Proxxon collet size?
jon hill 322/08/2020 17:44:51
63 forum posts
14 photos
Can anybody identify the type of collets that the proxxon ff400 milling machine takes?
I have a funny feeling that they are a not standard spec which is frustrating as proxxon ony do a limited range.
I have tried a few aftermarket supply companies without much luck.
Jon
John Haine22/08/2020 18:02:58
3428 forum posts
184 photos
The Proxxon website is pretty poor but says the FF500 takes ER20. There doesn't seem to be an FF400, maybe it's a previous model., though a Google search says that it is a fine feed attachment.
jon hill 322/08/2020 18:07:34
63 forum posts
14 photos
Yes FF400 is now discontinued, I think it was meant to pair with the PD400 lathe or with additional table like mine.
Michael Gilligan22/08/2020 18:16:10
16648 forum posts
725 photos
Posted by John Haine on 22/08/2020 18:02:58:
John,
I posted this on jon’s previous thread :
[quote]
This may inform the advisors : **LINK**
https://www.manualslib.com/manual/1204863/Proxxon-Ff-400.html?page=12#manual
[/quote]
I think it adequately explains what the FF400 was
Ref. https://www.model-engineer.co.uk/forums/postings.asp?th=167233&p=1
Edit: The manual is also available here:
http://proxxonspain.es/images/pdf/manuales/2224304-M.pdf
Edited By Michael Gilligan on 22/08/2020 18:28:13
jon hill 322/08/2020 19:34:46
63 forum posts
14 photos
Unfortunatly the manual doesn't describe the specification of the collets.
Any ideas?
Michael Gilligan22/08/2020 21:25:01
16648 forum posts
725 photos
Posted by jon hill 3 on 22/08/2020 19:34:46:
Any ideas?
I think they are probably ER20 ... but that’s only my ‘reading between the lines’ on various Proxxon pages.
The machine is said to come with some collets ... do you have any ?
... A picture would be worth the proverbial thousand words.
Dick H22/08/2020 22:06:31
95 forum posts
I think the Proxxon collets are a special design, you have to engage the collet in the nut before you tighten it in the spindle. Conversely if it doesn´t disengage on loosening you have to jiggle it a bit until you can remove it from the tightening nut. I hope this is clear but I don´t know the correct terms to describe this. I have a Proxxon FF230 (notmy choice) and I know if the collet is not properly engaged it will move in use.
Michael Gilligan22/08/2020 22:17:01
16648 forum posts
725 photos
The plot thickens ...
These don’t look like ER20 [although they could have the same basic dimensions]
https://www.hobbyland.eu/eng/shop/5-pcs-collet-set-for-ffpf-400500-proxxon/p-17921/
Edit: At last, I have found a picture which purports to show the Proxxon collets:
Manufacturer ID 24252, as per the previous link
http://us.100y.com.tw/viewproduct.asp?MNo=64443
No useful dimensions to identify the style though
Edit: Alternatively, we are offered these: https://www.ebay.co.uk/c/1295140767
Edited By Michael Gilligan on 22/08/2020 22:31:33
Edited By Michael Gilligan on 22/08/2020 22:41:29
Dick H22/08/2020 22:29:51
95 forum posts
Look at the annular slot that locks into the tightening nut , then you understand how it works.
Michael Gilligan23/08/2020 09:53:30
16648 forum posts
725 photos
The Proxxon website is pretty poor but says the FF500 takes ER20. [...]
The combination of that ^^^ plus my links of yesterday, would seem to confirm that the outside dimensions must be compatible with ER20 [even if some Proxxon collets are slit in the ‘fixed capacity’ style.
Former Member23/08/2020 10:02:57
JasonB23/08/2020 10:26:35
19135 forum posts
2105 photos
Michael, did you not look at page 4 of your linked manual, shows they are slit from one end only and unlikely to be ER as we know them.
Michael Gilligan23/08/2020 10:35:28
16648 forum posts
725 photos
Posted by JasonB on 23/08/2020 10:26:35:
YES, I looked, Jason !!
That is precisely why I wrote: outside dimensions must be compatible with ER20 [even if some Proxxon collets are slit in the ‘fixed capacity’ style.
... Did you not look at the links I posted yesterday ?
secret
Edited By Michael Gilligan on 23/08/2020 10:38:30
Former Member23/08/2020 10:38:00
JasonB23/08/2020 12:25:53
19135 forum posts
2105 photos
Posted by Michael Gilligan on 23/08/2020 10:35:28:
secret
I was going by the fact that yesterday you said "at last I have found a picture" when there was a picture in the manual all the timecrook
Circlip23/08/2020 12:36:54
1215 forum posts
Thanks for dimensional description Barrie, Saves irritant squabbling. Probably a dimensioned drawing of all ER size collets, there seems to be for all other types, Crawford Etc.. And part of design is that ER collets are supposed to be self extracting. We all seem to have lost a great mentor.
Regards Ian.
Edited By Circlip on 23/08/2020 12:38:39
Edited By Circlip on 23/08/2020 12:40:55
Edited By Circlip on 23/08/2020 12:44:47
Michael Gilligan23/08/2020 13:39:37
16648 forum posts
725 photos
Posted by JasonB on 23/08/2020 12:25:53:
A usefully informative photographic picture of the collets which are supplied in the boxed set; not just a line drawing in the manual.
most others only show them in the box, with just the noses visible
[quote]
[/quote]
Edited By Michael Gilligan on 23/08/2020 14:06:18
Michael Gilligan23/08/2020 14:10:39
16648 forum posts
725 photos
Posted by Circlip on 23/08/2020 12:36:54:
Not for the first time on this forum ... I find myself wishing I hadn’t tried to help.
Dick H23/08/2020 16:12:56
95 forum posts
Just to give the pot a stir, I looked at a German Proxxon dealer´s site and they sell a set of ER20 collets for the FF400 for machines with a serial number beyond 401-10910 manufactured after 05/ 2012. Before then I think they used the Proxxon style collets with slits from the front face. Around 2012 the ER20 collets became the norm, hence the confusion. See https://www.fluidonline.de/proxxon-24304-81-ersatz-spannzange-12mm-fuer-ff400-pf400_3629_4029.
Dick.
jon hill 323/08/2020 23:05:41
63 forum posts
14 photos
Thanks everyone for all your research, I did eventually find a US chart that lists the exact dimensions of er collets. Previously I thought it might be er20, however another site had a table which suggested it was er16.
Having done some measurements from one of the genuine proxxon collets they are as follows: 4 Deg taper, 27.06mm height, 18.24mm diameter (widest point). However as others have said it is a non standard size and not an 'er' collet.
I will leave the chart for reference: **LINK**
EngineDIY
