Arduino Pendulum Clock Design - Comments Welcome
SillyOldDuffer29/10/2020 18:11:23
7139 forum posts
1572 photos
Two problems with the clock in it's latest state, which was run with reduced impulse as suggested by Duncan, and also at reduced amplitude. Should be possible to do more of the same for even better performance. One problem is how long measurements take, ideally taking at least 24 hours without disturbance. Second issue is once temperature corrections are applied to the Arduino, accuracy is similar to that of my 2ppm Real Time Clock module, which doesn't indicate fractions of a second. The most recent run illustrates the problem:
After temperature corrections are applied to the Arduino oscillator my pendulum is within 1 second of the electronic Real Time Clock over 18 hours, so I can't detect the difference. Although the calculation suggests 0.325 seconds error over 18hrs 20minutes, it's not valid because I don't know exactly when RTC seconds occur: I need to improve the reference clock. There's weak correlation between between air pressure and period, and the reference clock has to be improved to prove that's real as well.
Encouraging levels of accuracy over 18 hours aside, the pendulum is far from perfect. Amplitude and period occasionally glitch for no apparent reason. Whatever causes glitches isn't temperature, pressure or humidity - some happen when the house is empty or asleep. Of even more concern is the degree of spread around the average period: this pendulum is a noisy oscillator, cause unknown. The spikes on the bell-curve may indicate secondary oscillations or elliptical pendulum paths.
For what's worth, Allan Deviation. I don't know what the graph means!
Another long run with further reduced impulses next while I decide how to improve the reference clock. John Haine mentioned using a serial terminal to timestamp records as they arrive from the Arduino, and noted inaccuracies due to Linux multi-tasking, ie other processes delay the timestamping program. This appears to be fixable in code because it's possible for a linux program to select a scheduler profile giving itself near real-time characteristics. From the spec, it appears possible to effectively allocate a CPU core almost 100% to one process, minimising scheduler delays by forcing everything else running on the computer on to the other cores. I've written a time-stamper that gives itself top priority, but not proved it makes any difference to data capture. (It relies on the scheduler to wake it up whenever the serial port is activated, and the scheduler may be a bottleneck.)
Edited By SillyOldDuffer on 29/10/2020 18:18:13
SillyOldDuffer30/10/2020 11:16:44
7139 forum posts
1572 photos
Graphed pendulum period against air pressure not expecting anything and instead got a clear positive result:
For periods near the average it appears there is a linear relationship between period and barometric pressure.  The pendulum speeds up as air pressure rises. I think unusually high and low periods aren't affected by air-pressure, suggesting something else is going on as well.
Why the pendulum is effected by air pressure is another question. Rawlings 'The Science of Clocks and Watches' suggests:
  • Buoyancy changes - the weight of the bob (but not it's mass) falls when air becomes denser.
  • Friction between bob and air increases with pressure
  • Varying resistance as the bob causes an alternating wind inside the clock, the size of which depend on the shape of the bob and whatever else is nearby. As my bob runs in a channel, partially blocked at one end by the electromagnet, turbulence could be a problem.
Oddly, I'd expect all three effects to slow the pendulum down as air pressure increases. The graph shows my pendulum doing the opposite.
More mysteries!
Edited By SillyOldDuffer on 30/10/2020 11:19:38
Swarf Maker30/10/2020 11:58:18
107 forum posts
4 photos
Another parameter for you to consider regarding unexpected perturbations - earth tremors?
John Haine30/10/2020 12:04:03
3828 forum posts
222 photos
Hmmm.
  • As I read that graph, as pressure increases the period gets longer so the clock slows down! As the buoyancy increases with pressure so the effective weight decreases, or in effect "g" decreases and the period gets longer. Have you compared the slope of your curve with the theoretical value (which I can't remember offhand)? The effect of pressure variations is reduced in proportion to the air density/bob density, my impression is that your coefficient is rather large, it seems to be about 40uS/mbar. From my last analysis, my clock (which has a 7 Kg CI bob) has a coefficient of ~0.4 uS/mbar (with no explicit attempt at compensation).
  • A related effect is "access to inertia" caused by air carried along by the bob which increases its effective mass but not its weight - normally this is reckoned to be about equivalent to the buoyancy effect.
  • Denser air has greater resistance so amplitude ought to decrease (unless you are controlling it), which would decrease the period through circular deviation (but that does depend on escapement deviation as well). Do you have a plot of amplitude vs, pressure?
duncan webster30/10/2020 12:24:30
3180 forum posts
55 photos
I think you still have a fairly light bob, could the odd spikes be related to passing motor traffic causing mini ground vibrations?
Intuitively a light pendulum is more affected by air resistance than a heavy one as it's mass/area is smaller
SillyOldDuffer30/10/2020 13:11:54
7139 forum posts
1572 photos
Posted by John Haine on 30/10/2020 12:04:03:
Hmmm.
