Emco 8.6 - Tumble Reverse Position for Screwcutting?
Question Regarding Correct Position of Tumble Reverse for Screwcutting
Avery Neaman03/09/2020 16:21:56
4 forum posts
New Member here, my name is Avery, Hello.
I reside in the US, Los Angeles.
I have an Emco 8.6. Restoring it now. Can't find any serial number on the old girl, so I don't know how old she is.
So sorry to bother you good folks with such a simple question.
I don't have the "Operator's Manual" for this lathe.
As to Screwcutting, which position should the tumble reverse be in for cutting threads?
This lathe has an visual indication/guidance/reminder cast into the change gear case door. It shows when the tumble reverse is in the up position, less screw threads result. In the down position, more threads result.
I've tested this, and it is in fact the case. No need to reply and question this, please.
The challenge I'm facing is that the screwcutting chart inside of the change gear case, does not indicate which position the tumble reverse lever should be placed in, in order to cut screw threads based on the chart?
For information, the chart has an interesting indication:
It shows an arrow pointing to the right and "0.12 mm/U". Then there is an arrow pointing left, and "0.05 mm/U"
An answer to my question, or any relevant information, would be greatly valued.
Does anyone have an "Operator's Manual" that they could refer me to (or possibly forward a copy of)?
Finally, do any of you good folks know where I should find the serial number on her? She has the four speed Milling Head attached to the bed ways frame. I don't see any nameplate anywhere, except on the motor itself.
Thanks a million!
Avery
Thor 🇳🇴03/09/2020 18:24:35
1395 forum posts
41 photos
Hi Avery,
Welcome to the forum. There is a spare parts list here. You may be able to buy a manual from lathes.co.uk.
Thor
Edited By Thor on 03/09/2020 18:25:56
JasonB03/09/2020 18:28:30
21294 forum posts
2416 photos
Have you tried the Emco user group? used to be a yahoo one but that has changed to groups.io now.
Unfortunately I did not have the change gears for my 8.6 so never tried it and the manual went with the machien when I sold it.
Oldiron03/09/2020 19:30:33
829 forum posts
23 photos
Hi Avery. Try here >>> EMCO parts lists available so they may also have the manuals. Always worth an email to the supplier with questions. UK I know but there may be a US equivalent site.
regards
JohnF03/09/2020 20:32:31
1092 forum posts
166 photos
Hi Avery, there is an Emco section on groups.io but seems to be little regarding the 8 series but I would suggest you join and ask the question.
However if you terminology is the same as this side of the pond the tumbler reverse normally only changes the direction of travel of the carriage and thus whether you are cutting left or right hand threads. There is more detail but thats the basics.
Versaboss03/09/2020 22:58:40
470 forum posts
51 photos
I'm quite sure what Avery mentions is the push-pull knob which changes between the coarse (0.12 mm) and the fine (0-05 mm) feed .
Many years ago I owned a Emcomat 8.6, and I am absolutely sure the tumbler gear didn't change the pitch of a thread.
I would be interested to see that >>visual indication/guidance/reminder cast into the change gear case door. It shows when the tumble reverse is in the up position, less screw threads result.<<
Hans
Avery Neaman04/09/2020 00:14:20
4 forum posts
Thanks to all for every cogent and germane reply to my novice question.
Everyone is so generous with their time and information!
It seems like the EMCO yahoo group has now taking place at groups.io, indeed. Furthermore, the group is called EMCOV10lathe. The group is not limited to the V10 machines, but rather is for all EMCO machines. That is my initial take, but don't take is as any gospel, please.
The EMCOMACHINETOOLS.CO.UK website refers to having operational manuals, oh boy smiley, but there are no links to them, as opposed to the active links for parts manuals and EMCO brochures. Boohoo sad
Han ("Versaboss" has my partial answer to my question: EMCO used two different size tumble reverse gears, thus when both are interacting in the changegear gear train (with the lever in the up position), the leadscrew speed is indeed faster. When in the down position, only the smaller gear is in the train, and the leadscrew is slower.
So as Hans mentions, this gives the lathe more capability (rather ingenious I think) because when simply using the change gears to drive the power feed, the operator has at his or her disposal, two feed speeds, as Hans refers to them as "coarse" and "fine." This being then coupled with the change in direction (that's why it's called "Tumble REVERSE, afterall), and the number of screw pitches that can be cut with this "vocational" machine is doubled! The practicality of that is not understood by me, but initially, I think that the pitches generated with the lever in the "alternative" position would be of no value, unless they coincidentally happen to be Module or Diametral!!
