Warco Minor mill/drill
Andrew Jenkins27/07/2020 20:42:55
15 forum posts
Hello everyone
Newbie alert! I have searched but not found on this forum info on whether the above named machine is any good?
I should point out I havent got it yet as its in storage, belongs to my brother who moved and as yet hasnt got his new workshop built! so any thoughts on this machine good or bad as I cant afford a different one!
Andy
Dave Halford28/07/2020 09:53:26
866 forum posts
8 photos
It's a round column mill with an awkward 3 pully belt drive, just ensure you don't need to move the head in the middle of a job. However it will drill and it will mill with a suitable milling cutter holder (not the drill chuck)
As you say "I cant afford a different one!" so it's fine.
Nicholas Farr28/07/2020 10:41:28
2405 forum posts
1188 photos
Hi Andrew, you may find this useful Warco Minor review.
Regards Nick.
Adrian 228/07/2020 12:09:25
82 forum posts
19 photos
Hello Andy, I have a Warco Minor, the round column can be a pain but there are work arounds. A DRO on the quill is
a must. Over all I am happy with it . It is solid and I have done some useful work with it. The build quality is better
than some later offerings. Being able to swing the head around can have its advantages when working on a large
job. Go for it.
Adrian.
Mick Dobson28/07/2020 12:16:46
21 forum posts
10 photos
Hello Andy,
I had one of these bought (new) in about 1994. It was a decent machine and quite sturdy, probably more so than the smaller ranges of dovetail machines on offer. The mil has reasonable capacity as well.
The round column is a limiting issue if moving the head between cuts when you need to go back to the same reference. I sold it on in 2008 and got a Super Major with dovetail column and powered head rise/fall etc.
Good luck, Mick
BCPROF28/07/2020 12:18:27
137 forum posts
Hi Andrew
A clone of the minor was my first milling machine . The manual was interesting " Please not to be installing the complex machine in a sunshine place " was the first instruction !. They are good , solid and heavy machines . Yes ,as others have said in the past about round column, mills they are a pain if you have to adjust the head but any mill is better than no mill so go for it
Russ B28/07/2020 12:58:14
575 forum posts
21 photos
Just my 2 pence, I think they're very good machines, I much prefer the reliability and pure power of the belt drive system to that of an electronic drive.
They're substantial enough to make good quality cuts on small parts, and certainly have the power, 2 points which can't be said for a lot of other similar sized machines.
Sure the round column means you lose x/y ordinates if/when you have to lower the head, but it's not hard to pick them up for the occasional times it has to happen, and with carefully selected tooling (mainly a set of stub drills) it's rarely an issue.
I can't think of a better machine for the price and sq footage, but thats all very personal, I don't need atom splitting accuracy, I like the power and reliability and heavy duty'ness of it.
* I should point out, there are 2 different sizes of this machine, they both look the same but next each, completely different, both capable, both solid. Some have plain tables with keep plates, some (most) have dovetail with tapered gibs. some have 8 speeds, some 10, some 12 etc. The older ones seem to have a better fit and finish than the newer ones I've had my hands on although I've owned 3 or 4 of the old ones, I've never owned a newer one so hard to pickout exactly why, could just need tweaking and setting up these days.
Edited By Russ B on 28/07/2020 13:04:19
Bazyle28/07/2020 13:55:37
5391 forum posts
206 photos
Again a user endorsement as it is a very good machine for hobby use and capable of anything you need to do on a 5in gauge loco for instance. Plenty of range on the z axis if you plan ahead far enough to put the head in the right place at the start, the danger is just being lazy or impatient to start.
One small problem not normally mentioned is that if you take too heavy a cut sideways the head might rotate so make sure that such a movement moves the cutter away from the work. Tends to happen when you forgot to properly tighten both bolts on the head after a move.
Howard Lewis28/07/2020 20:36:30
3536 forum posts
I have owned it smaller sister, a RF25 (Economy ) for many years.
My solution to the loss of co ordinates when moving the head on the column was to follow Stan Bray's advice and install a bracket on the head into which a cheap DIY shop laser can be inserted, snugly. When you are happy about the position of the head, relative to the table, switch on the laser, Draw a line on the wall furthest from the machine where the beam falls.