  • As I read that graph, as pressure increases the period gets longer so the clock slows down! ...
Doh! This is why I value the forum so much - good people correct my mistakes. I read it the wrong way round.
I can do pressure vs amplitude - watch this space.
Edited By SillyOldDuffer on 30/10/2020 13:45:17
John Haine30/10/2020 13:35:59
3828 forum posts
222 photos
Posted by duncan webster on 30/10/2020 12:24:30:
Yes, assuming it is the same physical size and shape its density will be lower.
SillyOldDuffer30/10/2020 13:43:42
7139 forum posts
1572 photos
Another correlation:
I am controlling amplitude: in this run the bob gets 1mS impulse when amplitude falls below 0.4 On average the bob does nearly 39 swings per impulse.
Not looked at last night's run yet. It's doing 500µS impulses.
John Haine30/10/2020 13:55:51
3828 forum posts
222 photos
Dave, if you could let me have a full set of results I could run a multivariate regression on them? Ideally a csv file of
<period>,<amplitude>,<temp>,<press>
Though the order doesn't matter (except that period should be the first).
SillyOldDuffer30/10/2020 14:38:36
7139 forum posts
1572 photos
Posted by John Haine on 30/10/2020 13:55:51:
Yes please! I'll produce a CSV and send you a dropbox link.
SillyOldDuffer30/10/2020 15:05:22
7139 forum posts
1572 photos
Posted by SillyOldDuffer on 30/10/2020 14:38:36:
This Dropbox Link is to a 2.4Mb CSV with fields:
Period - integer, microseconds
Amplitude - float, ratio
Temp - float, degrees C
Pressure - float, hPa
RelHumidity - float, %
Many thanks,
John Haine30/10/2020 17:32:20
3828 forum posts
222 photos
This is the R-Studio session:
> a1000pt4 <- read.csv("D:/John Haine/Documents/Personal/ME website/Dave's clock/a1000pt4.csv", header=FALSE)
> View(a1000pt4)
> Ard_dave <- lm(a1000pt4)
> Ard_dave
Call:
lm(formula = a1000pt4)
Coefficients:
(Intercept) V2 V3 V4 V5
922805.44 4035.47 -38.02 13.76 -23.56
> summary(Ard_dave)
Call:
Residuals:
Min 1Q Median 3Q Max
-6632.8 -100.9 -7.5 89.1 2285.3
Coefficients:
Estimate Std. Error t value Pr(>|t|)
(Intercept) 9.228e+05 3.148e+02 2931.72 <2e-16 ***
V2 4.035e+03 8.417e+01 47.94 <2e-16 ***
V3 -3.802e+01 1.602e+00 -23.74 <2e-16 ***
V4 1.376e+01 3.718e-01 37.01 <2e-16 ***
V5 -2.356e+01 1.137e+00 -20.73 <2e-16 ***
Signif. codes: 0 ‘***’ 0.001 ‘**’ 0.01 ‘*’ 0.05 ‘.’ 0.1 ‘ ’ 1
Residual standard error: 213.4 on 69996 degrees of freedom
Multiple R-squared: 0.05846, Adjusted R-squared: 0.05841
F-statistic: 1087 on 4 and 69996 DF, p-value: < 2.2e-16
Which means I think that: Period (us) =
922805 + 4035.47xAmplitude -38.02xTemp +13.76xPressure -23.56xRelHumid.
duncan webster30/10/2020 20:01:56
3180 forum posts
55 photos
Posted by John Haine on 30/10/2020 13:35:59:
I meant a heavy bob of the same density, it still has more mass per unit area whether that is cross section or total surface area. Air resistance must be down to area.
John Haine30/10/2020 22:14:11
3828 forum posts
222 photos
Sorry, I got confused between air resistance and buoyancy. It's slightly counter-intuitive but for a given impulse and a bob with a given air resistance, as the bob mass gets bigger and the Q increases, the amplitude nevertheless stays the same, it just takes longer to get there.
SillyOldDuffer31/10/2020 10:57:51
7139 forum posts
1572 photos
Posted by John Haine on 30/10/2020 17:32:20:....
Many thanks John. Linear regression is one of the many mathematical tools outside my reach. I'm out most of today but I think the next step is to have the Arduino apply the corrections and see what happens.
Interesting humidity has appeared as a factor. Is humidity affecting the carbon fibre rod directly, or is relative humidity itself a function of temperature and air pressure? I don't know. Correlation is not causality.
More fun tomorrow, hurrah!
Cheers,
John Haine31/10/2020 11:29:55
3828 forum posts
222 photos
Regression is a bit foreign to me too! I just use the software - apart from the strange syntax R Studio is very easy once you get used to it, and is used for heavyweight statistical analysis (such as epidemiological data...), not to mention free!
