Power Hacksaw
JA26/08/2020 11:43:19
979 forum posts
54 photos
I have a cheap, horrible, Chinese band saw. It is about 17 years old, flimsy, not reliable and pretty unsafe. It also takes up quite a bit of floor space in a crowded workshop (about half the floor area of my Myford on its stand). It is used about once a week just to cut lengths of bar etc.
I want to replace it with a small, new, reliable, power hacksaw that can cut up to 4” diameter mild steel bar. However looking at the market power hacksaws seem to be out of fashion, none of the usual dealers stock them. I don’t want to make one (I have a Hemingway kit which is too small) and I do not want to waste time refurbishing something like a Rapidor saw.
If I remember well someone a few years ago posted a thread about buying a rather nice Italian saw but I cannot find it.
Please can anyone advice me?
JA
AJAX26/08/2020 11:51:16
41 forum posts
22 photos
I wouldn't discount the possibility of finding an old but perfectly serviceable trapdoor power hacksaw. Apart from rewiring the motor I did nothing to mine and I've been using it for years. It was probably 80 years old when I got it!
DMB26/08/2020 12:04:30
1013 forum posts
JA,
I remember a bench mount bandsaw somewhile ago. It looked a smart jobbie but I thought very expensive and why do I want another when I had the floor mount Warco bandsaw, still in use today. Didn't follow it up as 2 seemed extravagant and lack space. Lots of designs on internet, one simple design I'm thinking of making to utilise my large stock of hacksaw blades. Kennedy hacksaws look attractive but they are probably all knackered and need refurb.
AJAX,
What do you mean by "trapdoor" hacksaw? I take it that means reciprocating frame?
peak426/08/2020 12:07:29
1184 forum posts
143 photos
Posted by DMB on 26/08/2020 12:04:30:
The perils of autocorrect.
I'm guessing Manchester Rapidor; quite large though.
I do have a Rapidor Minor which uses 9" blades and takes up a bit less room.
Bill
Simon Cook26/08/2020 12:42:12
15 forum posts
15 photos
You could build one......
Hemingway kits have a very nice one if that floats your boat. See here:- **LINK**
Usual disclaimer here, just a very happy customer. I've actually built this, and it's a very nice kit and drawings.
Mike Poole26/08/2020 12:47:14
2735 forum posts
64 photos
The Italian manufacturer Femi make some highly regarded compact bandsaws, Stakesy supply in the UK. They have been mentioned in threads on this site.
JA26/08/2020 12:55:07
979 forum posts
54 photos
Thanks Mike.
I think that is what I vaguely remembered.
JA
Dave Halford26/08/2020 13:04:27
909 forum posts
9 photos
Kennedy 90 ( the one with the reinforced vice) is your only bench top hacksaw option, but quite rare and some are junk
JA26/08/2020 13:05:22
979 forum posts
54 photos
Just had a look at Femi and Stakesy web sites. They no longer sell hacksaws but Femi make some rather nice small portable band saws.
Food for thought.
JA
Clive Foster26/08/2020 14:01:58
2361 forum posts
76 photos
For all practical purposes a 14" blade, 6" cut Rapidor takes up the same space as the common 6" x 4" cut horizontal / vertical bandsaw. Near enough 3 ft x 1 ft 6, my bandsaw is a touch narrower than the Rapidor I use but I built a cabinet on wheels to replace the inadequate stand and managed to shave an inch or so off the width. For me its more about having somewhere to poke the long bar than saw size per se.
Seems that Rapidors are almost impossible to wear out so long as they see a dash of oil occasionally. Pivot pins in the blade return relief system and in the clutch gubbins on older flat belt ones seem to be about all that does routinely wear. Both my Rapidors suffer so. Got two 'cos I tripped over a complete, late one in full running order at a price too low to ignore about a fortnight after obtaining an older one in need of a motor and darn good scrub for the proverbial 3 pints and a packet of woodbines if you pull it out from the old greenhouse! 5 barrow loads of dried leaves later ... Should a bought a camera.
