Stainless steel
colin hawes26/08/2020 11:11:09
515 forum posts
18 photos
Worn out windscreen wiper rubbers contain two inserted springy stainless steel strips ~ 2.5 x 0.8mm x blade length and easily removed .More free metal for the model making supply!
Bo'sun26/08/2020 11:16:16
202 forum posts
Hi Colin,
A man after my own heart. I salvage nuts, screws and washers from most things destined for the scrap bin. Sad isn't it? However, any other suggestions for free stuff are gladly welcomed.
J Hancock26/08/2020 11:53:02
451 forum posts
Disposable lighters for miniature O rings /springs /ball.
Printers , where new printers are cheaper than ink replacement !
David George 126/08/2020 11:58:15
1333 forum posts
447 photos
The little wheel from lighters make small knurling tools.
David
Jouke van der Veen26/08/2020 16:39:39
55 forum posts
7 photos
Hi Collin,
I also keep some steel strips from windscreen wipers available. Just this afternoon I found such a strip that had fallen down from the top of the tool cupboard on my workbench. Until now no application for these strips.
Jouke
larry phelan 127/08/2020 16:48:13
820 forum posts
17 photos
Something wrong when it,s cheaper to replace the printer than the ink !!
Must be one Hell of a rip-off somewhere along the line.frown
Steviegtr27/08/2020 17:09:04
1488 forum posts
154 photos
Posted by larry phelan 1 on 27/08/2020 16:48:13:
Yes it's like when you buy a new printer it comes with ink cartridges with just a bit of ink in them.
I only use HP printers now , as the cartridges for some are stupendous.
Steve.
jimmy b27/08/2020 17:15:13
671 forum posts
38 photos
I think the "nearly empty cartridge" is just an urban myth.
The money is made out of the repeat buying of ink, much like a lot of consumer products.
Jim
SillyOldDuffer27/08/2020 17:17:53
6322 forum posts
1384 photos
They're doing it on purpose. Cars, computers and electronics get better year on year, but domestic printers get worse and worse. Unreliable expensive ink gobblers because the profit is in the consumables and regular replacement. Chipped half empty ink cartridges that can't be refilled; ink wasted by constant 'cleaning', paper jams, and pipes and nozzles that gum up. Office printers are much better and ink is cheap, but they're expensive to buy, not worth it unless you do lots of printing.
I've switched to a black and white laser printer for letters etc and have photos done on the internet.
sad
KWIL27/08/2020 17:31:27
3308 forum posts
63 photos
At least on Canon printers you can reset the chips.
Stuart Bridger27/08/2020 17:39:03
476 forum posts
26 photos
After getting completely fed-up with endlessly buying HP ink cartridges at no small cost, I moved to an Epson Ecotank based printer. Still using the original bottles of ink a year later with plenty still available
Brian H27/08/2020 17:45:36
1794 forum posts
108 photos
I did a cost analysis (very roughly) and concluded that HP Instant Ink was the way to go. The printer tells HP when ink is getting low and sends a new cartridge and a bag for sending the old cartridge back to France (postage paid).
The cost for 50 pages a month is less than buying cartridges for my other printer, but I keep it because it does A3 printing.
S.D.L.27/08/2020 18:24:43
220 forum posts
37 photos
Posted by Stuart Bridger on 27/08/2020 17:39:03:
+1 Done the same been using it 2 or 3 years of fairly heavy B&W use and only on second bottle of ink.
Steve
Tim Stevens27/08/2020 18:25:17
1268 forum posts
The pump-type hand wash bottles seem (when rinsed properly) to be ideal for oil in the workshop. And within the pump is a stainless spring - very handy.
Cheers, Tim
mark costello 127/08/2020 20:13:13
607 forum posts
12 photos
The almost empty ink cartridge included with a new printer is no urban myth here, buying commercially refilled cartridges is also worthless as 2 of them have been empty, 2 out of 2 for a loss. One store made it right, another did not. Switching to a laser printer when these cartridges are spent.
Anthony Knights28/08/2020 08:26:26
427 forum posts
185 photos
+1 for the Ecotank. I've had one for about 18 months and still using original ink bottles.
Nick Clarke 328/08/2020 08:40:48
883 forum posts
30 photos
A new inkjet printer with separate ink tanks and head will need to fill the head from empty but will indicate that the cartridge needs replacing when the cartridge is itself empty. The replacement cartridge will not need to do this so appears to print more pages that the original ones supplied.
Regarding colour laser printers sometimes a part filled set of cartridges has been supplied with the machine amongst the 6 I look after, but I really can't give a reason why as surely to produce the lower capacity cartridges in smaller quantities must cost the manufacturer more per item.
The other piece of advice learnt the hard way is to use an inkjet printer. If left standing heads clog up and replacing them is not economic. The printer is junk. If it is a printer where the head is part of the cartridge you do not have this problem, but the cartridges are then very expensive - a genuine HP colour cartridge with integral head for one of my printers is now £70 and the black £50. And remember if buying genuine HP it may still be recycled - hence the HP Instant ink system.
Nick Clarke 328/08/2020 08:47:06
883 forum posts
30 photos
Posted by mark costello 1 on 27/08/2020 20:13:13:
While colour laser technology is good remember that it is not photo quality and photo paper is not compatible with a colour laser printer. If you wish to print photos (the only job I still use an inkjet for) ink jet is the only domestic solution available.
Nicholas Wheeler 128/08/2020 09:49:13
390 forum posts
20 photos
Posted by SillyOldDuffer on 27/08/2020 17:17:53:
A business model that goes back to 1903, and the Gillette safety razor......
Ian Welford28/08/2020 10:11:40
292 forum posts
If you ask nicely the bottles containing hair colouring with nozzles make excellent dispensing bottles for oil, water , coolant etc Smell at bit odd at first but after a couple of rinses...
EngineDIY