But this doesn't answer my question: Is the tumble reverse lever supposed to be in the up or down ("coarse" or "fine" position, when cutting screws per the screwpitch diagram of the lathe?
If I had the manual (which emcomachinetoos.co.uk apparently doesn't carry, it might answer my question.
So without that, I'll just have to knuckle under and get some experience. I'll cut some test screw pitches with the tumble reverse in the up position, and then the down position, and simply count the threads!
Thanks again to all, you gentlemen are valued and appreciated! You gentlemen are kind.
Avery
Michael Gilligan04/09/2020 06:53:05
18702 forum posts
915 photos
Here’s a German version, Avery : **LINK**
https://dokumen.tips/documents/emcomat-84-86-manual.html
.... probably not convenient, but worth a look.
Edit: German PDF freely downloadable here:
https://www.emco.or.at/index.php/download/emco-bedienungs-und-serviceanleitungen/drehmaschinen/15-emcomat-8-4-emcomat-8-6-betriebsanleitung/file
Edited By Michael Gilligan on 04/09/2020 06:57:49
JasonB04/09/2020 07:09:56
21294 forum posts
2416 photos
As Hans says the tumbler reverse with it's lever at the front is just that a reverse for the leadscrew and does not alter feed rate. Up or down will move the carrage in the direction you want to cut and then return it to take the next cut.
There is also a push/pull knob sticking out the left side of the headstock that changes feed rate fron high to low as indicated by teh coarse and fine zigzag markings., I would expect that some screw pitched need this on one position and some in the other. EDIT having looked at the manual Michael posted I think it stays in the pushed in position for all thread cutting.
When I had my 8.6 the Group answered queries I had about it despite being mainly aimed at the larger machines, should still be photos and other documents in the files and photo sections of the site showing series 7 and 8 machines.
Edited By JasonB on 04/09/2020 07:24:57
Avery Neaman04/09/2020 16:34:20
4 forum posts
Thank you all for your replies, answers and information. This has been so helpful.
I think Hans had rightfully asked for pictures, but I'm having a bit of challenge finding out how to add pictures that are saved on my computer's hard drive, or my iPhone, I'll work on that next. Sorry.
Note the screwcutting chart (a little out of focus, sorry). If you zoom in you can clearly see the indications of the two feed speeds (0.12 mm/U and 0.05 mm/U). It shows a right arrow next to the 0.12 mm/U and a left arrow next to the 0.05 mm/U.
Here is a summary of what I've empirically observed:
Tumble Reverse Lever Down; Motor Forward => Carriage feeds to right at faster speed, I assume this is the "Coarse" (0.12 mm/U) speed that Hans refers to.
Tumble Reverse Lever Up; Motor Forward => Carriage feeds to left at slower speed, I assume this is the "Fine" (0.05 mm/U) speed that Hans refers to.
I also noted that the spring-loaded "pull knob" which is in the center of the Tumble Reverse lever, does not change speeds from "Coarse" to "Fine."
It simply is a safety interlock such that the knob must be pulled out before the lever can be changed from any position to another. You certainly don't want to accidentally move the lever with an inadvertent hand or arm motion, when the lathe is operating. That would be the end of the change gears and maybe other items.
So in summary, the Tumble Reverse mechanism of this EMCO 8.6 is such that when you operate the Tumble Reverse lever, you are changing not only the direction of the feed, but also the carriage feed speed.
Not reading German, I'm unable to "read up" on how EMCO designed the Tumble Reverse mechanism to work (changing both direction and speed, both at once by re-positioning the lever). But again, by observation, that is how the machine works.
And finally, I assume that since screw cutting is always done at the slowest carriage feed rate, that with this particular tumble reverse design, the Tumble Reverse lever is always in the UP position when cutting threads.
Thanks to all for your input!
Avery
Thor 🇳🇴04/09/2020 16:40:51
1395 forum posts
41 photos
Hi Avery,
Here is an explanation on how to create Albums and post photos.
