Robin Graham | 08/08/2020 00:13:47 |
945 forum posts 295 photos | This arises because I got involved with a project to make a riser for a VMC mill as detailed in another thread . It got me thinking. How does one turn the faces of a bar parallel? The inimitable doubleboost just turned the piece end-for-end in the 3-jaw. I tried that with with a 4" diameter billet, making sure the workpiece was referenced to the flats on the jaws rather than the grippy bits. It turned out about 0.03mm out of parallel across 100mm. Not good! I'm wondering if it can be done better by bolting to a faceplate which could be skimmed before attaching the work? Robin
Hopper | 08/08/2020 00:27:35 |
![]() 6203 forum posts 321 photos | No need to skim your faceplate unless there is something measurably wrong with it. You could ruin a good plate. But yes it's more reliable to bolt to faceplate to get faces parallel. Holding in the 3 jaw by a relatively small area can allow movement under load. Or bits of swarf or even duff chuck jaws can throw it out too. And always tap the the job home carefully with a brass hammer to make sure job is seated on all jaws. A 4 jaw would give better grip than a 3. |
Hopper | 08/08/2020 02:37:43 |
![]() 6203 forum posts 321 photos | PS. But the faceplate method can mean you end up with the two ends parallel to each other but out of square with the outer diameter. This happens if the first unmachined face bolted to the faceplate is not square to the OD to start with -- as is common with power hacksaw cuts on stock. Probably for a riser, the OD is non-functional so won't matter if it is not square to the faces. If you want to get the OD square to both ends and both ends parallel, the best way would be careful set up in the four jaw. Get OD running true at both ends and job seated firmly on all four jaw steps with a brass hammer. Then carefully machine one end. Then either flip it around and do the same again or use the faceplate to do the second face. |
Hopper | 08/08/2020 05:11:35 |
![]() 6203 forum posts 321 photos | Using a tailstock centre would help keep things in place in the chuck too, facing across to leave a small tit in the middle to be removed last and perhaps even relieved a little so load bearing is around the outside. Edited By Hopper on 08/08/2020 05:12:34 |
Neil Lickfold | 08/08/2020 06:31:21 |
836 forum posts 166 photos | 1st to check, is the cross slide actually square to the run of the lathe. Some are not and are not adjustable in any way to make them square. Which is why on some older machines, you need to set the compound to get a flat face. |
Ady1 | 08/08/2020 06:49:19 |
![]() 5067 forum posts 734 photos | It's not really a lathe job, there are too many potential errors I would use a shaper (or if I had one a grinder) the faces must be parallel, and flat, and at right angles to the diameter Lathes do round bits and shapers do flat bits I believe that most lathes are set up a bit convex or concave to start with, so even the facing off isn't really flat which doesn't matter with most jobs but when you need it really spot on you need the right machine I suppose a decent mill with a fly cutter would also do flat Edited By Ady1 on 08/08/2020 07:14:53 |
JasonB | 08/08/2020 06:55:44 |
![]() Moderator 22588 forum posts 2641 photos 1 articles | As you were using the outside jaws and the work was not back against the chuck it would be easy enough to get a dti onto the previously faced now back face of the work to check it for true running. Only tap the work back against the jaws if you know they are totally true. Regarding hoppers point about ends not parallel that is easily solved by taking a cut off the OD at the same setting when facing the first end.