DON'T look at the beam!
If you reposition the head so that the laser line always falls on the line on the wall, you should maintain a reasonable alignment.
Over ten feet any error should be of the order of 0.001", which should suffice for most work.
Don't overtighten the bolts for the internediate pulley carrier, to prevent cracking the casting.
If the pulleys are not aligned (motor in particular ) belt life will be shortened.
If the NVR switch buzzes, try tightening the securing screws! It worked for me.
HTH
Andrew Jenkins30/07/2020 19:39:15
15 forum posts
Hi Dave
Apologies for the late reply.
Posted by Dave Halford on 28/07/2020 09:53:26:
I'll bear that in mind.
Andy
Andrew Jenkins30/07/2020 19:40:32
15 forum posts
Hi Nicholas
Apologies for the late repl.
Posted by Nicholas Farr on 28/07/2020 10:41:28:
Regards Nick.
I'll read that later!
Andy
Andrew Jenkins30/07/2020 19:42:53
15 forum posts
Hi Adrian
Apologies on the late reply.
Posted by Adrian 2 on 28/07/2020 12:09:25:
job. Go for it.
Adrian.
I'll look into a DRO in the future when I get the machine.
Andy
Andrew Jenkins30/07/2020 19:44:47
15 forum posts
Hi Mick
Posted by Mick Dobson on 28/07/2020 12:16:46:
Hello Andy,
Good luck, Mick
Nice to see they can last for more than a couple of years!
Andy
Andrew Jenkins30/07/2020 19:47:54
15 forum posts
Hi Russ
Posted by Russ B on 28/07/2020 12:58:14:
I'm not sure of the exact model my brother has but good to know that there are different 'Minors'.
Andy
Andrew Jenkins30/07/2020 19:50:00
15 forum posts
Hi Bazyle
Posted by Bazyle on 28/07/2020 13:55:37:
Again more useful information from experienced users to help a novice like myself!
Andy
Andrew Jenkins30/07/2020 19:52:19
15 forum posts
Hi Howard
Posted by Howard Lewis on 28/07/2020 20:36:30:
HTH
Again more useful user experince info for me to glean!
Andy
Andrew Jenkins30/07/2020 19:54:50
15 forum posts
Again thanks to all the above for taking time to reply!
Any body know how to multi quote? laugh
Andy
Speedy Builder530/07/2020 20:27:10
2077 forum posts
145 photos
I too have the Economy Mill - can be a pain changing from slow to fast speeds. I keep a second motor belt on the machine. The lower belt is used for high speeds whilst the higher belt is removed. For slow speeds, the lower belt is slipped off the pulleys and laid on the lower belt guard out of the way of the pulleys. The higher belt is slipped on for the lower speeds.
Ov course a variable speed motor would help, but that is increased cost etc etc (and another potential source of problems).
Andrew Jenkins30/07/2020 20:59:14
15 forum posts
Hi Speedy
Posted by Speedy Builder5 on 30/07/2020 20:27:10:
Thanks for another useful tip! As you say a variable speed motor would be very useful but beyond my budget for now, maybe if i win the pools! laugh
Andy
peak430/07/2020 21:47:37
1153 forum posts
135 photos
I'm broadly with Adrian 2 on the ability to swing the head on the round column, whilst it can be a pain, it also has a major advantage for those of us who do jobs which are too big for our machines.
I don't have the Warco you hope to receive, but have a Dore Westbury, which also has a round column.
I've just been recommissioning a Herbert grinder, and wanted to mill a flat on a casting which was longer than the travel on the table, by several inches.
By swivelling the head from one side to the other, I was able to complete the job without needing to move and re-clamp the workpiece, which would have been something of a nightmare as it's bigger than the mill table.
Swung to the left;Herbert Junior Surface Grinder recommissioning.
And swung to the right;
I also have Centec, with a more conventional dovetail column design, but could never have done the job on that at all.
Do enjoy your new toy when you get it; if your first efforts don't go to plan, don't get disheartened; just come back and ask more questions.
Bill
Edited By peak4 on 30/07/2020 21:49:57
EngineDIY
