. The motor runs but the compression and vacuum fail to impress. No manual or info on the web.
Suspected it needed oil and have the right sort. Sprayed myself & workshop, I think by filling the pump through the wrong hole at the top. Fortunately the big output filter was off and the oil came out without fuss. On second thoughts this type of pump may be medical, and not meant to be oily.
Opening it up revealed a rotor with four fibre vanes running in an offset circle - a vane pump.
The black nozzle top right photo above is for the vacuum hose. Below near the base is a plastic screw screw cap covering a felt pad with access to a chamber filled with coarse fibre: could be a filter, or an oil pad. Anyone know if this is the oiling point? The pump would have to be tipped sideways to use it.
Just underneath and to the right of the black vacuum connector is a big spring loaded slotted steel screw ending in a rod fitting into a hole. It probably communicates with the vacuum side - see below. I think it's a valve of some sort. Anyone know what it is?
The vanes don't seem worn and there's no physical damage inside to speak of.
As the pump is covered in cooling fins and has a 500W continuous motor I was expecting a more powerful vacuum and better compression. Have I bought the wrong pump and am I expecting too much?
All help and suggestions gratefully received!
Ta,
Edited By SillyOldDuffer on 24/09/2020 16:55:53
Oven Man24/09/2020 17:25:15
70 forum posts
8 photos
Are the vanes free to move in and out? They might be spring loaded or move out under centrifugal force.
Peter
Dave Halford24/09/2020 17:29:49
939 forum posts
9 photos
You've not said the vanes are free to move? beaten to it
This sounds like to be an oil trap for the bearing breather, perhaps to stop it pumping all the oil out.
It's a lab pump link
Edited By Dave Halford on 24/09/2020 17:30:16
Ian Parkin24/09/2020 17:33:52
840 forum posts
202 photos
I do deal with a lot of pumps like this in the print industry and never considered them to be high vacuum
usually the ones i work with are dry with carbon vanes
older ones were steel bladed running with oil and an oil separator a bit like a hydro vane pump
anyway check that the vanes are free to slide in and out and don’t expect much of a vacuum with it..
SillyOldDuffer24/09/2020 18:27:07
6331 forum posts
1389 photos
Oh dear, not to expect too much of it - the worst answer!
The vanes slide in and out freely - no springs. The construction doesn't seem to provide much of a seal at the ends which implies low compression. Could be it's a dental spit sucker, designed to run continually without enough power to disembowel anyone!
Got a vacuum gauge and a pressure either of which would show how good or bad it is - both are Absent With Out Leave.
crying
Martin Cargill24/09/2020 18:49:07
147 forum posts
It looks like a dry pump, As Ian Parkin mentioned the oil pumps tend to have steel vanes. The vanes you have should be free to move in their slots. The Felt pad etc is probably a filter to remove worn vane debris from being blown out by the pump. The slotted screw is probably a vacuum valve (the reverse of a pressure valve) to stop it drawing too much vacuum .
Martin
Ian Parkin24/09/2020 19:15:16
840 forum posts
202 photos
I’m sure that the fibre vanes need lubing
small offset machines used to have “Gast “ pumps which had fibre vanes and a small (50ml) glass jar on the inlet side with a pipe cleaner into the oil and inlet to lube the vanes
Steviegtr24/09/2020 19:28:21
1515 forum posts
163 photos
The ones i used to PAT test in labs looked like that. The more powerful types i would have thought, would be the ones used to vac down air conditioning units to remove moisture.
Steve.
Roger Hart24/09/2020 19:35:11
125 forum posts
30 photos
looks a decent pump, if a bit small. Should get to about 1mm mercury on a small tight chamber.
On the inlet side the vanes sweep oil+air round and compress the air to be exhausted. There is no valve on the inlet side. On the outlet side there is usually some sort of reed valve. The old slow pumps had a neoprene flap, I have seen a steel reed valve on faster pumps. These sometimes break and don't work.
There is sometimes a bleed valve to let air into the pump on the inlet side to help degas the oil and 'give something to chew on'. Usually this can be screwed up tight shut.