Edited By JasonB on 08/08/2020 07:16:58 |
Michael Gilligan | 08/08/2020 08:45:14 |
![]() 20096 forum posts 1042 photos | Posted by Ady1 on 08/08/2020 06:49:19:
. I suppose a decent mill with a fly cutter would also do flat
. Given the purpose of the exercise ... That would seem the obvious choice, MichaelG. |
DC31k | 08/08/2020 09:13:50 |
661 forum posts 2 photos | Posted by Ady1 on 08/08/2020 06:49:19:
I believe that most lathes are set up a bit convex or concave to start with Have a look on the Stub Mandrel site for Schlessinger's work and then you will know rather than merely believe. |
Essm | 08/08/2020 09:32:38 |
29 forum posts 8 photos | It turned out about 0.03mm out of parallel across 100mm. Not good! Good grief man thats a tad over one thou - I think its fantastic! |
John Haine | 08/08/2020 09:48:40 |
4631 forum posts 273 photos | Obviously the person who has the requirement here has a mill, though it might be in pieces. But this is an obvious milling job, it would need a large lathe and chuck to hold it accurately for turning. I had a similar issue facing and drilling a pendulum bob and did that on the mill. Surely it must be easier for the mill to be reassembled and used rather than a dodgy lathe setup? |
Phil H1 | 08/08/2020 09:51:59 |
458 forum posts 60 photos | Essm, You beat me to it. I would say that 0.03mm in a 3 jaw chuck is quite good. You could also try checking the jaws with a DTI to see if that is the cause of this small error. For reference, the jaws on my had it from brand new, top of the range, very expensive 4 jaw chuck is out by about 0.001". Phil H |
JasonB | 08/08/2020 10:09:12 |
![]() Moderator 22588 forum posts 2641 photos 1 articles | Just measured the 100mm dia EN3 flywheel blank I turned the other day in 4 places around the rim no more than 2/10ths deviation which is 0.005mm so I must be doing something right though did not clock the back so maybe I could have done better but job did not need it. |
mgnbuk | 08/08/2020 10:12:31 |
1177 forum posts 71 photos | It turned out about 0.03mm out of parallel across 100mm. Not good! But not too bad for a 3 jaw either ? Close enough to sort with a scraper if you are in a position to measure the error. Could you not put the component between centres, face one end, reverse the part & face the other ? Should be pretty close to parallel done that way. May need a hole drilling & tapping in a non-working area to take a drive peg. I have a cylinder square at work that appears to have been machined that way, complete with an off-centre tapped hole at each end. Nigel B. |
Vic | 08/08/2020 11:10:57 |
3060 forum posts 8 photos | The riser block can be fitted in one of three positions. Given that Chinese machines often have “errors” built into them it might actually be and advantage to have a slightly less than square riser?! |
blowlamp | 08/08/2020 11:18:50 |
![]() 1595 forum posts 102 photos | Turn it between centres and both faces will be parallel with each other. Face the tailstock end first, remove part from lathe, refit back between centres with faced end now located at headstock. Face the tailstock end. Job done.
Martin. |
Graham Meek | 08/08/2020 11:25:33 |
464 forum posts 300 photos | Martin you came in while I was writing, I would simply rough out somewhere near size and centre each end with a protected, or recessed centre. Drill and tap at one of the mounting holes on each face for a driver peg. Then mount the work between centres to take a light skim down each face and over the O/D if desired. This does assume that the lathe is already set-up correctly. Regards Gray, Edited By Graham Meek on 08/08/2020 11:26:09 |
blowlamp | 08/08/2020 12:06:08 |
![]() 1595 forum posts 102 photos | Posted by Graham Meek on 08/08/2020 11:25:33:
Agreed, Graham. If a fairly large central relief can be made at each end, which leaves a face of sufficient size for its intended purpose, then a much smaller area will need facing and the concave/convex facing issue becomes almost irrelevant.
Martin. |
Hopper | 08/08/2020 13:21:16 |
![]() 6203 forum posts 321 photos | Posted by Essm on 08/08/2020 09:32:38:
It turned out about 0.03mm out of parallel across 100mm. Not good! Good grief man thats a tad over one thou - I think its fantastic! Oops. I missed that. Yes you are not going to get much better than that on the average lathe. |
Michael Gilligan | 08/08/2020 13:59:33 |
![]() 20096 forum posts 1042 photos | Posted by DC31k on 08/08/2020 09:13:50:
Have a look on the Stub Mandrel site for Schlessinger's work . I am genuinely surprised to see ‘the book’ available there ... ‘though of course that is not all of Schlesinger’s work. MichaelG. . Edit: But time has passed since this discussion: https://www.model-engineer.co.uk/forums/postings.asp?th=132159 Edited By Michael Gilligan on 08/08/2020 14:03:01 |