Supposedly CF road does absorb water from the air into the resin which affects the weight (not the length) but the amount is tiny and the effect usually insignificant compared to the bob - I estimated about 3 uS total for my pendulum IIRC. May be more if the rod weight and springiness is more significant. I have seen some analysis of the effect of humidity on Clock B (since it was measured) and as far as I recall it is very small:
That also has some useful information about "computer compensation".
Something I'm not clear about in my mind is just what correlation we should be looking for. Buoyancy and amplitude depend on density, but density is a function of both pressure and temperature. So should one normalise each pressure reading to absolute temperature to allow for this? There's also a small effect of temperature on viscosity which Harrison is said to have allowed for.
SillyOldDuffer01/11/2020 16:15:01
7139 forum posts
1572 photos
Posted by John Haine on 31/10/2020 11:29:55:
I'm not sure what's going on after looking at last night's run. I added "Haines Seconds" to the Arduino, which now calculates ticks as: 922805 + 4035.47xAmplitude -38.02xTemp +13.76xPressure -23.56xRelHumid and upgraded the stats program. Result of graphing Haines ticks rather than pendulum measured ticks:
Big reduction in stdev, hurrah, but the result over nearly 15hrs is 47 seconds out, which is worse than my simple correction based on averaging the arduino clock to align it with GPS seconds. I believe linear regression should do better than my method, so something's adrift. Below, uncompensated pendulum is 6.9 seconds out, and crudely recalibrating the Arduino clock brings the error over 15 hours down to under a second.
One difference is Haines seconds (from linear regression) have stronger correlations with temp, humidity and pressure when the stats are generated from them rather than pendulum measurements. I expected the regression formula to have that effect but note the correlation with pressure is more amplified. It may indicate the formula is over-compensating for pressure.
Not blaming the formula at all. It assumes the clock was set up as it was in the data file I sent, which may not be true.
Having swotted up on Linear Regression I reckon I can apply it with the software I'm using (Python Numpy & SciPy). Nothing against R except I'm not familiar with it and I'm fluent in Python. I'll be a happy man if I can get the same answer as you from the log.
Meanwhile preparing to move the clock from Arduino to Raspberry. Only necessary to get decent sub-second clock measurements, possible because the Raspberry has NTP. No need for a Raspberry once the clock has been analysed. Although Raspberries are much faster than Arduinos they don't support user-level interrupts. Not having interrupts makes coding a fast response to pendulum events harder, but I'm sure I can make it work. Transferring to Raspberry is almost a complete re-write.
Also trying to come up with a way of detecting vibration, which may be causing the time anomalies I see in the data. No luck so far, and - unlike Arduino - the Raspberry doesn't even have the basics!
Many thanks for the link to 'Clock B' - fascinating, and I clearly have a long way to go. Also been reading through your other thread, which shows I'm not a pioneer!
Cheers,
John Haine01/11/2020 16:55:48
3828 forum posts
222 photos
Ah, the regression won't remove the rate, it just evaluates the sensitivity of the period to the other variables.
SillyOldDuffer01/11/2020 17:55:42
7139 forum posts
1572 photos
Posted by John Haine on 01/11/2020 16:55:48:
I've gone a step too far again!
Ta,
SillyOldDuffer05/11/2020 14:58:45
7139 forum posts
1572 photos
Spent a massive amount of time getting a Raspberry Pi3B to drive and measure my pendulum directly. Lesson learned, when writing to GPIO pins in 'C' make absolutely certain it's the right pin. Wring to the wrong pin crashes the Pi .
Anyway the expected advantage of using a Pi instead of an Arduino was the Pi has nanosecond precision timing and good long-term stability because it regularly synchronises with GMT over the network.
I expected timing inaccuracies due to the Pi swapping my clock program in and out depending on other activity on the system (like resynchronising time!). To avoid that I programmed the clock program to have top priority on one of the 4 CPUs.  Whatever other tasks the Pi has to do run on the other three CPUs.
This works, ardclock almost flat out at priority -71, with everything else queued behind:
Alas all is not well and I don't understand it! I connected the pi to a GPS module emitting ultra-high accuracy second pulses expecting the Pi to be measure seconds to within at least a tenth of a microsecond or better. And it mostly does, but not reliably!
Although the vast majority of measurements are close to the average 1.000002784s, stdev only 0.000111703, the graph shows bursts of instability and excursions of up to nearly 1mS. Although Arduino measures with a higher standard deviation, it's less wild.
The pi is underperforming in an unexpected way - I don't know why it should wobble at the beginning, then measure well for about two hours, before throwing another wobbler.
John Haines provided source code of a different approach to measuring pps accurately with a Pi, so I shall try that. Fingers crossed.
Edited By SillyOldDuffer on 05/11/2020 15:03:19
JD Metals