The vanes run immersed in oil but not too much - say 3/4 full. Ordinary 20/50 oil works OK, Edwards oil v pricey.
The drive shaft sometimes has a simple oil pump - waggling rod in off centre groove to pump bearing oil. Take care to put this back right. Otherwise, if the vanes are not stuck there is not much to go wrong. Gaskets not usually used but some older pumps used a lick of shellac on the mating faces.
Slightly worried about running a clock in a vacuum chamber, outgassing etc. Not at all easy to get a really good seal, not really a vac once and forget job. Still - enjoy.
As said in ATM books, high vacuum is a technique that makes figuring mirrors look easy - and I agree!
True high vacuum is in the 10^-5 and beyond region, think turbo pumps etc.
Bill Davies 224/09/2020 19:37:54
197 forum posts
11 photos
Do you need a 'high' vacuum Dave. The vacuum pump I used as a school technician would remove enough air that a buzzerl was all but silent, but would be nothing like the vacuum required for making bulbs, electronic valves (tubes), sputter aluminium onto mirrors or the like. I can't recall the pressure that it went down to, but a surprising amount of air had to leak back into the bell jar when the valve to the atmosphere was opened.
Bill
Robert Atkinson 224/09/2020 19:53:34
772 forum posts
17 photos
The EB3A is classed as a high vacuum but i't's relative. Specification seems to be 26" Hg / 133mB. So pretty good. Certainly good enough for a pendulum enclosure. It's not an oil free pump but is not wet/oil sealled. The wet ones have a "sump" cover over the pump block with a level glass. The Black plastic "cheese head" screw is normally the oil filler on Edwards pumps. Was the wadding wet with oil? If so it likely that is the oil filler.
Most likely issue is leacking or stuck valves. These will be poppet or reed (possibly combination) type.
Robert G8RPI.
Robert Atkinson 224/09/2020 19:58:16
772 forum posts
17 photos
I crossed with Rodgers post. His description is correct for the wet vacuum pumps like the speedi-vac and EV range. As the EB3A will also act as a compressor I'd expect it to have valve on inlet and outlet but I've never had one apart.
Robert G8RPI.
John Haine24/09/2020 20:41:04
3345 forum posts
178 photos
According to Wikipedia the Shortt free pendulum tank was evacuated to 30mm mercury - ~39 mBar.  In 1984 Pierre Boucheron did some measurements of the stability of a Shortt pendulum electronically impulsed using one preserved at NIST in Colorado.  Apparently the tank vacuum was intact after something like 30 years.
Edited By John Haine on 24/09/2020 20:49:30
Edited By John Haine on 24/09/2020 20:51:58
old mart24/09/2020 21:16:37
2000 forum posts
155 photos
That Edwards pump is capable of going down to 133mB, which may not be enough for your requirements.
John Haine24/09/2020 21:53:24
3345 forum posts
178 photos
Depends on the requirement. The Shortt ran at very low pressure to maximise Q, but even at lower vacuum the Q increase will be worthwhile and it should eliminate barometric rate variations.
SillyOldDuffer26/09/2020 18:49:23
6331 forum posts
1389 photos
Pleased to report the pump is much better.
Took it apart again and went over it carefully. There are no valves.
I believe the improvement is down to putting oil in the right place. Not just a lubricant, I believe it's part of the sealing system. When the pump is running I think oil is pulled out of the padded reservoir and into the gap between the cylinder end and the rotor block where it fills the gaps and makes it difficult for air to leak past the rotor blades. I cleaned a thin layer of caramelised oil off the end-face that may have stopped oil flowing into the gap properly.
Anyway, the pump now pulls a markedly stronger vacuum on a rigid cylinder. Wish I could find the missing gauge to see how good or bad it is!
not done it yet26/09/2020 19:45:44
5026 forum posts
20 photos
I had two speedivac pumps in the back of my car this last week. One turns, the other doesn’t, at the moment. One will get sold, if it works, and the other will certainly go for scrap if it won’t free off (they are heavy). You could have it if you were local...
I have one in operating condition that I have used for degassing wines. It pulls a hard vacuum.🙂
EngineDIY
