larry phelan 1 | 15/08/2020 12:58:17 |
1172 forum posts 15 photos | Good morning all, I am about to fit a power feed unit to my milling machine. The unit comes with a 110V plug unsuitable for our system, so needs to be replaced. The wires are black white green. Which is the live, white or black ? I suspect it is white, but just to be sure I decided to check Thanks for your help [always available ] |
John Haine | 15/08/2020 13:09:27 |
4644 forum posts 273 photos | Umm... If it's a 110V plug, is a 110V motor? If so it might not be a good idea to just put a new plug on it, you would need a transformer too... |
DC31k | 15/08/2020 13:17:17 |
662 forum posts 2 photos | If it is AC, it does not matter which you connect to live or neutral, but US wiring uses black for live. See: https://www.graphicproducts.com/articles/wire-color-coding/ As John says, you need a transformer. A standard yellow building site one is cheap. |
Bryan Cedar 1 | 15/08/2020 13:23:32 |
98 forum posts 4 photos | You talk of two connections, do not forget the earth! |
larry phelan 1 | 15/08/2020 16:58:01 |
1172 forum posts 15 photos | Yes John, it is a 110v motor, was ordered as such, so was fitted with a 110v moulded plug, just not the type we use., that,s why a new one has to be fitted. and I do have a transformer. Bryan, I did notice the earth connection, I,m not that brave. I dont take chances, even with 110 v ! Thanks to all |
Michael Gilligan | 15/08/2020 17:54:29 |
![]() 20113 forum posts 1044 photos | It’s a lazy and extravagant option, but adaptor leads are available to suit the yellow ‘site’ transformers: A google search for : iec 110v plug to american should find one for around £25 That said, it’s only a five minute job to put an IEC plug on the lead. MichaelG |
Meunier | 15/08/2020 20:22:54 |
448 forum posts 8 photos | I'm resisting the temptation, I really am trying, to enquire if that will need 'Arctic' cabling ? Oh, weak-willed again....... |
Paul Kemp | 16/08/2020 00:42:41 |
710 forum posts 27 photos | I think it might need tropical cable at present or even sub sea cable depending on your location......... In fact an adaptor lead may be a very good suggestion, could have one for all seasons! I'll get my coat, Paul. |
larry phelan 1 | 16/08/2020 10:05:33 |
1172 forum posts 15 photos | Maybe I should just go back to spinning the hand wheels ? |
