Eccentric strap
Arthur Goodwin | 05/09/2020 20:05:18 |
41 forum posts 18 photos | Hi Guys Just pondering on the best way to do the eccentric strap. Do i bore to size then split and use shims or should i split first and then clamp together with the bolts before boring. Thanks in advance Arthur |
JasonB | 05/09/2020 20:12:40 |
![]() Moderator 19589 forum posts 2150 photos 1 articles | I usually soft solder two bits of brass/bronze together, mill the steps at the sides so the bolts can be fitted, then bore and finally shape the outside before melting apart. |
