Door stay help
AJW10/08/2020 11:33:05
306 forum posts
121 photos
We had a couple of uPVC doors fitted about 9 months ago. There was an option of a door stay unit that fits to the top of the door and has an adjustment screw fitted to create friction in the door stays operation which we have found quite useful as the door can be left part open and resisting wind gusts.
I have now found that the friction adjustment is all taken up and no more friction adjustment! All worn out in 9 months.
Removing the unit from the door it is of a very poor design so I dug out a lump of brass in the hope I can make something longer lasting but before I attempt a redesign I thought I would ask has anyone had experience of uPVC door stays that work and more importantly - keep working!
Alan
Bazyle10/08/2020 12:09:47
5464 forum posts
206 photos
Is it something like moulded nylon - a bit flexible? Brass might be too hard to get adjusted unless there is room for a spring. Maybe tufnot.
Circlip10/08/2020 12:27:28
1197 forum posts
Door furniture for plastics were never meant to be a "Partial" thing, Door is either closed or fully open, design was to stop door opening greater than 90deg. saving tears if you inadvertently let go while opening it in a wind. French doors??
Regards Ian
Edited By Circlip on 10/08/2020 12:28:43
Jim Young 210/08/2020 12:58:21
24 forum posts
5 photos
Many and various designs on eBay for between £5 and £10. Can you just replace the friction pad perhaps?
AJW10/08/2020 13:26:37
306 forum posts
121 photos
Thanks for replies! Yes the assembly uses a moulded nylon section for applying friction and it works well but it slides inside the extruded aluminium section that fits the door channel.
Unfortunately the friction wears out the nylon piece. I have seen the same design from various outlets from less than £4 but I know they won't last!
Even found a review of door stays where this design came up trump's although it's obviously not been tested over a longer period as it would wear itself out.
Think I need to re design the idea.
Alan
Nicholas Wheeler 110/08/2020 13:56:52
390 forum posts
20 photos
Posted by Circlip on 10/08/2020 12:27:28:
it's also intended to prevent the door and mechanism from damage by slamming shut. The stay will slow it down.
Phil H110/08/2020 14:10:23
315 forum posts
32 photos
Not quite what you have described but we have two quite wide French type doors and we use two simple brass hook and loop arrangements. The hook is attached to the wall and the loops on the bottom of the door frames. They hold the doors wide open and there is no problem with the wind.
pgk pgk10/08/2020 14:28:20
1911 forum posts
288 photos
I have the same arrangement on my UPVC patio doors..totally useless in any breeze. My solution was to add hooks and eyes from outside wall to door at the bottom... simple and guaranteed.
pgk
Danny M2Z10/08/2020 15:30:00
892 forum posts
283 photos
I just use a rubber wedge under the door. Open door, kick the wedge in place.
Clive Brown 110/08/2020 15:54:02
503 forum posts
18 photos
Our conservatory door suffers from the wind when left open in hot weather. A friction stay was no help. An outside step made a door stop diificult to devise. Solution this year has been a short length of rope, loop in each end to connect the door handle to the nearby garden bench. Takes seconds to deploy. Success!
MadMike10/08/2020 17:20:40
209 forum posts
4 photos
Nine months old? get the crew back that fitted it. Do not alter anything until they have sorted it as they will simply accuse you of tampering.
Sam Longley 110/08/2020 17:27:54
786 forum posts
27 photos
stay
Cornish Jack10/08/2020 17:35:54
1170 forum posts
163 photos
Sam has it - we have two fitted to our french windows and they JUST WORK, - and have done untended for 6 years so far. Have just ordered another for the scullery door. Available in 8" and 12". We use the 12" to cope with the outside step.
rgds
Bill
AJW10/08/2020 17:51:55
306 forum posts
121 photos
Yes, only 9 months usage! Disgusting, and I am sure they would be replaced but I would only get another 9 months use because they just wear out!
As you say I could fit one of the 'door holder open' type stays but the beauty of the original (albeit short term!) is the ability to leave the doors anywhere between ajar and fully open.
Alan
larry phelan 110/08/2020 19:29:35
820 forum posts
17 photos
My Granny used to use a spare brick to hold the backdoor open, but I suppose that would be out of fashion these days ?cheeky
Perko711/08/2020 07:50:27
351 forum posts
24 photos
Would replacing the nylon with a stiff felt pad (the type used for putting under chair legs) be a potentially more long-lasting option?
john carruthers11/08/2020 08:40:55
606 forum posts
177 photos
We would fit 'restrictor stays' as a safety option, mainly on tilt&turn windows on upper floors to avoid people falling through. They are a simple toothed bar that clips onto a stud.
They can be fitted to doors and would give some adjustment to how wide it opens.
Or, how about a damper style restrictor as used on caravans, boats, etc ?
Edited By john carruthers on 11/08/2020 08:56:27
AJW11/08/2020 10:11:03
306 forum posts
121 photos
The felt idea sounds like it would offer better long term operation, I will certainly look that idea. The only real restriction is that any of the friction components need to operate in the extruded aluminium channel fitted into the door edge shape, and it is just over 1/2 in wide!
Our old wooden doors had a friction device incorporating a max opening position. This was screwed to door and frame with the 'hinge' between both parts having the friction components fitted a bit like the old suspension dampers used on old Bentley's etc. Worked a treat and as the cork components wore they could be re adjusted with a wing nut.
Not the sort of thing that is suitable for a plastic door/frame though.
John, you refer to a damper/restrictor - got anymore info?
Alan
AJW11/08/2020 21:33:01
306 forum posts
121 photos
Well I woke up with the bit between my teeth this morning determined to improve the stays!
Found myself a piece of self adhesive felt which when compressed was about .035 thou thick, a lump of steel to machine into a 'T' shape to fit the alloy channel. Had to pop round local screw supplier for some grub screw's and csk jobbies.
Basically spent all day developing them but am really pleased with the results. I have two grub screws which expand the T section with the felt attached to adjust the friction within the channel.
The original design, while obviously cheap is of very poor design and of very limited lifespan, how can they sell such a poor product?
Alan
Sam Longley 112/08/2020 06:50:54
786 forum posts
27 photos
Posted by AJW on 11/08/2020 21:33:01:
Well you bought one for a startwinkfrownsurprise
Edited By Sam Longley 1 on 12/08/2020 06:51:43
EngineDIY
