Greensands | 06/09/2020 16:56:52 |
329 forum posts 69 photos | Hi all - I need to carry out a largely cosmetic repair on an aluminium casting as a result of a being a little too hasty on the milling machine. Essentially it would a (small) gap filling exercise but before resulting to using Araldite or similiar I would like to explore the possibilities of a soft solder repair as it would be a good excuse to try a new (to me) technique. Has anyone had any experience of soldering alumimiun and able to offer some suitable suggestions, e.g source of alloy, soldering tools etc. required for the job? |
Grindstone Cowboy | 06/09/2020 17:07:02 |
854 forum posts 64 photos | I have successfully used Lumiweld for repairing motorbike castings, so it might be OK for this. Bought a kit many years ago, but I'm assuming it is still available. Rob |
JasonB | 06/09/2020 17:08:24 |
![]() Moderator 22579 forum posts 2637 photos 1 articles | Cup do a flux for use with standard soft solders on aluminium as well as a cored solder specifically for aluminium |
peter smith 5 | 06/09/2020 17:11:44 |
93 forum posts | Hi Chronos do a kit inc wire brush to remove oxide. There was a company a few years ago that did the exhibition circuit selling a similar product which was excellent . If repairing a crack don’t forget to stop it with hole. Pete |
J Hancock | 06/09/2020 17:18:50 |
832 forum posts | Technoweld is the 'go to' , expensive if it is a big hole but easy to use without requiring huge amounts of heat. |
Brian Wood | 06/09/2020 17:20:20 |
2549 forum posts 39 photos | A Google search for aluminium welding gives plenty of choices for low temperature 'brazing' joints using bars made from zinc/aluminium alloy. Lots of videos showing how it is done too I was sceptical and tried them on extruded square section aluminium with success, the repair on a casting should be even better. Scrubbing the joint area with a stainless steel wire brush is the key to a good joint Brian |
Andrew Tinsley | 06/09/2020 17:47:15 |
1610 forum posts | Hello Jason, I have always used technoweld / lumiweld for soldering aluminium. I have just followed up your lead on Cupalloy. They certainly do a flux for aluminium. However the only solder that they sell for aluminium, says that it is only for pure aluminium and aluminium / copper alloys. Is there any solder that works for the type of alloys that we commonly use? Regards, Andrew. |
henryb | 06/09/2020 18:22:10 |
![]() 51 forum posts 3 photos | I ordered some off ebay earlier. aluminium brazing solder it melts at 300 degrees. you don't need flux with them. i think they are johnson mathey ones. the seller is called ablemablecrafts. |
JasonB | 06/09/2020 18:22:56 |
![]() Moderator 22579 forum posts 2637 photos 1 articles | From what I can remember of Keith's posts on the subject any of the soft solders can be used with the Harris flux but the problem is postage costs. This is why they also do the cored one as that can be posted at normal rates. Hopefully Keith will see the post and comment. 6082 (HE30) that we commonly use does contain copper though in far smaller amounts than something like 2014 |
Martin Kyte | 06/09/2020 18:35:11 |
![]() 2725 forum posts 48 photos | Rivet or loctite a plug into the casting and remachine perhaps? Or my all time favourite if it's a small defect, drill and tap a suitable size, add a grubscrew and stamp OIL underneath. regards Martin |
SillyOldDuffer | 06/09/2020 19:07:08 |
Moderator 8491 forum posts 1891 photos | I've successfully soft soldered copper wires to Aluminium following Neil's advice which is to splash the area with thick oil, scrape the oxide off under the oil with a screwdriver, and then solder as normal with a big electric iron. It's the oxide layer that makes Aluminium difficult to solder and it forms almost instantly in air. Soldering works provided the joint is made before the oil burns off and lets air in. You can't pussyfoot with a small iron or use a flame because the oil fails before the Aluminium gets hot enough. I used a 200W solder gun. No idea if it would do for a cosmetic repair. Dave |
Greensands | 06/09/2020 20:26:19 |
329 forum posts 69 photos | A lot of very useful help and advice given here - Thanks for that. It would appear that my best options would be to use either the Lumiweld 5 rod + Wire Brush Kit or to try Alsol, the flux cored solder sold by Cup Alloys. I should have said that the cosmetic treatment involves filling a line gap from the inside of a concave shell casting typically 0.020" thick x 1" long which after soldering would be filed down to maintain the external profile. |
Emgee | 06/09/2020 20:55:51 |
2404 forum posts 285 photos | ![]() A lot of very useful help and advice given here - Thanks for that. It would appear that my best options would be to use either the Lumiweld 5 rod + Wire Brush Kit or to try Alsol, the flux cored solder sold by Cup Alloys. I should have said that the cosmetic treatment involves filling a line gap from the inside of a concave shell casting typically 0.020" thick x 1" long which after soldering would be filed down to maintain the external profile. Good luck if you do go the Lumiweld, Technoweld, GAZ or any other route that requires a flame to heat the job so the rod runs, with such a small thickness of parent metal take a lot of care or you are likely to end with a hole and a spoilt casting. Emgee picture of another make of rod + flux Another product from UK Brand: Sif Product Model: RO553212 Edited By Emgee on 06/09/2020 21:00:22 Edited By Emgee on 06/09/2020 21:09:07 |
Greensands | 06/09/2020 21:14:34 |
329 forum posts 69 photos | Given the fact that there is not a lot of parent material around the line gap perhaps the best option would be the CUP Alloys Type Alusol flux cored solder having a melting range of 178 to 287deg C, quite adequate for what I have in mind provided that it 'sticks' to the casting |
Emgee | 06/09/2020 21:29:32 |
2404 forum posts 285 photos | Posted by Greensands on 06/09/2020 21:14:34:
Given the fact that there is not a lot of parent material around the line gap perhaps the best option would be the CUP Alloys Type Alusol flux cored solder having a melting range of 178 to 287deg C, quite adequate for what I have in mind provided that it 'sticks' to the casting That sounds like the safest option, vee the crack if you are going to file down to the surrounding surface, hope it goes well for you. Emgee |
Roderick Jenkins | 06/09/2020 22:05:09 |
![]() 2176 forum posts 608 photos | I used HTS2000 for this:
HTH, Rod |
Former Member | 06/09/2020 22:31:00 |
[This posting has been removed] | |
John Graham 7 | 07/09/2020 07:08:49 |
1 forum posts | Aluminium oxidizes very quickly making it hard to solder. Coat the surface with sewing machine oil. Scratch the surface through the oil with a wire brush or the blade of a screwdriver. Don't remove the oil as it prevents oxide forming. Coat the surface with soft solder through the oil. You need a lot of heat because aluminium is an excellent conductor of heat and cools very quickly. If you do aluminium brazing rub the surface of the aluminium with a brass bristle wire brush. This will remove the oxide and leave a light coating of brass on the aluminium which prevents further oxidization and helps the aluminium filler rod to stick. John |
Former Member | 07/09/2020 08:23:16 |
Danny M2Z | 07/09/2020 08:32:39 |
![]() 962 forum posts 1 photos | Lumiweld works well if one carefully follows the instructions. My first attempt restored a broken out mounting lug on an ancient DC Dart model diesel engine, Apart from the fact thet the repair is a bit darker than the original it's still working quite well 20 years later |