Kennedys do wear over time and most are now past their best. Realistically more of a saw for heavy duty plumbers, building site, tube et al work than bar cutting in the shop.
AJAX26/08/2020 21:38:55
41 forum posts
22 photos
Posted by peak4 on 26/08/2020 12:07:29:
Bill
Manchester Rapidor. Auto correct on my phone strikes again!
IanT26/08/2020 23:17:17
1600 forum posts
150 photos
"It is used about once a week just to cut lengths of bar etc. "
I have the Aldi bandsaw which sits nicely on the bench and (apart from the crappy vice) seems to work very well for 'light' work. Your use sounds fairly 'light' to me JA?
I also have an old McMaster power hacksaw, which needed some effort to become usable. It will chew through just about anything - day in and day out - and the vice is large & very solid. It's on castors and doesn't take too much room. It's big and heavy and not exactly 'delicate' in use - which is not a problem for most things.
I wanted the Aldi mainly for use as a small 'vertical' band saw and I've built a holding frame for that but not made a replacement table as yet. The supplied vice generally works but occasionally doesn't - and whilst it's only "un-gripped" on me once, that was once too many. So I've fitted a 'clamping' plate instead of the sliding jaw and I'll see how that works out in practice but really I need to finish the vertical table where the vice isn't required anyway.
So there are very good (but more expensive) bench band-saws out there, the Aldi is OK for light duty (and less than half the price) and there are big, old power hacksaws that will probably need some time and TLC spent on them. As usual, you pays your pennies and makes your choice.
IanT
Mike Poole26/08/2020 23:27:51
2735 forum posts
64 photos
My Rapidor was a bargain, £27 and advertised as 3 phase, it was single phase and still wearing its original paint in good condition from 1974, it had the latest motor gearbox and made by Alexander. Very pleased with eBay purchase.
Paul Lousick26/08/2020 23:32:42
1537 forum posts
578 photos
JA,
I use one of these weekly and it will cut 4" steel. It is compact, sits on top of a milk crate as a stand and can be picked up with one hand.
Paul.
JA27/08/2020 17:52:38
979 forum posts
54 photos
Paul
What make is it? I am thinking of buying a small Femi saw.
JA
Craig Brown 227/08/2020 18:34:13
26 forum posts
8 photos
JA,
I suspect Paul's saw is a Femi but rebadged. I have the same saw badged up as Clarke, originally sold in Machine Mart. I purchased it second hand and I first thought it was probably a knock off of a Femi but the original sale sticker price was still on it of over £300.
The saw is very compact but very capable
Craig
Paul Lousick27/08/2020 23:22:02
1537 forum posts
578 photos
Hi JA,
Not sure of the make. I biught it about 6 -7 years ago from an ebay seller in Australia and the name has come off. There are a few advertised on ebay.
The round item in my pevious post is a tube of bees wax, used to lubricate the blade.  The saw had done a lot of work and still performs well. Only had to replace the blade guide rollers which are only standard ball bearings.
I paid about A$350 but now they are normally selling for about A$650.  Just found this one advertised for A$396.
Paul
Edited By Paul Lousick on 27/08/2020 23:31:56
JasonB28/08/2020 08:22:11
18819 forum posts
2065 photos
Bit late to this but I find my Femi very good Cuts all metals with ease eg 2" dia EN8 in just over 60secs with less than a 10thou cleanup cut needed to face it off. I got mine from Stakesys others have had issues with the likes of Amozon supplying from Europe.
Ron Laden28/08/2020 08:37:42
1996 forum posts
397 photos
I have the small Femi SN105XL, although compact it has 4 inch capacity and I have found it to be excellent, very good vice on it to.
Also got mine from Stakesys.
John Haine28/08/2020 09:55:25
3320 forum posts
176 photos
+1 for Femi, excellent.
EngineDIY
