Using End Mills
Chris TickTock21/09/2020 17:11:44
586 forum posts
41 photos
Hi Guys,
Provided you have a centre cutting supply of end mills is there a rule of thumb as to when you should mill downwards as to sideways. Take for example you want to bore a 1mm radius in mild steel the end mill would likely bend if you used it sideways on. But does this apply to 3mm or 6mm and is there an accuracy implication/
Chris
JasonB21/09/2020 17:19:50
18868 forum posts
2069 photos
1 articles
Simple rule of thumb is that when using the full width of the cutter don't use a depth of more than D/4 that's diameter divided by 4. You can go a lot more than this particularly as cutter dia increases but stick to D/4 for now.
So for your 1mm dia cutter you could go sideways if milling the half circle in say 0.2mm thick brass shim using a single pass but would not want to do that if it were 3mm gauge plate you were cutting. Even if plunging don't do it in one go with a small cutter like that gradually move the work sideways say 0.1mm per plunge
Either way do as suggested in the other thread and drill a 1mm hole then file or mill back to half way.
Edited By JasonB on 21/09/2020 17:34:59
Chris TickTock21/09/2020 18:01:21
586 forum posts
41 photos
Posted by JasonB on 21/09/2020 17:19:50:
Thanks Jason but although this is related to that thread this post is for a different purpose it is for milling in small radius in a cutter to improve accuracy of milling. Up to I would guess 4mm then moving the end mill out straight to leave parallel front edges during production stages. So in this case drilling a hole is not going to work on its own.
For example if I wish to put a 3mm radius on the end of a 6mm square piece of silver steel I could align the cutter above the stock and mill down but there is a remnant at the front to remove which to date it seems in error I have removed by moving the end mill though the entire 6mm thickness.
Hope all this makes sense, if not a will put up a drawing.
Chris
JasonB21/09/2020 18:18:32
18868 forum posts
2069 photos
1 articles
put up a drawing
Chris TickTock21/09/2020 18:24:18
586 forum posts
41 photos
radius sketch.jpgPosted by JasonB on 21/09/2020 18:18:32:
put up a drawing
Hope this helps. Remember this has to be fairly precise. As I said I would be minded to say put the 3mm dia end mill to the side of the stock, zero hand wheel, then raise the end mill move in the specific amount plunge cut and move forward to remove front remnant. Is this the wrong way to do this Jason/
Chris
JasonB21/09/2020 18:40:07
18868 forum posts
2069 photos
1 articles
Again a lot will depend on thickness of the material being cut, if thin (less than 1/4 of cutter dia) make one pass from the end.
If thick then you have two options, firstly set the cutter to take the whole 1.5mm width then lower the cutter say 0.75mm then take a cut stopping at a specific handwheel reading which looks like it would be 4.5mm from the end of the work then back the cutter out of the work. Lower it another 0.75mm and feed in again to your handwheel position.
The other method for thicker work would be to use more of the side of the cutter but less width typically 1/10th the dia, So locate the end and edge of the work, move work 0.3mm sideways and then feed in to your set handwheel position then back out. move over another 0.3mm and take the next cut and so on. The disadvantage of doing it this way on a cut that does not go right to the far end of the work is that as you get towards the full width there will be a larger area being cut as you get to the handwheel position (cutter engagement) and this can make the tool chatter resulting in a poor finish on the curved part of the cut. The main advantage is it uses more or the cutting edges so you get more use out of the cutter rather than just blunt the end.
I would not use a plunge type cut for that shape.
Edited By JasonB on 21/09/2020 18:41:39
Emgee21/09/2020 18:45:45
1709 forum posts
225 photos
Chris
If you use a 6mm diam cutter it will give you the 3mm radius in 1 operation and you are less likely to break the cutter.
Emgee
JasonB21/09/2020 19:49:01
18868 forum posts
2069 photos
1 articles
here you go Chris, the two methods I describe in previous post but using an 8mm cutter rather than 3mm as it's easier to see.
First option I'm doing all the required width eg half the cutter dia in this case 4mm by D/4 = 8/4 = 2mm height each pass
Second option hull height but 10% of cutter width 8/10 = 0.8mm per pass.
Both stopping 6mm in from the end.
Chris TickTock21/09/2020 20:30:16
586 forum posts
41 photos
Posted by JasonB on 21/09/2020 19:49:01:
Many thanks Jason and others will chew over this tomorrow. I don't have DRO so iby hand tIwill introduce error I suspect. Truly wonderful video.
Chris
JasonB21/09/2020 20:49:23
18868 forum posts
2069 photos
1 articles
Should not get any error unless user generated. I just used DRO as it was easier to show what was going on particularly doing it one handed.
EngineDIY