Thor
JasonB04/09/2020 17:01:33
21294 forum posts
2416 photos
Avery, you must have a machine that is not like any of the others if you look at the end of the machine where the push/pull lever is you will see a coarse and fine zig zag which represents coarse or fine feeds. The tumbler only uses one or both of two gears that are the same tooth count so only changes direction not speed. Turn the chuck slowly by hand when pulling/pushing the lever as it may not drop straight into the different gear (no syncro) and will just spring back
Phpoto below shows the two light coloured gears with a green blob on teh push/pull knob, moving this will engage one of the pair of gears marked ( or ) in green so changing the feed rate. The two small white gears on the tumbler are the same size so don't affect speeds.
Images on page 32 of Michael's pdf link show the tumbler lever in the DOWN position which would be correct for the usual right hand threads.
The chart in the PDF is the same as the inside cover, top left of that chart has an image of a turning tool and the two arrows with 0.12 and 0.05 are under that so apply to FEED RATES. To the left of that there is a representation of a screw thread, the gear train below that is the THREAD CUTTING one.
Edited By JasonB on 04/09/2020 17:11:57
Pete Rimmer04/09/2020 17:10:22
1042 forum posts
58 photos
The tumbler reverse only changes the direction of the leadscrew, so it will cut a left hand or right hand thread as required. Most threads are right hand.
If the spindle and leadscrew are turning the same direction you'll cut a right hand thread. If they are turning opposite directions you'll cut a left hand thread.
Michael Gilligan04/09/2020 23:06:55
18702 forum posts
915 photos
Posted by Avery Neaman on 04/09/2020 16:34:20:
[…] or my iPhone […]
If you have the patience ... it is possible to translate that PDF using the iPhone
[ it’s not set to allow selection of the text, but we can work around that ]
  1. Take a screenshot of an interesting piece of text
  2. Use an App called Photo Translator : Translate+
  3. This will OCR the photo, and translate the text
  4. It will even read it aloud to you !
I have just tried it on the first section of page 19, using my iPad
[quote]
19th
Attaching the gear combination
Swing the scissors down after loosening the fixing screw.
1. Remove the feed gear
a) Loosen the SW10 locking screw; Take off lock washer, pull off gear wheel z = 20 and sleeve. The
Reversing heart gear z = 35 always remains on the machine.
b) Remove the feed unit. (Key area behind pull button)
c) Intermediate gear and the lead screw gear also by loosening the hexagon bolts and removing
Pull off the lock washer.
2. Slide the gearwheel z = 60 onto the turning heart bolt and then attach the sleeve. With Si
lock washer and locking screw fix the gear on the turning heart bolt.
3. Slide a sleeve onto the lead screw, attach the gearwheel z = 45 and fix it.
4. Insert the shear bolt with its slot nut into the upper groove of the scissors.
5. Slide a sleeve onto the shear bolt and then attach the gearwheel z = 80.
6. Push the intermediate gear z = 80 mounted on the shear bolt up to the lead screw gear and with
bring this into engagement. Fix the intermediate gear in this position.
7. Swing up the scissors with the intermediate wheel and with the gear wheel on the turning heart pin z = 60 in
bring a grip.
[/quote]
Not exactly ‘vernacular’ translation, but a pretty good effort !
http://aitube.doukantv.com/media/html/home/5.html
Versaboss05/09/2020 00:25:43
470 forum posts
51 photos
Reading that stuss above from Avery, (hi A. use that translator!*), I'm beginning to loose my will to live...
- the knob on the tumbler reverse lever is not the one which changes the feed speeds!!! This is on the side of the cover, see Jason's picture.
- I am old and cannot always trust my memory, but I am quite sure that for screwcutting that double gear is always removed, or in other words: a screwcutting setup never transmits over that double gear. The picture on p. 28 of the manual above shows the setup for normal turning., and the feeds 0.12 and 0.05 mm work only in that setup!
Jason displayed all very clearly in the piccies above, so I retreat now...
* ok, I do it for you: a nice word I found is balderdash...
Hans
Avery Neaman05/09/2020 14:54:01
4 forum posts
Thanks to all here, this has just helped me realize that my EMCO 8.6 is missing the "push-pull" knob for changing the feed speeds.
The photos provided are excellent.
The explanations spectacular and so well written!
I appreciate all this.
I shall "experiment" with making a temporary knob, and get to know this part of "my baby" a little better.
I'll also try to create an "album" so I can then begin attaching pictures to my posts.
FOR THE TIME BEING, gentlemen, I do not need you assistance any longer (but I bet I will in the not to distant future!), so thank you all very much, you've been most professional and courteous, thorough, and thoughtful!
Avery
rapid Direct
JD Metals
walker midge
Dreweatts
